3821|5
MSP430G2231产生PWM波 [复制链接]
如何用MSP430G2231产生150Kz的方波?求教各位大神,谢谢了
//****************************************************************************** //  MSP430G2xx1 Demo - Timer_A, PWM TA1-2, Up Mode, DCO SMCLK // //  Description: This program generates one PWM output on P1.2 using //  Timer_A configured for up mode. The value in CCR0, 512-1, defines the PWM //  period and the value in CCR1 the PWM duty cycles. //  A 75% duty cycle on P1.2. //  ACLK = na, SMCLK = MCLK = TACLK = default DCO // //               MSP430G2xx1 //            ----------------- //        /|\|              XIN|- //         | |                 | //         --|RST          XOUT|- //           |                 | //           |         P1.2/TA1|--> CCR1 - 75% PWM // //  D. Dang //  Texas Instruments, Inc //  October 2010 //  Built with CCS Version 4.2.0 and IAR Embedded Workbench Version: 5.10 //****************************************************************************** #include   void main(void) {   WDTCTL = WDTPW + WDTHOLD;                 // Stop WDT BCSCTL1 = CALBC1_16MHZ;                   // Set range   DCOCTL = CALDCO_16MHZ;                    // Set DCO step + modulation*/   P1DIR |= 0x0C;                            // P1.2 and P1.3 output   P1SEL |= 0x0C;                            // P1.2 and P1.3 TA1/2 options   CCR0 = 106;                             // PWM Period   CCTL1 = OUTMOD_7;                         // CCR1 reset/set   CCR1 = 53;                               // CCR1 PWM duty cycle   TACTL = TASSEL_2 + MC_1;                  // SMCLK, up mode   _BIS_SR(CPUOFF);                          // Enter LPM0 }  详情 回复 发表于 2012-7-20 04:12
//****************************************************************************** // MSP430G2xx1 Demo - Timer_A, PWM TA1-2, Up Mode, DCO SMCLK // // Description: This program generates one PWM ou  详情 回复 发表于 2012-7-20 04:12
437
不知道怎么插入代码,直接贴上来了~
这是之前写的一个,两路PWM,一路5.6k,一路150k~
你可以试试看~
#include  <msp430g2553.h>
void main(void)
    BCSCTL2 = SELM_0 + DIVM_0 + DIVS_1; //2
    if (CALBC1_16MHZ != 0xFF)
        DCOCTL = 0x00;
        BCSCTL1 = CALBC1_16MHZ;      /* Set DCO to 16MHz */
    BCSCTL1 |= XT2OFF + DIVA_0;
    BCSCTL3 = XT2S_0 + LFXT1S_2 + XCAP_1;
  P2SEL |= BIT0+BIT1;                        // P2.0 - P2.1 option select
  P2DIR |= BIT0+BIT1;                        // PP.0 - P2.1 outputs
  TA1CCTL0 = OUTMOD_4+ CCIE;                // TA1CCR0 toggle, interrupt enabled
  TA1CCTL1 = OUTMOD_4+ CCIE;              // TA1CCR1 toggle, interrupt enabled
  TA1CTL = TASSEL_2 +  MC_2;          // SMCLK, Contmode, int enabled
  _BIS_SR(LPM0_bits + GIE);                 // Enter LPM0 w/ interrupt
// Timer A0 interrupt service routine
#pragma vector=TIMER1_A0_VECTOR
__interrupt void Timer_A0 (void)
  TA1CCR0 += 664;                              // Add Offset to CCR0 1.4k*4
// TimerA1 Interrupt Vector (TA1IV) handler
#pragma vector=TIMER1_A1_VECTOR
__interrupt void Timer_A1(void)
  switch( TA1IV )
  case  2: TA1CCR1 += 27;                    // Add Offset to CCR1   150k
           break;
拷来试试,正找这东西呢
拷来试试
24
请问楼主我出来的频率是5.9K和146.5K是什么原因呢????
188
回复 楼主 DLY1104 的帖子
//               MSP430G2xx1
//        /|\|              XIN|-
//         --|RST          XOUT|-
//  D. Dang
//  October 2010
#include
void main(void)
有奖直播 | AI之眼——安森美图像传感器 报名中
直播主题:AI之眼——安森美图像传感器
报名观看直播、直播间提问、填写问卷均有机会获得精美礼品!
