I’ve been thinking about the reason my UART code can’t do 9600 bps communications both ways without losing or corrupting data. If we calculate, two way communication requires handling 2*9600 = 19200 interrupts per second. With the main clock running at 1Mhz, that means 1000000/19200 = 52 clock cycles are available to handle each bit.
Just entering and returning from an interrupt uses 11 clock cycles, leaving only 41 cycles on average for doing work. There just isn’t time to finish up the work of one interrupt when the next interrupt has to occur, and data bits get lost in the receiving code or transmitted too late in the sending code.
The MSP430 value line chips can run at faster clock speeds, but there are no calibration settings recorded in the flash memory for speeds faster than 1 Mhz. However, we can figure out the settings by hand if we we have access to a reliable clock source. If you have the clock crystal soldered to your Launchpad, that will do the trick.
The key new code is the set_dco_c() function, which calibrates and sets the digitally-controlled oscillator (DCO) to change the clock speed. This is the code that requires an external timer crystal, and the next program will not function without one (so don’t bother unless you soldered one to your Launchpad). Cite: this page gave me the idea and the sample code, http://jbremnant.wordpress.com/2011/01/03/nokia-lcd-wiinunchuck-with-msp430/ .
#include
/* Demo UART application. Receives bytes from the computer
* at 9600 bps, and sends the same byte back to the computer.
* This code requires an external clock crystal for calibration
* of 4 Mhz clock speed.
#define RED_LED BIT0
#define GRN_LED BIT6
#define TXD BIT1
#define RXD BIT2
/* Ticks per bit, and ticks per half. Use the following values based on speed:
* 9600 bps -> 52
* 4800 bps -> 104
* 2400 bps -> 208
* 1200 bps -> 416
* I did not have success with slower speeds, like 300 bps.
#define TPB 52
#define TPH TPB/2
unsigned int TXWord = 0;
unsigned char RXByte = 0;
unsigned int rxbitcnt = 0;
unsigned int txbitcnt = 0;
/* a circular buffer to for characters received/to send */
#define BSIZE 16 // must be power of 2
unsigned char buffer[BSIZE];
unsigned int bhead=0, btail=0, bytestosend=0;
/* function prototypes */
unsigned char set_dco_c(unsigned int delta);
void initUart( void );
inline void RX_Start( void );
/* LEDs off, but we can use them for debugging if we want */
P1DIR |= RED_LED+GRN_LED;
P1OUT &= ~ (RED_LED + GRN_LED );
/* set clock speed and initialize the timers and data pins */
initUart();
/* Start listening for data */
RX_Start();
for( ; ; ) {
/* go to sleep and wait for data */
__bis_SR_register( LPM0_bits + GIE );
/* Pass a delta value to set the DCO speed. Values for delta:
* 244 -> 1 MHz 1220 -> 5 Mhz 2197 -> 9 Mhz 3173 -> 13 Mhz
* 488 -> 2 Mhz 1464 -> 6 Mhz 2441 -> 10 Mhz 3417 -> 14 Mhz
* 732 -> 3 Mhz 1708 -> 7 Mhz 2685 -> 11 Mhz 3662 -> 15 Mhz
* 976 -> 4 Mhz 1953 -> 8 Mhz 2929 -> 12 Mhz 3906 -> 16 Mhz
* General formula:
* floor(x hz / 4096) -> delta
* Return values:
* 0 - DCO set
* 255 - Timeout
* Adapted from code by J. B. Remnant.
unsigned char set_dco_c(unsigned int delta) {
unsigned int Compare, Oldcapture = 0;
volatile int i;
/* set auxilliary clock to use /8 divider (requires external crystal) */
BCSCTL1 |= DIVA_3;
/* Timer A0 capture positive edge, select input 1, capture mode */
TACCTL0 = CM_1 + CCIS_1 + CAP;
/* Timer A use submain clock, continuous up mode, clear timer */
TACTL = TASSEL_2 + MC_2 + TACLR; // SMCLK, cont-mode, clear
/* loop 10000 times to set clock */
for ( i = 10000; i; i-- ) {
while (!(CCIFG & TACCTL0)) ; // Wait until capture occurred
TACCTL0 &= ~CCIFG; // Capture occurred, clear flag
Compare = TACCR0; // Get current captured SMCLK
Compare = Compare - Oldcapture; // SMCLK difference
Oldcapture = TACCR0; // Save current captured SMCLK
if (delta == Compare)
break; // If equal, leave the loop
else if (delta < Compare)
DCOCTL--; // DCO is too fast, slow it down
if (DCOCTL == 0xFF) // Did DCO roll under?
if (BCSCTL1 & 0x0f)
BCSCTL1--; // Select lower RSEL
else
DCOCTL++; // DCO is too slow, speed it up
if (DCOCTL == 0x00) // Did DCO roll over?
if ((BCSCTL1 & 0x0f) != 0x0f)
BCSCTL1++; // Sel higher RSEL
/* i>0 means that DCO is set correctly -- set return value accordingly */
Compare = (i) ? 0 : 255;
/* delay loop */
for (i = 0; i < 0x4000; i++) ;
return Compare;
void initUart( void ) {
/* set clock speed to 4 Mhz no divider */
set_dco_c( 976 );
BCSCTL2 &= ~(DIVS_3);
/* Set timer A to use continuous mode 4 Mhz / 8 = 500 khz. */
TACTL = TASSEL_2 + MC_2 + ID_3;
/* When TXD isn't being used, it should be high */
CCTL0 = OUT;
/* TXD and RXD set for timer function, RXD input, TXD output */
P1SEL |= TXD + RXD;
P1DIR &= ~ RXD;
P1DIR |= TXD;
/* This continuously sends bits of the TXWord starting from the
* least significant bit (the 0 start bit). One bit is sent every
* time the handler is activated. When the bits run out, a new
* byte is loaded from the data pointer, until bytestosend equals 0.
void TimerA0 (void) __attribute__((interrupt(TIMERA0_VECTOR)));
void TimerA0(void) {
if( txbitcnt ) {
/* send least significant bit */
if( TXWord & 0x01 ) {
CCTL0 &= ~ OUTMOD2;
} else {
CCTL0 |= OUTMOD2;
TXWord >>= 1;
txbitcnt --;
/* If there are no bits left, load the next byte */
if( !txbitcnt ) {
if( bytestosend ) {
/* load next byte with stop bit 0x100 and shifted left
* to make the start bit */
TXWord = ( 0x100 | buffer[btail++]) << 1;
btail &= BSIZE-1;
bytestosend --;
/* 1 start bit + 8 data bits + 1 stop bit */
txbitcnt = 10;
} else {
/* turn off interrupts if not receiving */
if( ! rxbitcnt ) CCTL0 &= ~ CCIE;
/* add ticks per bit to trigger again on next bit in stream */
CCR0 += TPB;
/* reset the interrupt flag */
CCTL0 &= ~CCIFG;
void TimerA1 (void) __attribute__((interrupt(TIMERA1_VECTOR)));
void TimerA1(void) {
/* If we just caught the 0 start bit, then turn off capture
* mode (it'll be all compares from here forward) and add
* ticks-per-half so we'll catch signals in the middle of
* each bit.
if( CCTL1 & CAP ) {
/* 8 bits pending */
rxbitcnt = 8;
/* next interrupt in 1.5 bits (i.e. in middle of next bit) */
CCR1 += TPH + TPB;
/* reset capture mode and interrupt flag */
CCTL1 &= ~ ( CAP + CCIFG );
/* turn on transmitting also if needed */
if( ! (CCTL0 & CCIE)) {
/* interleave the interrupts, transmit half-bit after receive */
CCR0 = CCR1 + TPH;
CCTL0 = CCIS0 + OUTMOD0 + CCIE;
return;
/* Otherwise we need to catch another bit. We'll shift right
* the currently received data, and add new bits on the left.
RXByte >>= 1;
if( CCTL1 & SCCI ) {
RXByte |= 0x80;
rxbitcnt --;
/* last bit received */
if( ! rxbitcnt ) {
/* Record this byte and reset for next.
* Put character in circular buffer (unless full).
if( bytestosend < BSIZE ) {
buffer[bhead++] = RXByte;
bhead &= BSIZE-1;
bytestosend ++;
/* we're done, reset to capture */
CCTL1 = SCS + OUTMOD0 + CM1 + CAP + CCIE;
return;
CCR1 += TPB;
CCTL1 &= ~CCIFG;
Although the external timer crystal is required to run the calibration routine, if we save the calibration value it wouldn’t need to be determined every time. Altough it will change somewhat with conditions (like voltage or temperature) the fluctuations are probably not important. We could determine the value one time using our Launchpad, and then hard code the calibration value into a program, and the chip would work fine without the crystal.
Since we’ve figured out how to calibrate the MSP 430 value line chips (like the 2211 and 2231) for faster speeds, I thought we should have a program that would let us know what the settings are. That way we can take a particular chip and run it in a context that doesn’t have an external clock.
The next program puts together a lot of the things we’ve learned to this point:
blinking LEDs
triggering interrupts on button presses
serial transmission to the PC via the Launchpad interface
setting and calibrating the MSP 430 clock speed
#include
#include
#define BUTTON BIT3
#define TXD BIT1
#define RXD BIT2
#ifndef CALDCO_16MHZ_
#define CALDCO_16MHZ_ 0x10F8 /* DCOCTL Calibration Data for 16MHz */
const_sfrb(CALDCO_16MHZ, CALDCO_16MHZ_);
#define CALBC1_16MHZ_ 0x10F9 /* BCSCTL1 Calibration Data for 16MHz */
const_sfrb(CALBC1_16MHZ, CALBC1_16MHZ_);
#endif
#ifndef CALDCO_12MHZ_
#define CALDCO_12MHZ_ 0x10FA /* DCOCTL Calibration Data for 12MHz */
const_sfrb(CALDCO_12MHZ, CALDCO_12MHZ_);
#define CALBC1_12MHZ_ 0x10FB /* BCSCTL1 Calibration Data for 12MHz */
const_sfrb(CALBC1_12MHZ, CALBC1_12MHZ_);
#endif
#ifndef CALDCO_8MHZ_
#define CALDCO_8MHZ_ 0x10FC /* DCOCTL Calibration Data for 8MHz */
const_sfrb(CALDCO_8MHZ, CALDCO_8MHZ_);
#define CALBC1_8MHZ_ 0x10FD /* BCSCTL1 Calibration Data for 8MHz */
const_sfrb(CALBC1_8MHZ, CALBC1_8MHZ_);
#endif
* 2400 bps -> 52
#define TPB 52
#define TPH (TPB/2)
unsigned char *data;
unsigned int bytestosend=0;
/* for converting hex values to characters */
unsigned char hex[] = "0123456789ABCDEF";
/* get ready to transmit to the computer */
initUart();
/* turn on red LED so we know calibration is done */
P1OUT |= RED_LED;
/* We'll use the button to let the chip know we're ready to communicate.
