3375|3
28
lauchpad g2553频率测量 [复制链接]
做一个lauchpad  g2553频率测量,但是编译总是出错
谁能给个程序参考下,频率捕获的
#include "msp430g2553.h"#include "delay.h" void sys_init(void){  DCOCTL = CALDCO_16MHZ;  BCSCTL1 = CALBC1_16MHZ;    } void io_init(void){  P1DIR = 0;  P1DIR |=  BIT4  + BIT6;  P1SEL |= BIT1;}void cap_init(void){  TACTL |= TASSEL_2 + MC_2 + TACLR;  //MCLK , CONTINUE , CLEAR  TACCTL0 |= CM_1 + SCS + CAP + CCIE + CCIS_0; // rising edge , synchronous , capture , interupt enable } void main( void ){  // Stop watchdog timer to prevent time out reset  WDTCTL = WDTPW + WDTHOLD;  sys_init();  io_init();  cap_init();  __enable_interrupt();   while(1)  {    P1OUT ^= BIT6;    delay_ms(30);  }} #pragma vector = TIMER0_A0_VECTOR__interrupt void capture(void){  P1OUT ^= BIT4;    //  输出频率是捕获频率的一半}  详情 回复 发表于 2012-7-17 21:23
2856
260
呵呵,慢慢调程序
#pragma vector=TIMERA1_VECTOR //==定时器A中断处理== __interrupt void timer_a(void) { switch(TAIV) //==向量查询== { case 2: { if(j>1) {  详情 回复 发表于 2012-7-13 16:08
28
回复 沙发 ltbytyn 的帖子
  { case 2:
         if(j>1)
           j=1;
           end = TAR;
           if(end>start)
             width[time++]=end-start;            //time在此++
         j=2;
         start =TAR;
         TACCTL1 &=~CCIFG;
         if(time>=32)
           CCTL1 &= ~CCIE;
       break;
      default:j=1;
      break;
说这个#pragma vector=TIMERA1_VECTOR        //==定时器A中断处理==
没有定义。。。。不懂了,前面都已经有了
#include
#include
#include
还需要定义么?
#include "delay.h"
void sys_init(void)
void io_init(void)
  P1DIR = 0;
  P1SEL |= BIT1;
void cap_init(void)
void main( void )
  sys_init();
  io_init();
  cap_init();
  while(1)
    P1OUT ^= BIT6;
    delay_ms(30);
