1. Pattern measurement: a. The anechoic chamber is a far-field measurement system with size of 7m*3m*3m. The quiet zone region is 30cm x 30cm x 30cm at center of the rotator. b. The probing antenna is the Darfon 900MHz~18 GHz module ( 9120D horn antenna ) , which is placed in the one side of the chamber room. And the antenna under testing (AUT) is placed in the other side of the chamber. The distance between the probing antenna and the AUT is about 4m. c. The gain is calibrated by the standard gain horn (BBHA 9120 LFA 700MHz~6GHZ), and we do the gain calibration in each measurements. d. We use the HP 8753D for the pattern measurements. e. The scanning method is CW wave with 6 degree by one step. f. We measure the radiation pattern in the free space situation at the lowest,middle and highest frequency for the H(X-Y), E1(Y-Z), and E2(X-Z) planes, which defined in figure next page.