* Button direction is receive, clear interrupt flag
P1DIR &= ~BUTTON;
P1IFG &= ~BUTTON;
while( 1 ) {
/* done -- go to sleep and wait for button interrupt to report to PC */
P1IE |= BUTTON;
__bis_SR_register( LPM3_bits + GIE );
P1OUT ^= RED_LED;
report_data();
* General formula:
* Return values:
* 0 - DCO set
* 255 - Timeout
BCSCTL1 |= DIVA_3;
volatile int i;
if (BCSCTL1 & 0x0f)
else
/* delay loop */
return Compare;
/* set up the clocks for 1 mhz */
BCSCTL1 = CALBC1_1MHZ;
DCOCTL = CALDCO_1MHZ;
/* Set timer A to use continuous mode 1 Mhz / 8 = 125 khz. */
TACTL = TASSEL_2 + MC_2 + ID_3 + TACLR;
CCTL0 = OUT;
P1SEL |= TXD + RXD;
P1DIR &= ~ RXD;
P1DIR |= TXD;
if( txbitcnt ) {
CCTL0 &= ~ OUTMOD2;
} else {
CCTL0 |= OUTMOD2;
TXWord >>= 1;
txbitcnt --;
if( !txbitcnt ) {
if( bytestosend ) {
TXWord = ( 0x100 | *data++ ) << 1;
bytestosend --;
txbitcnt = 10;
} else {
/* turn off interrupts */
CCTL0 &= ~ CCIE;
/* wake up the main program */
__bic_SR_register_on_exit( LPM0_bits );
CCR0 += TPB;
CCTL0 &= ~CCIFG;
/* Prepares a block of data to be sent. */
int sendBytes( unsigned char *d, int len ) {
/* can't queue up data if we're still sending */
if( bytestosend > 0 ) return 0;
txbitcnt = 0;
data = d;
bytestosend = len;
/* Make sure we don't catch the TAR register while it is changing.
* As long as the difference is only in the lower bits, we'll call
* it close enough.
do {
CCR0 = TAR;
} while( (CCR0^TAR) > 3 );
/* sleep until message sent */
while( CCTL0 & CCIE ) {
return len;
/* Sends a single byte to the computer */
int sendByte( unsigned char b ) {
return sendBytes( &b, 1 );
/* Sends a string of characters to the computer */
int sendString( char *str ) {
return sendBytes( str, strlen(str) );
/* A button press triggers this interrupt, which wakes
* up the main program to send a message.
void Port_1 (void) __attribute__((interrupt(PORT1_VECTOR)));
void Port_1(void) {
/* clear interrupt flag */
P1IFG &= ~BUTTON;
/* disable button (will be re-enabled in main program) */
P1IE |= BUTTON;
__bic_SR_register_on_exit( LPM3_bits );
sendString( "Stock 16Mhz settings BCSCTL1/DCOCTL:" );
str[2] = hex[( CALBC1_16MHZ>>4 ) & 0x0F];
str[3] = hex[( CALBC1_16MHZ>>0 ) & 0x0F];
str[7] = hex[( CALDCO_16MHZ>>4 ) & 0x0F];
str[8] = hex[( CALDCO_16MHZ>>0 ) & 0x0F];
sendString( str );
sendString( "Derived: " );
str[2] = hex[( calbc1_16mhz>>4 ) & 0x0F];
str[3] = hex[( calbc1_16mhz>>0 ) & 0x0F];
str[7] = hex[( caldco_16mhz>>4 ) & 0x0F];
str[8] = hex[( caldco_16mhz>>0 ) & 0x0F];
sendString( str );
To use the program, compile it for your target chip. Then execute a terminal program, and press Switch 2 on the Launchpad. The commands I used look like this:
$ msp430-gcc -O2 -mmcu=msp430x2211 -o calibrate.elf calibrate.c
$ mspdebug rf2500 "prog calibrate.elf" ; minicom -o -b 2400 -D /dev/ttyACM0
The data I get back from the chip looks something like this:
Stock 1Mhz settings BCSCTL1/DCOCTL:0x86/0xA0
Derived: 0x86/0xA7
Stock 8Mhz settings BCSCTL1/DCOCTL:0x02/0x01
Derived: 0x8C/0xD5
Stock 12Mhz settings BCSCTL1/DCOCTL:0xFF/0xFF
Derived: 0x8E/0x6F
Stock 16Mhz settings BCSCTL1/DCOCTL:0xFF/0xFF
Derived: 0x8E/0xCA
Notice that the Stock settings for 1Mhz, which the program reads from the flash memory, are very close to the Derived settings. I think that is reassuring. For this particular chip, I can set BCSCTL1 and DCOCTL to any of the derived calibration pairs and expect to get a fairly accurate clock speed.
It turned out that the previous calibration program could refuse to settle on a single calibration value. Sometimes it would try one calibration, find it too slow, and speed the oscillator up. But then the next value was too high, so it would slow the oscillator down. Eventually the loop would time out, with no value being set.
To correct it, I added a bit of code to check for direction changes in the oscillator tuning loop. If we change direction 4 times between two consecutive calibration values, that’s close enough. We can return either value and be happy with it.
#include
#include
#define BUTTON BIT3
#define TXD BIT1
#define RXD BIT2
#endif
#endif
#endif
* 2400 bps -> 52
#define TPB 52
#define TPH (TPB/2)
initUart();
P1OUT |= RED_LED;
P1DIR &= ~BUTTON;
P1IFG &= ~BUTTON;
while( 1 ) {
P1IE |= BUTTON;
P1OUT ^= RED_LED;
report_data();
* General formula:
* Return values:
* 0 - DCO set
* 255 - Timeout
int direction=0;
volatile int i;
unsigned char signchg=0;
BCSCTL1 |= DIVA_3;
for ( i = 10000; i && (signchg<3); i-- ) {
if (BCSCTL1 & 0x0f)
if( direction > 0 ) { // catch for successive direction changes
signchg++; // and increment count when one happens
} else {
signchg=0;
direction = -1;
else
if( direction < 0 ) { // catch for successive direction changes
} else {
signchg=0;
direction = +1;
/* delay loop */
return Compare;
CCTL0 = OUT;
P1SEL |= TXD + RXD;
P1DIR &= ~ RXD;
P1DIR |= TXD;
if( txbitcnt ) {
CCTL0 &= ~ OUTMOD2;
} else {
CCTL0 |= OUTMOD2;
TXWord >>= 1;
txbitcnt --;
if( !txbitcnt ) {
if( bytestosend ) {
bytestosend --;
txbitcnt = 10;
} else {
CCTL0 &= ~ CCIE;
CCR0 += TPB;
CCTL0 &= ~CCIFG;
txbitcnt = 0;
data = d;
bytestosend = len;
* it close enough.
do {
CCR0 = TAR;
return len;
void Port_1(void) {
P1IFG &= ~BUTTON;
P1IE |= BUTTON;
I’ve started re-implementing the TI temperature demo, both to make it compile with mspgcc4, and to enhance and embellish the comments in the code. Hopefully, beginners will find it easier to understand with more copious comments, especially if they can see it implemented bit by bit.
It’s sort of a long process, so I’ve devoted a separate page to it: demo.html
MSP430 Launchpad Demo Program
Don Bindner
Table of Contents
1. Startup mode
2. Entering Application Mode
3. Communication With the Computer
4. Internal temperature sensor
Personally, I found the TI MSP430 Launchpad demo code a little daunting on first read. It’s easier and more readable than a lot of the demo code I’ve found for the MSP430, but I bet there are a lot of people who still find it difficult. I decided I would devote a page to building up the TI demo part by part in such a way that a beginner could watch the it being created.
This code is for the MSP430g2231 chip with the internal temperature sensor.
This page is a companion page for my MSP430 Launchpad page.
1. Startup mode
When the MSP430 powers up, it blinks the LEDs to let the user know that the device is alive. The key functions are PreApplicationMode() which sets up Timer A1 to generate an interrupt every 1/5 second, and t1a_isr() which handles the interrupt and toggles the LEDs. The chip spends almost all of its time sleeping in low power mode 3 (which is entered right at the end of PreApplicationMode()).
/* the mode the chip initially enters to blink the LEDs */
void PreApplicationMode(void) {
/* Set both LED pins as output pins and turn red on, green off */
P1DIR |= RED_LED + GRN_LED;
P1OUT |= RED_LED;
P1OUT &= ~GRN_LED;
/* The basic clock system control register 3 controls the oscillator
* the auxilliary clock uses. Change ACLK from external timer crystal
* oscillator to internal very low-power oscillator (VLO) clock,
* which runs at appoximately 12kHz.
