3165|3
141错误 打死也找不到..求帮助 [复制链接]
sbit LCDRS=P3^4;
sbit LCDRW=P3^3;
sbit LCDEN=P3^2;
sbit LCDRST=P3^0;
sbit LCDPSB=P3^1;
uchar data z;
uchar data y;
uchar data column;
uchar data page;
uchar *p2;
uchar wbyte;
void delayms(uint z)  //ÑÓ³Ùº¯Êý£¬MS¼¶ÑÓ³Ù¡£
uint data i,j;
for(i=0;i<z;i++)
    for(j=0;j<600;j++)
void write_com(uchar com)
 uchar temp=0;
 LCDRS=0; //  ֮ǰÊÇ0£»
 LCDRW=1;
 do
  LCDEN=1;
  delayms(1);
  temp=P2;
  LCDEN=0;
 while(temp&0x80);
 LCDRW=0;
 P2=com;
 LCDEN=1;
 delayms(1);
 LCDEN=0;
void write_date(uchar date)
 uchar temp=0;
 LCDRS=0;
 LCDRW=1;
 do
  LCDEN=1;
  delayms(1);
  temp=P2;
  LCDEN=0;
 while(temp&0x80);
 LCDRS=1; //¸Ä³ÉдÊý¾ÝÁË¡£Ö®Ç°ÊÇ1.д´í¡£
 LCDRW=0;
 P2=date;
 LCDEN=1;
 delayms(1);
 LCDEN=0;
void clearlcd1()
 uchar  i;
 uchar  j;
 for(i=0;i<64;i++)
  write_com(i|0x80);
  write_com(0x80);
  for(j=0;j<32;j++)
   write_date(0x00);
void picture()
 uchar  v;
 uchar  w;
 uchar  x;
 uchar  h;
 write_com(0x34);
 write_com(0x36);
 for(h=0;h<32;h++)
  v=column|0x80;
  w=page|0x80;
  write_com(w);
  write_com(v);
  page++;
  for(x=0;x<4;x++)
   wbyte=*p2;
   write_date(wbyte);
   p2++;
void init()
 LCDRST=1;
 write_com(0x30);  //»ù±¾Ö¸Á
 delayms(1);
 write_com(0x02);   //µØÖ·¹éλ
 delayms(1);
 write_com(0x0c);   /  /ÕûÌåÏÔʾ´ò¿ª Óαê¹Ø±Õ
 delayms(1);
 write_com(0x02);    //Çå³ýÏÔʾ
 delayms(1);
 write_com(0x02);//¹â±ê´ÓÓÒÏò×ó¼ÓһλÒƶ¯
void lock()
 clearlcd1();
 column=3;
 page=1;
 const uchar code clocker_32_4[]=
 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x7F,0xFE,0x00,
 0x00,0xFF,0xFF,0x00,0x00,0xC0,0x03,0x00,0x00,0xC0,0x03,0x00,0x03,0xFF,0xFF,0xC0,
 0x07,0xFF,0xFF,0xE0,0x06,0x00,0x00,0x60,0x06,0x00,0x00,0x60,0x06,0x00,0x00,0x60,
 0x06,0x00,0x00,0x60,0x06,0x00,0x00,0x60,0x06,0x00,0x00,0x60,0x06,0x00,0x00,0x60,
 0x06,0x00,0x00,0x60,0x06,0x00,0x00,0x60,0x07,0xFF,0xFF,0xE0,0x03,0xFF,0xFF,0xC0,
 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00
  //这里出现 C141 syntax error
 p2=clocker_32_4[];
 picture();
void main()
 uchar temp1[]={"--¡æ "};
 uchar temp2[]={"³ý¹¸"};
 uchar temp3[]={"--ml "};
 uchar temp4[]={"ÖÆË®ÖÐ"};
 int i=0;
 LCDPSB=1;
 init();
 write_com(0x80);//É趨λÖÃΪµÚÒ»ÐеĵÚһλ
 for(i=0;i<4;i++)
  write_date(temp1);
 write_com(0x86);//É趨λÖÃΪµÚÒ»Ðеĵڶþλ
 for(i=0;i<2;i++)
  write_date(temp2);
 write_com(0x98);//É趨λÖÃΪµÚÒ»ÐеĵÚÈýλ
 for(i=0;i<5;i++)
  write_date(temp3);
 write_com(0x9e);//É趨λÖÃΪµÚÒ»ÐеĵÚËÄλ
 for(i=0;i<3;i++)
  write_date(temp4);
 lock();
 while(1);//³ÌÐòÍ£Ö¹
此帖出自51单片机论坛
变量的定义要放在语句之前。数组的定义放在函数外面就可以了吧,为什么放在函数里面呢?  详情 回复 发表于 2012-6-13 20:39
6066
92
裸片初长成(初级)
回复 楼主 fight281 的帖子
这有部分显示是乱码
此帖出自51单片机论坛
202
const,这个不要吧
此帖出自51单片机论坛
3404
裸片初长成(初级)
此帖出自51单片机论坛
