input CLK_IN; //40Mhz input CLK_RST; //全局复位信号
output SYS_CLK;//输出20Mhz时钟信号 output MAC_CLK;//7.5Mhz output DIN_CLK;//60Mhz output CB_CLK;//80Mhz output SYS_CLK_D;//40Mhz output LOCKED;//时钟锁定信号,高电平锁定,锁定期间所有时钟正常工作
wire RST; //RST is the core reset signal enabled with high level wire LOCKED_OUT1; //Output of the DCM1 that activates after the DCM has achieved lock wire SYS_CLK; //Clock divide output of the DCM1 by 2 wire CB_CLK; //Clock double output of the DCM1 wire DCM2_CLK; //Frequency synthesizer output to the DCM1 by 2/3 wire SYS_CLK_D; //The clock output same as input clock of DCM1 wire CLK_IN2; //Clock for generating MAC_CLK reg LOCKED; reg MAC_CLK; //Clock divide output of the DCM1 by 8 wire DIN_CLK; reg lock_reg; reg lock_reg1; reg lock_reg2; assign DCM2_CEN=~lock_reg2; assign RST=~CLK_RST; //RST is the core reset signal enabled with high level. wire RST2; assign RST2=lock_reg2; //Digital clock management block1 is used to generate clocks with the frequency //of 20MHz, 40MHz, 80 MHz and 60MHz. The last one will be used as the clock to //generator 7.5MHz.
wire clk_reg; DCM1 U_DCM1 ( .RST_IN(RST), .LOCKED_OUT(LOCKED_OUT1), .CLKIN_IN(CLK_IN), .CLKDV_OUT(SYS_CLK), .CLK2X_OUT(CB_CLK), .CLKFX_OUT(DCM2_CLK), .CLK0_OUT(SYS_CLK_D), .CLKIN_IBUFG_OUT(clk_reg) );
BUFG DCM2_CLK_BUFG( .I (DCM2_CLK), .O (CLK_IN2) ); BUFG CLK_BUFG( .I (DCM2_CLK), .O (DIN_CLK) );
endmodule[/code] 各位达人们,我想请问一下:XILINX中DCM部分??那么用Altera的板子,PLL该怎么实现啊 ?? 尤其是 .CLKIN_IBUFG_OUT(clk_reg) 这个怎么解释啊 ?看不懂啊 ? 这个在Altera板子上怎么实线 ??感谢,万分感谢。小弟在做论文啊...OFDM系统