BCSCTL3 |= LFXT1S_2;
/* Basic clock system control register 1 controls the auxilliary clock
* divider. Set ACLK to use Divider 1, i.e. divided by 2^1. */
BCSCTL1 |= DIVA_1;
/* Set TimerA counter period to 1200 or about 1/5 second */
TACCR0 = 1200;
/* Set TimerA to use auxilliary clock TASSEL_1 and count up mode MC_1 */
TACTL = TASSEL_1 | MC_1;
/* Set capture/compare mode interrupts enabled, to trigger an interrupt
* when TACCR1 is reached. OUTMOD_3 not essential here? */
TACCTL1 = CCIE + OUTMOD_3;
/* The value at which TimerA1 interrupt triggers. */
TACCR1 = 600;
/* Go to sleep in low power mode 3 with interrupts enabled. */
__bis_SR_register(LPM3_bits + GIE);
/* Timer A interrupt service routine 1. The function prototype
* tells the compiler that this will service the Timer A1 interrupt,
* and then the function follows.
void ta1_isr(void) __attribute__((interrupt(TIMERA1_VECTOR)));
void ta1_isr(void)
/* clear the interrupt flag */
TACCTL1 &= ~CCIFG;
/* in application mode, we'll turn off the LEDs, otherwise we'll
* toggle them.
if (applicationMode == APP_APPLICATION_MODE)
P1OUT &= ~(RED_LED + GRN_LED);
else
P1OUT ^= (RED_LED + GRN_LED);
/************** main program begins here ***************/
void main( void ) {
/* access the watchdog timer control without password and hold
* the count (so the watchdog timer doesn't reset the chip)
WDTCTL = WDTPW + WDTHOLD;
This version adds a way to get into the application mode of the program by pressing switch 2. Because of the check in ta1_isr() this will cause the LEDs to go dark. The key new functions are InitializeButton() which configures the button to trigger interrupts, PORT1_ISR() which is triggered by button presses, and WDT_ISR() which is used to handle button bounce in software.
Debouncing is handled in a very clever way. When the button interrupt is triggered, that service handler disables future button interrupts to prevent spurious extra "bounce presses." It then sets the Watchdog timer to wait one quarter second and execute the timer Watchdog interrupt. The Watchdog interrupt service handler then turns the button interrupts back on.
The neat thing is that the program doesn’t have to stop or delay for any of this to work. In effect we just schedule the button to start working again 681 milliseconds in the future and an interrupt will fire automatically when the time comes to make that happen.
P1OUT |= RED_LED;
P1OUT &= ~GRN_LED;
BCSCTL1 |= DIVA_1;
TACCR0 = 1200;
TACCR1 = 600;
void ta1_isr(void)
TACCTL1 &= ~CCIFG;
* toggle them.
else
/* This function configures the button so it will trigger interrupts
* when pressed. Those interrupts will be handled by PORT1_ISR() */
void InitializeButton(void) {
/* Set button pin as an input pin */
P1DIR &= ~BUTTON;
/* set pull up resistor on for button */
P1OUT |= BUTTON;
/* enable pull up resistor for button to keep pin high until pressed */
P1REN |= BUTTON;
/* Interrupt should trigger from high (unpressed) to low (pressed) */
P1IES |= BUTTON;
/* Clear the interrupt flag for the button */
P1IFG &= ~BUTTON;
/* Enable interrupts on port 1 for the button */
P1IE |= BUTTON;
* Port Interrupt for Button Press
* 1. During standby mode: to exit and enter application mode
* 2. During application mode: to recalibrate temp sensor
void PORT1_ISR(void) __attribute__((interrupt(PORT1_VECTOR)));
/* clear interrupt flag for port 1 */
P1IFG = 0;
/* disable interrupts for the button to handle button bounce */
P1IE &= ~BUTTON;
/* set watchdog timer to trigger every 681 milliseconds -- normally
* this would be 250 ms, but the VLO is slower
WDTCTL = WDT_ADLY_250;
/* clear watchdog timer interrupt flag */
IFG1 &= ~WDTIFG;
/* enable watchdog timer interrupts; in 681 ms the button
* will be re-enabled by WDT_ISR() -- program will continue in
* the meantime.
IE1 |= WDTIE;
if (applicationMode == APP_APPLICATION_MODE) {
// tempCalibrated = tempAverage;
// calibrateUpdate = 1;
} else {
/* switch to APPLICATION MODE */
applicationMode = APP_APPLICATION_MODE;
/* clear the low power mode bit, so when we return from
* the interrupt call, the program will resume running
__bic_SR_register_on_exit(LPM3_bits);
/* This function catches watchdog timer interrupts, which are
* set to happen 681ms after the user presses the button. The
* button has had time to "bounce" and we can turn the button
* interrupts back on.
void WDT_ISR(void) __attribute__((interrupt(WDT_VECTOR)));
void WDT_ISR(void)
/* Disable interrupts on the watchdog timer */
IE1 &= ~WDTIE;
/* clear the interrupt flag for watchdog timer */
IFG1 &= ~WDTIFG;
/* resume holding the watchdog timer so it doesn't reset the chip */
/* and re-enable interrupts for the button */
P1IE |= BUTTON;
void main( void ) {
InitializeButton();
PreApplicationMode();
The MSP430 doesn’t just blink lights in this demo. It also communicates the internal chip temperature back to the computer. We haven’t yet written any code to measure temperature, but we can frame in the code for communicating with the computer.
After the clock oscillators are calibrated with InitializeClocks(), communication is handled by three functions: ConfigureTimerUart() which setups up TimerA0, Transmit() which queues up a particular transmission, and Timer_A() which actually does the communication.
/* Conditions for 2400 Baud SW UART, SMCLK = 1MHz, divider 8
* (1 Mhz/8) / 2400 bps = 52 clock cycles per bit
#define Bitime_5 20 // ~ clock ticks per half bit
#define Bitime 52 // clock ticks per bit
#define UART_UPDATE_INTERVAL 1000
unsigned char BitCnt;
unsigned int TXByte;
unsigned char applicationMode = APP_STANDBY_MODE;
unsigned char timerMode = TIMER_PWM_MODE;
P1OUT |= RED_LED;
P1OUT &= ~GRN_LED;
BCSCTL1 |= DIVA_1;
TACCR0 = 1200;
TACCR1 = 600;
void InitializeClocks(void) {
/* Use calibration values to set digitally controlled oscillator
* to 1 mhz, and set the submain clock to the same (i.e. we turn
* off the /8 divider bit).
void ConfigureTimerUart(void) {
/* This flag tells us that we're using the timer for communcation
* rather than pulse width modulation.
timerMode = TIMER_UART_MODE;
/* Set transmission pin high for now (until we later set it low
* to start communication). */
CCTL0 = OUT;
/* TimerA is using submain clock (at 1mhz), in continuous mode,
* with a clock divider of 2^3=8
/* Set transmit and receive pins latched to the timer, and the
* transmit pin is set as an output pin.
P1SEL |= TXD + RXD;
P1DIR |= TXD;
void Transmit() {
/* Function Transmits Character from TXByte. We'll have 10 bits total
* to communicate, 8 bits of data plus a start bit (zero) and a
* stop bit (one).
BitCnt = 10;
* it close enough.
do {
CCR0 = TAR;
/* Set time when the transmission will actually begin */
CCR0 += Bitime;
/* Add a one bit to act as stop bit (least significant bits in the TXByte get sent first) */
TXByte |= 0x100;
/* Shift left to make an initial zero bit to act as start bit */
TXByte = TXByte << 1;
/* Timer A0 to start triggering interrupts to do the actual sending */
/* We'll loop and wait for the transmission to finish */
while ( CCTL0 & CCIE ) ;
// Timer A0 interrupt service routine
void Timer_A(void) __attribute__((interrupt(TIMERA0_VECTOR)));
void Timer_A(void) {
if (timerMode == TIMER_UART_MODE) {
/* schedule when the next bit is communicated */
CCR0 += Bitime;
/* If the transmission bit is set */
if (CCTL0 & CCIS0) {
/* Are there bits left to be transmitted? */
if ( BitCnt == 0) {
/* No, disable the interrupt. We're done. */
CCTL0 &= ~ CCIE;
} else {
/* If the next bit is a one, set pin high/mark */
if (TXByte & 0x01) {
CCTL0 &= ~ OUTMOD2;
} else {/* Otherwise set pin low/space */
CCTL0 |= OUTMOD2;
/* Shift right to drop the bit we just sent, and update the count. */
TXByte = TXByte >> 1;
BitCnt --;
} else {
// if (tempPolarity == TEMP_HOT)
// LED_OUT |= LED1;
// if (tempPolarity == TEMP_COLD)
// LED_OUT |= LED0;
/* Clear the interrupt flag */
TACCTL0 &= ~CCIFG;
void ta1_isr(void)
TACCTL1 &= ~CCIFG;
* toggle them.
} else {
P1DIR &= ~BUTTON;
P1OUT |= BUTTON;
P1REN |= BUTTON;
P1IES |= BUTTON;
P1IFG &= ~BUTTON;
P1IE |= BUTTON;
P1IFG = 0;
P1IE &= ~BUTTON;
IFG1 &= ~WDTIFG;
* the meantime.
IE1 |= WDTIE;
} else {
void WDT_ISR(void)
IE1 &= ~WDTIE;
IFG1 &= ~WDTIFG;
P1IE |= BUTTON;
void main( void ) {
for( ; ; ) {
ConfigureTimerUart();
TXByte = '.'; // for testing
Transmit();
To use this program, I typed:
$ mspdebug rf2500 exit ; minicom -b 2400 -o -D /dev/ttyACM0
Pressing Switch 2 shows me a series of dots, i.e. period characters. The reset button on the Launchpad stops it.
This code contains two new functions, ConfigureAdcTempSensor() and ADC10_ISR(). The first function configures the analogue to digital converter to use the internal temperature sensor and takes a reading. It’s important to know that ADC conversions are not instantaneous. Effectively, you have to schedule a temperature reading and then wait for it to occur. That’s what the ADC10_ISR() function is for. It responds to the interrupt that occurs when a new value is ready and wakes up the main program.
Eventually, the program will keep a history of temperature values so it can compute a moving average, but for now we just read in a single value and use our Transmit() code to send it back as a byte to the PC. If your room is a reasonable temperature (at least 65F) you should see upper case letters.
/* We'll keep a history of 8 temperature measurements from the ADC
* and calculate a moving average.
long tempMeasured[8];
unsigned char tempMeasuredPosition=0;
long tempAverage;
long tempCalibrated, tempDifference;
P1OUT |= RED_LED;
P1OUT &= ~GRN_LED;
BCSCTL1 |= DIVA_1;
TACCR0 = 1200;
TACCR1 = 600;
void ConfigureAdcTempSensor(void) {
volatile unsigned int i;
/* Configure ADC input channel 10 (i.e. the temperature sensor)
* with clock divider /4
ADC10CTL1 = INCH_10 + ADC10DIV_3;
/* not sure what these mean */
ADC10CTL0 = SREF_1 + ADC10SHT_3 + REFON + ADC10ON + ADC10IE;
/* A delay loop for ADC reference to settle */
for( i = 0; i < 500; i++ ) ;
/* Enable ADC conversion and set it to start conversion */
ADC10CTL0 |= ENC + ADC10SC;
/* Sleep in LPM0 until the conversion is ready */
__bis_SR_register(LPM0_bits + GIE);
/* Read off the temperature raw value */
tempCalibrated = ADC10MEM;
/* We'll keep a history of temperatures to compute a moving average,
* but for now they're all initialized to this starting temp. So
* is the average temperature.
for (i=0; i < 8; i++)
tempMeasured = tempCalibrated;
tempAverage = tempCalibrated;
CCTL0 = OUT;
P1SEL |= TXD + RXD;
P1DIR |= TXD;
void Transmit() {
* stop bit (one).
