2845|0
lm3s 把中断放在ram中,对NVIC_VTABLE赋值时错误 [复制链接]
  1. void
    IntRegister(unsigned long ulInterrupt, void (*pfnHandler)(void))
    unsigned long ulIdx, ulValue;
    // Check the arguments.
    ASSERT(ulInterrupt < NUM_INTERRUPTS);
    // Make sure that the RAM vector table is correctly aligned.
    ASSERT(((unsigned long)g_pfnRAMVectors & 0x000003ff) == 0);
    // See if the RAM vector table has been initialized.
    if(HWREG(NVIC_VTABLE) != (unsigned long)g_pfnRAMVectors)
    // Copy the vector table from the beginning of FLASH to the RAM vector
    // table.
    ulValue = HWREG(NVIC_VTABLE);
    for(ulIdx = 0; ulIdx < NUM_INTERRUPTS; ulIdx++)
    g_pfnRAMVectors[ulIdx] = (void (*)(void))HWREG((ulIdx * 4) +
    ulValue);
    // Point NVIC at the RAM vector table.
    HWREG(NVIC_VTABLE) = (unsigned long )(g_pfnRAMVectors+8);
    // Save the interrupt handler.
    g_pfnRAMVectors[ulInterrupt] = pfnHandler;
复制代码
上面是函数 那个+8是我自己加上的,加和不加都一样,NVIC_VTABLE始终是20000380.
为什么
有奖探索 | 和村田一起,深挖 GNSS 开发!
活动时间:即日起-5月11日
活动奖励:智能手环、螺丝刀套装、双肩包