BitCnt = 10;
* it close enough.
do {
CCR0 = TAR;
CCR0 += Bitime;
TXByte |= 0x100;
CCR0 += Bitime;
if ( BitCnt == 0) {
CCTL0 &= ~ CCIE;
} else {
CCTL0 &= ~ OUTMOD2;
CCTL0 |= OUTMOD2;
BitCnt --;
} else {
// LED_OUT |= LED1;
// LED_OUT |= LED0;
TACCTL0 &= ~CCIFG;
void ta1_isr(void)
TACCTL1 &= ~CCIFG;
* toggle them.
} else {
P1DIR &= ~BUTTON;
P1OUT |= BUTTON;
P1REN |= BUTTON;
P1IES |= BUTTON;
P1IFG &= ~BUTTON;
P1IE |= BUTTON;
P1IFG = 0;
P1IE &= ~BUTTON;
IFG1 &= ~WDTIFG;
* the meantime.
IE1 |= WDTIE;
} else {
void WDT_ISR(void)
IE1 &= ~WDTIE;
IFG1 &= ~WDTIFG;
P1IE |= BUTTON;
/* This function catches interrupts from the analogue to digital
* controller (ADC), which fire after a temperature has been sampled.
* Each time we sample, we sleep until ready, so all this routine
* has to do is wake the program back up.
void ADC10_ISR(void) __attribute__((interrupt(ADC10_VECTOR)));
__bic_SR_register_on_exit(LPM0_bits);
void main( void ) {
/* This conversion formula is magic! */
TXByte = (unsigned char)( ((tempAverage - 630) * 761) / 1024 );
Transmit();
Pressing Switch 2 shows me a series of C characters because my room is 67F. The reset button on the Launchpad stops it.
I wanted to use an LCD panel that does I2C communication (and that means I needed to learn about I2C). So I decided to write a bit-bang I2C master program for my Launchpad to display messages on my Newhaven C0220BIZ-FS(RGB)-FBW-3VM LCD panel.
I’m not sure how detailed I intend to be, so I’ve broken the experiment out into its own page: lcd_i2c.html
I2C communications with Newhaven LCD Panel
Don Bindner
Table of Contents
1. I2C communications
2. Wiring up the LCD panel
3. A first I2C program
3.1. I2C discussion
3.2. LCD panel functions
3.3. LCD contrast
4. I2C Multi-master
5. A multi-master I2C bit-banger
6. Messages in memory
6.1. Adding a memory chip
6.2. LCD changes
6.3. I2C changes
7. Capacitive Touch
As part of a project with a student, I wanted to get my MSP430 to talk to a relatively inexpensive LCD panel. I chose the Newhaven C0220BIZ-FS(RGB)-FBW-3VM panel, which communicates via an I2C interface. It is a 3.3v part (except the red backlight which wants less), which makes it a natural fit for the MSP430.
We bought our Newhaven displays from Jameco for $11.95 each: Item # 2118539 You may want to pick up at least one 1uF capacitor, and three 10K ohm resistors at the same time (two for the I2C lines, and one for the reset pin).
The pins of the Newhaven LCD are not set at a standard 0.1" (2.54mm) spacing. I had to gently spread the pins apart to fit the LCD to standard perf board. Basically, I angled a few pins into the perf board at one edge, wiggling slightly to bend the pins as I worked more and more into the holes. You also can’t see the fat pins that run the backlight are hanging off the side of the board, since they don’t fit either.
The I2C communications protocol is a method of doing serial communications that overcomes one of the inherent problems with typical UART serial methods, that of synchronizing the data rate at both ends. (With standard serial communications, you have to be careful to set the same baud rate for the transmitter and receiver, or the communication will fail.)
Only 2 wires are required for I2C communication (plus the power and ground connections), a "data" line and a "clock" line. That is very nice for a microcontroller, like the MSP430, which has a limited number of I/O pins.
The general idea of the communication is easy to understand: a master device puts data on the data line one bit at a time, most significant bit first, and pulses the clock line. Slave devices read the data bits during the pulses. Exact timing is not essential because slaves adapt to whatever speed the master pulses the clock line.
For detailed information about I2C, the Wikipedia page is very good, http://en.wikipedia.org/wiki/I%C2%B2C. The data sheet for the LCD panel also has some relatively simple example code that is a big help. You’ll definitely be wanting to read the data sheet for details on the panel!
When looking at the front of the LCD panel, pin 1 is on the right and pin 8 is on the left (page 4 of the data sheet shows the physical diagram). According to the data sheet, you should connect pins 7 and 8 with a 1uF capacitor. You’ll also want to connect pin 6 via a 1uF capacitor to ground (for example, pin 4).
For the code that follows, I made these connections to my MSP430 Launchpad:
LCD pin 1 (RST) to MSP430 pin 1.3 (the pin that switch S2 is on).
LCD pin 2 (SCL) to MSP430 pin 1.6 (the pin with the green LED).
LCD pin 3 (SDA) to MSP430 pin 1.0 (the pin with the red LED).
LCD pin 4 (VSS) to MSP430 ground.
LCD pin 5 (VDD) to MSP430 Vcc/power.
LCD pins 1, 2, and 3 require pull-up resistors, and two of these are shown on the data sheet. (The reset pin also needs to be pulled up since the data sheet describes it as "active low," and we don’t want the reset button continuously "pushed" because we forgot to wire it up. Nothing will work.)
We can use the internal pull-up resistors in the MSP430, so we won’t need external resistors, but I found physical resistors to be more reliable. On the Launchpad, switch S2 has a pull-up resistor on it already, so that connection is covered. But, I connected 10K ohm resistors between Vcc/power and LCD pins 2 and 3.
Because the clock and data lines are connected to the same pins as the red and green LEDs on the Launchpad, we’ll be able to observe the data communication visually. Later, if we wish, we can remove the jumpers to disconnect the LEDs or switch to different pins on the MSP430.
If you choose instead to modify the code to use the internal pull-up resistors in the MSP430, then you may not be able to watch the LEDs and have the panel actually work at the same time. I had to remove the jumpers (after verifying that the LEDs light up) to get the communication to work.
Since we connected the reset pin of the panel to MSP430 pin 1.3, we can reset the panel as we wish by pressing switch S2. We could also have the microcontroller trigger a reset by outputting a 0 on pin 1.3.
#include
#define I2C_SDA BIT0 // Serial Data line
#define I2C_SCL BIT6 // Serial Clock line
/* A crude delay function. Tune by changing the counter value. */
void delay( unsigned int n ) {
volatile int i;
for( ; n; n-- ) {
for( i = 0; i < 50; i++ );
void data_read(void ) {
P1DIR &= ~I2C_SDA; // float to get ready to read
void data_high(void ) {
P1DIR &= ~I2C_SDA; // float pin to go high
delay( 5 );
/* I2C communication starts when both the data and clock
* lines go low, in that order. */
void I2C_Start(void) {
clk_high();
data_high();
data_low();
clk_low();
/* I2C communication stops with both the clock and data
* lines going high, in that order. */
void I2C_Stop(void) {
data_low();
clk_low();
clk_high();
data_high();
/* Outputs 8-bit command or data via I2C lines. */
void I2C_out(unsigned char d) {
int n;
for( n = 0; n < 8; n++ ) {
if( d & 0x80 ) {
data_high();
} else {
data_low();
clk_high();
clk_low();
d <<= 1; // Shift next bit into position.
data_read(); // Set data line to receive.
clk_high(); // Clock goes high to wait for acknowledge.
// Slave will pull data line low to acknowledge.
while( P1IN & I2C_SDA ) {
// Else toggle the clock line and check again
clk_low();
clk_high();
clk_low();
/* Initializes the LCD panel. */
void init_LCD(void) {
I2C_Start();
I2C_out( 0x78 ); // Slave address of the LCD panel.
I2C_out( 0x00 ); // Control byte: all following bytes are commands.
I2C_out( 0x38 ); // 8-bit bus, 2-line display, normal instruction mode.
delay( 10 );
__bis_SR_register( LPM3_bits ); /* go to sleep */
To compile and install:
> msp430-gcc -O2 -mmcu=msp430x2211 -o lcddemo.elf lcddemo.c && mspdebug rf2500 "prog lcddemo.elf"
If you power cycle the Launchpad (and the LCD, since they’re connected) the program will fail initially to communicate with the panel. That is because the Start condition is set by the MSP430 before the panel is ready to detect it. Simply press switch S1 (the Launchpad reset) to restart the program, and everything will work.
3.1. I2C discussion
Most of the program should be relatively easy to understand. For this first program, we used a crude delay loop for timing. If you want to slow the timing down, increase the value of the counter in delay(). This will allow you to see, and even count if you wish, the communication bits and the clock pulses on the red and green LEDs of the Launchpad board.
The data_high() and data_low() functions cause a 1 or 0 to be put on the data line. Only the 0, however, is an actively driven value. To put a 1 on the line, we set the pin (which is pin 1.0) to be an input pin, effectively letting it "float." The pull-up resistor then takes care of raising the value to 1.
The clk_high() and clk_low() functions work the same way. We either set pin 1.6 as an output pin and put a 0 on it to drive it low, or we set it as an input pin and let it be pulled high.
In this application, with a single master and a single slave, there would be no harm to actively setting the clock line to both 1 and 0. In multi-slave and multi-master situations, we would need to be more careful about our manipulation of the clock line (and the data line too). The Wikipedia page on I2C has more details.
The I2C_Start() function begins each communication. Slaves will know a communication is beginning when the data line transitions from high to low while the clock line is high. (During communication, data line transitions only occur when the clock line is low.) In I2C_Stop() it is the transition of the data line from low to high when the clock line is high that signals the end of the communication.
The I2C_out() function transmits a single 8-bit byte of values on the data line. Then it waits for an acknowledgement from the slave device (the LCD panel). According to the I2C standard, the master should let the data line float and set the clock line high. When the slave is ready to continue, it will acknowledge the byte by pulling the data line low, which will break (or skip) the while loop in our program.
If your LCD panel is not responding correctly, perhaps because it is miswired or has a different slave address, your program will hang in the while loop. You’ll be able to see this, since the pattern of blinking on the LEDs on the Launchpad will change character (becoming very uniform and continuing forever).
The init_LCD() code is pulled straight from the Newhaven data sheet, though some comments have been added about what each byte/command does. It needs to be the first thing your program communicates to the LCD.
The clear_display() function gives an example of sending a single command to the LCD.
The show() function copies data sequentially to the RAM of the panel, and assumes it has been called with strings of length 20.
The memory configuration of the LCD panel is worth discussing. This 2-line LCD display has an 80 byte memory (so more memory than can appear on the display). The first 20 bytes of RAM are the characters that show on the first line of the 2-line display. The next 20 bytes of RAM exist off-screen to the right of the first line.
That means that the second line of the display actually fills RAM location 40-59, which is probably not what you would naively expect. Finally, at location 60 there are another 20 characters of off-screen data that exists to the right of the second line.
Here is an example:
clear_display();
show( "Hello, world. " ); // shows on line 1
show( "12345678901234567890" ); // hidden to the right of line 1
show( "Goodbye, world. " ); // shows on line 2
show( "12345678901234567890" ); // hidden to the right of line 2
show( "Oh, hello again. " ); // replaces/shows on line 1
There are commands for scrolling the screen to the left and right to show the "hidden" off-screen text.
3.3. LCD contrast
My LCD panel had the contrast set too high by default, and I could not read my hello world text (it looked instead like two rows of filled black boxes). I found that I could modify the contrast by placing a resistor between Vout (LCD pin 6) and Vdd/Vcc (power). I found 3900 ohms to work well. I have no idea if this is recommended or not, and I plan to experiment with changing the contrast via commands to the panel instead. So, perhaps I can remove this resistor.
4. I2C Multi-master
The I2C protocol allows for multiple masters and multiple slaves to be on the serial bus at once. Each master needs to watch the bus, so it doesn’t initiate communications while another master is already active. We can use interrupts to watch for changes in the data line corresponding to Start and Stop conditions.
Before writing a fully-fledged multi-master capable program, we’ll start first with a short program that detects the start and stop conditions and shows it with LEDs. This program uses pins 1.4 and 1.5 for the data and clock lines to leave free pins 1.0 (red LED) and 1.6 (green LED).
#include
#define I2C_SDA BIT4 // Data line
#define I2C_SCL BIT5 // Clock line
/* This flag is set if another master is controlling the bus */
int other_master = 0;
/* Catch rising or falling edges of the data line, to check for
* Start and Stop condition (and sometimes just other traffic). */
void Port_1(void) {
int status = P1IN;
/* if clock line is high, then this was Start or Stop */
if( status & I2C_SCL ) {
/* if data line fell, then this is a Start */
if( ( status & I2C_SDA ) == 0) {
other_master = 1;
P1OUT |= BIT0; // red on
} else { /* this is a Stop */
other_master = 0;
P1OUT &= ~BIT0; // red off
/* Stop the watchdog timer so it doesn't reset our chip */
P1DIR |= BIT0 + BIT6; // status lights are output pins
P1OUT &= ~(BIT0 + BIT6); // start off
// Enable interrupts on the data line (dropping edge)
P1IES |= I2C_SDA; // dropping edge
P1IFG &= ~I2C_SDA; // clear the interrupt flag
P1IE |= I2C_SDA; // enable interrupt
__bis_SR_register( GIE ); /* general interrupts enabled */
while( 1 ) {
/* While we're waiting for interrupts, we'll blink the
* green light to show changes in the data line. */
if( P1IN & I2C_SDA ) {
P1OUT |= BIT6; /* green on */
} else {
P1OUT &= ~BIT6; /* green off */
Build and install with:
This code implements a multi-master I2C interface via bit-banging. That is, it is an I2C master that watches the serial bus for activity from other masters and waits its turn to communicate. It can also detect when another master starts communicating simultaneously (and drops out to let the other master continue).
#include
int we_are_master = 0;
/* A crude delay function. Tune by changing the constant. */
inline void delay( unsigned int n ) {
volatile unsigned int i = n<<2;
while( i-- ) ;
inline void data_read(void ) {
inline void data_high(void ) {
delay( 5 );
void Port_1(void) {
int status = P1IN;
/* If both lines are high, we just saw a Stop condition.
* Otherwise, another master has the bus. */
if(( status & I2C_SCL ) && (status & I2C_SDA )) {
other_master = 0;
P1OUT |= BIT6; // green light on
P1OUT &= ~BIT0; // red light off
P1IES |= I2C_SDA; // catch next fall
} else {
other_master = 1;
P1OUT &= ~BIT6; // green light off
P1IES &= ~I2C_SDA; // catch next rise
P1IFG &= ~I2C_SDA; /* clear interrupt flag */
/* If we discover another master on the bus while we are communicating,
* we need to abort our communication and watch for Stop condition
* before continuing. */
inline void lost_arbitration() {
other_master = 1;
P1OUT ^= BIT0+BIT6; // toggle red on and green off
if( other_master ) return;
clk_high();
data_high();
if( data_pulled_down()) { // someone else has the bus
lost_arbitration();
return;
/* stop processing data line interrupts */
P1IE &= ~I2C_SDA;
data_low();
clk_low();
we_are_master = 1;
if( ! we_are_master ) return;
data_low();
clk_low();
/* Resume watching for Start condition (falling data edge). */
P1IES |= I2C_SDA;
P1IE |= I2C_SDA;
P1IFG &= ~I2C_SDA;
clk_high();
data_high();
we_are_master = 0;
int n;
if( d & 0x80 ) {
data_high();
clk_high();
/* If the line is 0, some other master is
* controlling the line, and we should drop out. */
lost_arbitration();
return;
} else {
data_low();
clk_high();
clk_low();
int i = 20;
clk_low();
clk_high();
I2C_Start();
delay( 10 );
I2C_out( 0x14 ); // Bias set to 1/5.
I2C_out( 0x78 ); // Contrast set.
I2C_out( 0x5E ); // Icon display on, booster on, contrast set.
I2C_out( 0x6D ); // Follower circuit on, amplifier=1?
I2C_out( 0x0C ); // Display on, cursor off.
I2C_out( 0x01 ); // Clear display.
I2C_out( 0x06 ); // Entry mode set to cursor-moves-right.
delay( 10 );
I2C_Stop();
/* Sends the "clear display" command to the LCD. */
void clear_display(void) {
I2C_Start();
I2C_out( 0x78 ); // Slave address of panel.
I2C_Stop();
/* Writes a 40-char string to the RAM of the LCD. */
void show40( unsigned char *text ) {
int n;
I2C_Start();
I2C_out( 0x40 ); // Control byte: data bytes follow, data is RAM data.
for( n = 0; n < 40; n++ ) {
I2C_out( *text++ );
I2C_Stop();
int main(void) {
int i;
/* Only output lines are the lights, which start green on, red off */
/* Data and clock lines are read pins that go low when set for output */
P1DIR &= ~(I2C_SDA + I2C_SCL);
P1OUT &= ~( I2C_SDA + I2C_SCL );
/* We use an interrupt handler to detect start/stop conditions,
* and some arbitration errors. */
P1OUT |= BIT6; // green on to show bus clear
P1IES |= I2C_SDA; // trigger on falling edge
} else {
P1OUT &= ~BIT6; // off to show someone on the bus
P1IES &= ~I2C_SDA; // trigger on rising edge
P1IFG &= ~I2C_SDA; // clear interrupt flag
__bis_SR_register( GIE ); // general interrupt enable
delay(400);
init_LCD();
delay(99);
#if 1
srand(100);
while( 1 ) {
show40( "1 1 1 1 1 1-1-1-1-1-----------" );
delay( rand()%9 );
show40( "1+1+1+1+1+++++++++++1*1*1*1*1***********" );
delay( rand()%9 );
show40( "1/1/1/1/1///////////1=1=1=1=1===========" );
delay( rand()%9 );
#else
srand(200);
while( 1 ) {
show40( " 2 2 2 2 2 -2-2-2-2-2----------" );
delay( rand()%9 );
show40( "+2+2+2+2+2++++++++++*2*2*2*2*2**********" );
delay( rand()%9 );
show40( "/2/2/2/2/2//////////=2=2=2=2=2==========" );
delay( rand()%9 );
#endif
There’s a fair bit of new stuff in this program. One small addition right at the beginning is in clk_high(). After the clock line is raised, a loop checks to ensure that another device is not still holding the clock line low, and waits for the other device to let go. This allows slower devices to invoke "clock stretching," effectively slowing down the interface. The loop eventually times out, but the duration can be tuned if necessary by changing the number of iterations of the loop.
The Port1 interrupt handler is used to detect when another master has control of the bus. It is somewhat modified from the monitor program. The main change is a logical reorganization, based on the premise that we can divide events into two types, either the Stop condition has been triggered, or another master has the bus. There is no need to distinguish a Start from any other kind of active use of the bus.
The lost_arbitration() function exists for situations where we thought we were the sole master on the serial bus and then discovered that another master is also using the bus. In every case, this is discovered when the data line has been pulled low while we expected it to be high. This function resets the global flags and interrupts, so we can wait for the bus to become free.
The I2C_Start() and I2C_Stop() functions are only slightly changed. Each makes appropriate changes to the interrupt handling behavior and global variables, reflecting that we are taking control of or releasing the bus. The start function checks for arbitration losses.
Similarly, the I2C_out() function checks after every 1 (high) bit to make sure another master is not pulling the data line low. We relinquish the bus if there is such a conflict. The ACK check is also slightly modified to specifically invoke the Stop condition in the case of a timeout of the loop.
None of the other changes are related to I2C. The show40() routine was modified to write an entire line of the LCD (even the invisible right half of the display). And the main() method was divided into separate ifdef divided sections to make it easier to rebuild the program for two different Launchpads connected together. Buy putting different strings on each chip, we can tell which one is successfully communicating with the LCD. Change the 1 to a 0 to build the alternative program.
msp430-gcc -O2 -mmcu=msp430x2211 -o lcddemo2.elf lcddemo2.c && mspdebug rf2500 "prog lcddemo2.elf"
Each board will light the green LED when it believes the bus is free to use (or when it is actually acting as the master). When the program detects that another device is on the bus, the green LED goes out.
If a program is communicating with the bus and loses arbitration, then the green light will toggle off and the red light will come on. This will last until a stop condition is detected. At that point, the red light goes off and the green comes back on.
This code is pretty reliable, but I found it was rare yet possible for both programs to relinquish the bus with an arbitration error (presumably the LCD panel did something), and then a dead-lock condition occurs with everyone waiting on everyone else. For most reliable operation, there is probably just enough room on the 2K ROM to add a timeout handler and reset things. If no activity has been detected in several seconds after an error, then it’s probably safe to resume. (We may need to trigger the reset pin of the LCD and send another initialization sequence.)
Here’s a picture of 3 Launchpads running this code. There are a few extra wires not strictly required to make it go. For convenience, I connected all of the S1 switches together and all of the S2 switches together (so I could reset the boards simultaneous or reset the LCD by pushing the switches on any board). Notice that the green light is lit on the second board (because it was controlling the bus), and if you look at the LCD, you can see that the second row was caught by the camera just as it was changing to 2s.
I have an idea to make a little sign that scrolls between different messages. So far, my I2C code uses almost all of the 2K Flash memory of my MSP430 chips, which doesn’t leave much room for messages. You can check the size of an MSP430 binary with the msp430-size utility, like this:
c$ msp430-size lcddemo2.elf
text data bss dec hex filename
1964 4 4 1972 7b4 lcddemo2.elf
To hold my messages, I intend to use a Microchip brand 24LC512-I/P Flash chip. It can hold 512 kilobits of data (or 512÷8=64 kilobytes) in pages of 128 bytes. You read and write data from the chip using the I2C protocol, so I can re-use the I2c code that I already have.
I ordered mine from Newark, part # 62K0581. Sparkfun also has a 256kb version at the time of this writing.
Compared to the LCD panel, I found the memory chip very simple to wire up. There are 8 pins. Pin 4 is Vss and is connected to ground. Diagonally opposite, pin 8 is Vcc and connected to power.
Pins 1, 2, and 3 are used to specify 3 bits of the memory chip’s I2C address (so you can configure up to 8 different memory chips on the same bus). The data sheet simply stated that each should be "tied" to Vcc or Vss to set a single 1 or 0. It did not say whether a resistor was required, but it didn’t seem to hurt. I connected all three pins, together with the write protect pin (pin 7) through a 10K ohm resister to ground.
Finally, pin 5 is SDA, which I connected to the SDA of the microcontroller and the LCD. And pin 6 is SCL, which I connected to the SCL of the microcontroller and the LCD. The master on the I2C bus will be the MSP430, and it will have two slaves.
6.2. LCD changes
I went back to the data sheet to learn how to control the contrast of the LCD panel. It was pretty straightforward to control during the initialization step, and I have now removed the 3900 ohm resistor connecting the LCD Vout and Vdd/Vcc pins.
I’ve also added some helper functions to write messages in specified locations of the LCD RAM. That way I can choose to write a new message on the second line or randomly at any position on screen.
6.3. I2C changes
To make space for new code, I decided that for this program I won’t worry about multi-master scenarios. I removed the interrupt handler and code that watched for other masters on the bus. I did leave the clock stretching code.
One new addition to the I2C code is the function I2C_in() which reads data from a slave. I didn’t need that for the LCD panel, but now that we want to read from a flash chip, that will be important. It take a single argument, a flag whether to acknowledge the byte or not (the convention is to acknowledge every byte except the last one). Perhaps, this should be rewritten to read an array of bytes, but this works for now.
#include
#define I2C_SDA BIT7 // Data line
#define I2C_SCL BIT6 // Clock line
inline int data_pulled_up(void) {
return (P1IN & I2C_SDA );
/* As sole master, we should never lose arbitration.
* This is more of an error check. */
we_are_master = 0;
error_occurred = 1;
P1OUT ^= BIT0; // toggle red
clk_high();
data_high();
lost_arbitration();
return;
data_low();
clk_low();
we_are_master = 1;
data_low();
clk_low();
clk_high();
data_high();
we_are_master = 0;
int n;
if( d & 0x80 ) {
data_high();
clk_high();
lost_arbitration();
return;
} else {
data_low();
clk_high();
clk_low();
int i = 20;
clk_low();
clk_high();
/* Inputs 8-bit data from slave, with or without acknowledgement. */
unsigned char I2C_in(int ack) {
int n;
unsigned char byte = 0;
if( ! we_are_master ) return 0;
data_read(); // Float line to read bits.
byte <<= 1; // Shift bits over to make room for new bit.
clk_high();
if( data_pulled_up()) {
byte |= 1; // Slave sent a 1.
clk_low();
/* If we need to acknowledge, we'll pull down the data line. */
if( ack ) {
data_low();
clk_high();
clk_low();
return byte;
I2C_Start();
delay( 10 );
I2C_out( 0x70 | CLOW ); // Contrast set.
I2C_out( 0x5C | CHIGH); // Icon display on, booster on, contrast set.
delay( 10 );
I2C_Stop();
I2C_Start();
I2C_Stop();
/* Shows a string of bytes on the LCD at the current position */
void show( unsigned char *bytes, int n ) {
I2C_Start();
while ( n-- ) {
I2C_out( *bytes++ ); // Put character.
I2C_Stop();
/* Shows a string of bytes on the LCD beginning from
* the specified address/position. */
void showAt( int addr, unsigned char *bytes, int n ) {
I2C_Start();
I2C_out( 0x80 ); // Next byte is command, followed by control byte.
I2C_out( 0x80 | addr ); // move to address addr
while ( n-- ) {
I2C_Stop();
/* Reads a sequential string of n bytes from Flash at the
* current addr. Assumes n>=1. */
void readNextByteSeq( unsigned char *c, int n ) {
I2C_Start();
I2C_out( 0xa1 ); // Slave address for reading
/* Reads the next byte of Flash from the current addr. */
unsigned char readNextByte( void ) {
unsigned char byte;
readNextByteSeq( &byte, 1 ); // Read a single byte.
return byte;
/* Read byte from Flash starting at the specified address. Sends
* a Start condition, but the (Restart and) Stop is done
* by the readNextByteSeq() function. */
void readByteSeqAt( unsigned int addr, unsigned char *c, int n ) {
I2C_Start();
I2C_out( 0xa0 ); // Slave address for writing/addressing
/* Data line is high from last write, so we are ready
* for another Start sequence. */
readNextByteSeq( c, n ); // Read a sequence of bytes.
/* Read a byte from Flash at the specified address. Sends
unsigned char readByteAt( unsigned int addr ) {
unsigned char byte;
readByteSeqAt( addr, &byte, 1 ); // Read a single byte.
return byte;
/* Write bytes to Flash starting at the specified address. */
void writeByteSeqAt( unsigned int addr, unsigned char *c, int n ) {
I2C_Start();
/* Wait for write sequence to complete. Attempt to start a
* new communication and check for an ACK. */
do {
I2C_Start();
I2C_out( 0xa0 );
} while( ! we_are_master );
/* finally got an ACK, so we can continue */
I2C_Stop();
/* Write a single byte at the specified address */
void writeByteAt( unsigned int addr, unsigned char byte ) {
writeByteSeqAt( addr, &byte, 1 );
int main(void) {
int i;
unsigned char buffer[10] = "whitestar";
unsigned char buffer1[10] = "blackstar";
/* Only output line is red, which starts off */
P1DIR |= BIT0;
P1OUT &= ~BIT0;
// Show message on second line of the LCD
showAt( 0x40, buffer, sizeof(buffer));
I found it a little unclear that the second line of the screen starts at memory location 0x40 in the display. Apparently, if you load data sequentially into the display, it loads locations 0-39 (decimal), then skips to 64-103 (decimal). I initially thought the 0x40 in the data sheet was simply a mistake, since it was the 40th character loaded, but apparently not.
Uncomment the writeByteSeqAt() calls in the main method to record new data into the Flash chip.
7. Capacitive Touch
Newer MSP430 chips have touch-enabled pins on them. But I discovered while searching for information, that any MSP430 can be programmed to do capacitive touch. This document was very helpful in working out the technique: MSP430 touch pad experiments.pdf. I also found the discussion of sampling from this page helpful: Sample Rate Jittering.
The idea for measuring a capacitive touch plate is pretty straightforward. You just apply a voltage to it and see how long it takes to charge. Apply ground and see how long it takes to discharge. If the time increases, the capacitance has gone up (and that’s what happens when you touch the plate).
If you wire things correctly, a pair of pins on the MSP430 can monitor a pair of touch plates (which don’t have to be anything special, basically anything metal you can touch). For my experiment, I chose pins 4 and 5. The configuration is simple. Connect the pins with a large value resistor; typical values I found in reading were 5M ohms and 5.1M ohms. Then connect a lead from pin 4 to one plate, and from pin 5 to another plate.
For my plates, I initially just used two jumper wires, and I touched the bare unconnected ends. But I think I may eventually want to use the technique to make a Morse code keyer, and I’ll actually want plates to touch. So I stopped at Radio Shack and bought some 2-sided copper clad (not knowing if it would be better if the back side were grounded). I scored it and snapped off two small strips.
Here’s a picture of my experiment. I labeled the resistor, which is actually five 1M ohm resistors in series, since that’s the largest value I had on hand. The I2C memory chip is still on my breadboard, but that isn’t relevant to this experiment. You can clearly see plastic wrap covering my plates (to verify that you don’t actually have to touch the plate electrically to get it to work).
Most of the code is copied from my previous I2C projects. The most interesting new parts are:
A Port 1 interrupt handler
The measure_key_capacitance() function, which is the most important new part.
The sample_key() function, which helps eliminate the effect of noise.
Check out the code. Then we can discuss.
#include
we_are_master = 0;
error_occurred = 1;
clk_high();
data_high();
lost_arbitration();
return;
data_low();
clk_low();
we_are_master = 1;
data_low();
clk_low();
clk_high();
data_high();
we_are_master = 0;
int n;
if( d & 0x80 ) {
data_high();
clk_high();
lost_arbitration();
return;
} else {
data_low();
clk_high();
clk_low();
int i = 20;
clk_low();
clk_high();
I2C_Start();
delay( 10 );
delay( 10 );
I2C_Stop();
I2C_Start();
I2C_Stop();
I2C_Start();
while ( n-- ) {
I2C_Stop();
I2C_Start();
while ( n-- ) {
I2C_Stop();
/* This triggers when a pad has been charged or discharged. When it returns,
* timer_count will hold the elapsed count of charging or discharging time for
* the key. Setup for triggering this interrupt happens in
* measure_key_capacitance(). */
void Port_1 (void) {
P1IFG = 0;
timer_count = TAR - timer_count;
/* Returns a value the reflects the capacitance of one of two key pads
* connected by a large value resistor. Assumes key to be BIT4 or BIT5. */
unsigned int measure_key_capacitance( unsigned int key ) {
static unsigned int sum;
P1OUT &= ~(BIT4 + BIT5); // Start with both keys low.
/* Set up interrupt to trigger on key. */
P1IES |= key; // Trigger on voltage drop.
P1IE |= key; // Interrupt on.
P1DIR &= ~key; // Float key and let voltage drop.
timer_count = TAR; // Get timer (to compare with in interrupt).
__bis_SR_register( LPM0_bits + GIE ); // Sleep.
P1IE &= ~key; // Disable interrupts on key.
P1OUT &= ~key; // Discharge key by setting
P1DIR |= key; // active low.
sum = timer_count; // Save the count that was recorded in interrupt.
P1IES &= ~key; // Trigger on voltage rise.
P1DIR &= ~key; // Float key and let voltage rise.
P1OUT &= ~(BIT4 + BIT5); // Set both keys to
P1DIR |= (BIT4 + BIT5); // active low.
return sum + timer_count; // Return the sum of both counts.
/* Computes a trimmed mean of 18 capacitance values, trimming the largest and
* smallest samples. */
unsigned int sample_key( unsigned char key ) {
int i, j, small, large, cap;
long int total;
total = 0;
/* Measure once to initialize max and min values. */
small = large = measure_key_capacitance( key );
/* Seventeen more samples happen here. Each time we decide whether the new
* sample is kept or if it replaces one of the extremes. */
for( i = 1; i < 18; i++ ) {
cap = measure_key_capacitance( key );
if( cap < small ) {
total += small;
small = cap;
} else if( cap > large ) {
total += large;
large = cap;
} else {
total += cap;
// Add some jitter here, for more effective sampling.
for( j=0; j < (cap&0x0F); j++ ) asm( "nop \n\t" );
/* We average 16 values (not including the two extremes) */
return total >> 4;
/* Converts an integer to a string of digits. Assumes
* the integer is between -99999 and +99999. */
char buf[7];
char *int2str( int x ) {
int num = x;
int idx = 6;
/* Leading minus for negative numbers. */
buf[0] = ( num < 0 ) ? '-' : ' ';
if( num < 0 ) num = -num;
buf[6] = '\0';
/* Fill in the digits from the right. Convert leading zeros to spaces. */
do {
idx--;
int main(void) {
int i, j;
int flag1=0, flag2=0;
int baseline1, baseline2, samp1, samp2;
/* Stop the watchdog timer so it doesn't reset our chip. */
/* Only output line is red, which starts off. */
P1DIR |= BIT0;
P1OUT &= ~BIT0;
/* Data and clock lines are read pins that go low when set for output. */
P1OUT &= ~(I2C_SDA + I2C_SCL);
delay(400); // Give LCD panel time to wake up.
init_LCD();
delay(99);
/* Setup for capacitive touch. Timer A is in count up mode, driven by the
* submain clock (1 Mhz) with a clock divider of 2^2=4. The pins for our
* touch pads are set as output pins. */
TACTL = MC_2 + TASSEL_2 + ID_2; // count up mode, SMCLK, /4
P1DIR |= BIT4 + BIT5;
/* Get baseline values for each key. */
baseline1 = sample_key(BIT4);
baseline2 = sample_key(BIT5);
/* Uncomment to see baseline values for each key. */
//showAt(0x40, int2str( baseline1 ), 6 );
//showAt(0x40+10, int2str( baseline2 ), 6 );
while( 1 ) {
samp1 = sample_key(BIT4);
samp2 = sample_key(BIT5);
#if 0
/* Uncomment to see running sample values for each key. */
showAt( 0, int2str( samp1 ), 6 );
showAt(10, int2str( samp2 ), 6 );
#else
/* If the sample exceeds the baseline by 20% (i.e. if
* samp1 > 1.2*baseline1 ), then print a message. */
if( 5*samp1 > 6*baseline1 ) {
if( !flag1 ) {
showAt(0, "Pin 4", 5 );
flag1 = 1;
} else if( flag1 ) {
showAt(0, " ", 5 );
flag1 = 0;
* samp2 > 1.2*baseline2 ), then print a message. */
if( 5*samp2 > 6*baseline2 ) {
if( !flag2 ) {
showAt(0x40, "Pin 5", 5 );
flag2 = 1;
} else if( flag2 ) {
showAt(0x40, " ", 5 );
flag2 = 0;
#endif
The key to the program is the measure_key_capacitance() function. It actually takes two measures of the capacitance of the key; and you get to specify the key, either BIT4 or BIT5. First it charges the key, then measures the time for it to discharge through the 5M ohm resistor (by recording the value of a timer and setting an interrupt to trigger on Port 1 when the voltage has fallen). Then it takes a second reading by discharging the pin, and then charging the plate from the other pin through the same resister (again measuring the time with the Port 1 interrupt handler). The sum of the charge and discharge times becomes our measure of capacitance.
The capacitance values can fluctuate quite a bit, and I read about a couple of different compensating techniques. Effectively, everyone recommends some kind of low pass filter (i.e. code that will minimize the effects of high-frequency oscillations). I tried many different things, but I eventually settled on a trimmed mean. It’s very easy to understand, and it gave me consistent performance. [Another technique I might also consider is trimming two values from the big end, since the probability distribution is right skewed; then average the rest.]
The sample_key() function simply measures the capacitance of the same key 18 times in succession. It throws out the lowest and highest values and averages the other 16. One other line worth noting in that function is the inner loop of nop instructions. The idea of that is to randomize slightly when the samples are drawn, following ideas of: Sample Rate Jittering.
The main() method is essentially just a bit of initialization code and a loop to repeatedly sample the keys. I took a bit of care about updating the LCD only when a status has changed (that’s the point of flag1 and flag2) since writing the LCD is much slower that testing the keys. Continuously writing unnecessary updates to the LCD just slows down the program. I could imagine sleeping in this loop and using a timer interrupt to wake periodically for key sampling. That would very likely consume much less power.
I also left code lines (commented out) for displaying the raw capacitance values. You might need these to tune your own setup or just to see if things are working at all.
If you liked this project, you might check out my attempts to create a Morse code touch keyer. I was not as successful as I hoped to be, but I think the attempt is still pretty interesting.
24. Bit-bang SPI interface for ktm-s1201 LCD panel
Another LCD panel; this one does SPI communication (and that means I needed to learn about I2C).
Also broken out into its own page: lcd_spi.html
SPI experiments with the MSP430
Don Bindner
Table of Contents
1. SPI communications with ktm-s1201 LCD panel
2. SPI communications with EA DOGS102 LCD panel
3. USI/SPI communications with EA DOGS102 LCD panel
I picked up a set of inexpensive 12 digit LCD panels ("new old stock" panels) on the web. Communication is via SPI (Serial Peripheral Interface), so I wired one up to an msp430g2211 and started studying data sheets. Since this microcontroller doesn’t have hardware serial support (and since I wanted to learn about how the protocol works) I decided to do a bit-banged serial program. To get things wired up, I used this (somewhat abreviated) data sheet: data/ktm-s1201.pdf
From the LCD panel, these connections are made:
Pin 1 Vcc — Vcc on the Launchpad (+3.3V)
Pin 2 Vss — GND on the Launchpad
Pin 3 SCK — P1.6 on the Launchpad (which I’ve used for the serial clock line)
Pin 4 SI — P1.0 on the Launchpad (which I’ve used for Master-out Slave-in line)
Pin 5 C/D — P1.7 on the Launchpad (which I’ve used for the Command/Data selector)
Pin 6 Reset — Needs to be pulled high. This can be done with a high-value resistor, like 10K, connected to Vcc.
Pin 7 Busy — Can be left disconnected as long, as you don’t drive the LCD too fast. Normally the panel uses this line to tell the microcontroller to wait.
Pin 8 CS — P1.5 on the Launchpad (which I’ve used for chip select)
Pin 9 Vlc — Described below
Pin 10 NC — Not connected
On the data sheet, Pin 9 is shown connected to the center pin of a variable resistor whose ends are connected to Vcc and GND. I used a 10K potentiometer that I had on hand. This arrangement effectively creates a voltage divider, with an adjustable intermediate voltage on the middle pin (connected to Pin 9). This is how you set the contrast of the LCD so you can actually see text on it.
There’s nothing particularly important about the specific Launchpad pin assignments. When learning, I usually configure significant lines on the pins that have LEDs, so I can watch the lights and have an idea if things are working. That’s why I put the clock line on P1.6 (so the clock line shows on the green Launchpad LED) and the data line on P1.0 (so data shows on the red Launchpad LED). But they could all be changed with minimal changes to the code.
A somewhat minimal SPI bit-banging example program follows. The key function is spi_IO(), which handles the serial communication with the panel, effectively putting bits on the MOSI line one at a time and pulsing the clock pin. The other helper functions; init_lcd(), print_lcd(), and decimal_on(); all call this function.
#include
#define CS BIT5 // Chip Select line
#define CD BIT7 // Command/Data mode line
#define MOSI BIT0 // Master-out Slave-in
#define SCK BIT6 // Serial clock
#if 20110706 > __MSPGCC__
/* A crude delay function. */
void __delay_cycles( unsigned long n ) {
volatile unsigned int i = n/6;
while( i-- ) ;
#endif
/* Write data to slave device. Since the LCD panel is
* write-only, we don't worry about reading any bits.
* Destroys the data array (normally received data would
* go in its place). */
void spi_IO( unsigned char data[], int bytes ) {
int i, n;
// Set Chip Select low, so LCD panel knows we are talking to it.
P1OUT &= ~CS;
__delay_cycles( 500 );
for( n = 0; n < bytes; n++ ) {
for( i = 0; i < 8; i++ ) {
// Put bits on the line, most significant bit first.
if( data[n] & 0x80 ) {
P1OUT |= MOSI;
} else {
P1OUT &= ~MOSI;
data[n] <<= 1;
// Pulse the clock low and wait to send the bit. According to
// the data sheet, data is transferred on the rising edge.
P1OUT &= ~SCK;
// Send the clock back high and wait to set the next bit. Normally
// we'd also read the data bits here, but the LCD is write-only.
P1OUT |= SCK;
// Set Chip Select back high to finish the communication.
// For data, this also triggers the LCD to update/display.
P1OUT |= CS;
/* Sets the LCD to command mode, and sends a 7-byte
* sequence to initialize the panel. */
void init_lcd( void ) {
unsigned char data[] = {
0x40, // M=0(4-share-1/3 duty; FF=0)
0x30, // Unsynchronized transfers
0x18, // Blink off
0x11, // Display on
0x15, // Segment Decoder ON
0x20, // Clear Data and pointer
0x00 // Clear blink memory
P1OUT |= CD; // set for commands
spi_IO( data, sizeof(data));
/* Prints a string on the LCD panel using the 7 segment decoder.
* Understood characters are 0x00 (zero) to 0x09 (nine) and
* 0x0A to 0x0F (the symbols -, E, C, =, and space). */
void print_lcd( unsigned char data[], int n ) {
unsigned char copy[12];
unsigned char tmp;
int i;
if( n < 1 ) return;
if( n > 12 ) n=12;
// The panel expects data arranged right to left, so we'll
// reverse the array of data passed before writing it out.
for( i = n; i > 0; i-- ) {
copy[n-i] = data[i-1];
P1OUT &= ~CD; // set for data
spi_IO( copy, n );
/* Draws a decimal point n places from the right, by turning on
* the individual LCD segment (OR 0x8 mask with segment memory). */
void decimal_on( int n ) {
0x14, // Segment Decoder off
0xE0+2*n, // Set pointer 0 (plus 2 for each digit)
0xB8, // Decimal point on (OR 0x8 with memory contents)
0x15 // Segment Decoder on
if( n < 0 || n > 11 ) return;
void main( void ) {
// Stop the watchdog timer so it doesn't reset our chip
// These are the pins we need to drive.
P1DIR |= SCK + MOSI + CS + CD;
// De-select the LCD panel and set the clock high
P1OUT |= CS + SCK;
// Pause so everything has time to start up properly.
__delay_cycles( 15000 );
for( ;; ) {
__bis_SR_register( LPM3_bits + GIE );
The next program adds functions to take advantage of most all the features/commands offered by the LCD controller chip on the panel (an NEC uPD7225). Details are in the data sheet: data/upd7225.pdf This data sheet is also where I learned specifics of the serial protocol (that bits are written on the rising clock edge for example).
The decimal_off() function complements the decimal_on() function.
The write_segments() function can turn on arbitrary segments of the display, so symbols other than the stock 15 symbols may be displayed. For example capital A and lower case b could be displayed by turning on the correct individual segments.
The write_blinking() function is similar, but it marks segments on the display that (if also set in the segment memory) will blink on and off. The blink_on() and blink_off() modify the master flag that controls whether blinking happens. Finally, the display_on() and display_off() turn on and off the entire display.
#include
while( i-- ) ;
#endif
int i, n;
P1OUT &= ~CS;
P1OUT |= MOSI;
} else {
P1OUT &= ~MOSI;
data[n] <<= 1;
P1OUT &= ~SCK;
P1OUT |= SCK;
P1OUT |= CS;
0x18, // Blink off
0x11, // Display on
unsigned char tmp;
int i;
if( n < 1 ) return;
if( n > 12 ) n=12;
spi_IO( copy, n );
/* Erases a decimal point n places from the right, by turning off
* the individual LCD segment (AND 0x7 mask with segment memory). */
void decimal_off( int n ) {
0x97, // Decimal point off (AND 0x7 with memory contents)
/* Writes a custom configuration of segments in the digit n places from
* the right, by writing 8 bits directly to the segment memory.
* Mask values:
* 0x01 = top 0x10 = top-left
* 0x02 = top-right 0x20 = middle
* 0x04 = bottom-right 0x40 = bottom-left
* 0x08 = decimal 0x80 = bottom */
void write_segments( int n, unsigned char bits ) {
0xD0+(bits&0xF),// Write contents (4 bits)
0xD0+(bits>>4), // Write contents (4 bits)
/* Blinks a custom configuration of segments in the digit n places from
* the right, by writing 8 bits directly to the blink memory. Segments
* only blink if they are set, and if the blink state is set on.
* Mask values:
void write_blinking( int n, unsigned char bits ) {
0xC0+(bits&0xF),// Write contents (4 bits)
0xC0+(bits>>4), // Write contents (4 bits)
/* Send the command to enable blinking. (Only segments set in blink
* memory actually blink, and only if they are on in segment memory.) */
void blink_on() {
unsigned char cmd = 0x1A;
spi_IO( &cmd, 1 );
/* Send the command to disable blinking. */
void blink_off() {
unsigned char cmd = 0x18;
spi_IO( &cmd, 1 );
/* Send the command to clear the blink memory. */
void clear_blinking() {
unsigned char cmd = 0x00;
spi_IO( &cmd, 1 );
/* Send the command to turn clear the display. */
void clear_lcd() {
unsigned char cmd = 0x20;
spi_IO( &cmd, 1 );
/* Send the command to turn off the display. */
void display_off() {
unsigned char cmd = 0x10;
spi_IO( &cmd, 1 );
/* Send the command to turn on the display. */
void display_on() {
unsigned char cmd = 0x11;
spi_IO( &cmd, 1 );
void main( void ) {
P1OUT |= CS + SCK;
// Initialize the LCD panel.
init_lcd();
// Print a message.
print_lcd("\x0A\x0B\x0C\x0D\x0F", 5 );
for( ;; ) {
The commands for building and installing this program (using the msp430-gcc 4.5.3 compiler) are:
$ msp430-gcc -O2 -mmcu=msp430g2211 -o ktm-s1201.elf ktm-s1201.c
$ mspdebug rf2500 "prog ktm-s1201.elf"
I had so much fun learning SPI that I decided to attack another LCD panel I have on hand, an EA DOGS102. This is a 102x64 pixel graphical panel. The data sheet, data/dogs102-6e.pdf (page 4), is pretty clear about wiring up the display, which requires three 1uF capacitors for the voltage booster and a pull-up resistor (I used a 10k resistor) for the reset pin.
There are 4 more connections for the serial communication, and these are the hookups that correspond to the program that follows.
LCD pin 24 SDA — Launchpad P1.1
LCD pin 25 SCK — Launchpad P1.2
LCD pin 26 C/D — Launchpad P1.7
LCD pin 28 CS — Launchpad P1.5
The dangling orange wire in the picture is hooked to the reset pin. If I need to reset the LCD, I can just touch it temporarily to ground.
The following code uses bit-banged SPI to initialize the panel and fill the LCD alternately with black, then white, then black, then white pixels. More info about the LCD controller is in the data sheet, data/uc1701.pdf.
#include
#define MOSI BIT1 // Master-out Slave-in
#define SCK BIT2 // Serial clock
void __delay_cycles( unsigned long int n ) {
while( i-- ) ;
#endif
int i, n;
P1OUT &= ~CS;
__delay_cycles( 5 );
P1OUT |= MOSI;
} else {
P1OUT &= ~MOSI;
data[n] <<= 1;
P1OUT &= ~SCK;
P1OUT |= SCK;
P1OUT |= CS;
0x40, // display start line 0
0xA1, // SEG reverse
0xC0, // Normal COM0-COM63
0xA4, // Disable->Set All Pixel to ON
0xA6, // Display inverse off
0xA2, // Set Bias 1/9 (Duty 1/65)
0x2F, // Booster, Regulator and Follower on
0x27,
0x81, // Set contrast
0x10,
0xFA, // Set temp compensation ...
0x90, // ... curve to -0.11 %/degC
0xAF // Display On
P1OUT &= ~CD; // set for commands
/* Writes zeros to the contents of display RAM, effectively resetting
* all of the pixels on the screen. The screen width is 6*17 = 102 pixels,
* so I used and array of size 17 and loop 6 times. Each page in RAM
* spans 8 pixels vertically, and looping through the 8 pages covers
* the 8*8 = 64 pixel height of the display. */
void write_zeros( void ) {
unsigned char zeros[17];
int i, j, page;
for( page = 0; page < 8; page++ ) {
zeros[0] = 0xB0 + page; // set page
zeros[1] = 0x00; // LSB of column address is 0
zeros[2] = 0x10; // MSB of column address is 0
spi_IO( zeros, 3 );
P1OUT |= CD; // set for data
for( i = 0; i < 6; i++ ) {
for( j = 0; j < 17; j++ ) zeros[j] = 0x00;
spi_IO( zeros, sizeof( zeros ));
/* Writes ones to the contents of display RAM, effectively setting
void write_ones( void ) {
unsigned char ones[17];
int i, j, page;
ones[0] = 0xB0 + page; // set page
ones[1] = 0x00; // LSB of column address is 0
ones[2] = 0x10; // MSB of column address is 0
spi_IO( ones, 3 );
for( j = 0; j < 17; j++ ) ones[j] = 0xFF;
spi_IO( ones, sizeof( ones ));
void main( void ) {
// De-select the LCD panel and set the clock high.
P1OUT |= CS + SCK;
__delay_cycles( 5500 );
init_lcd();
// Blacken and clear the LCD two times.
write_ones();
write_zeros();
write_ones();
write_zeros();
for( ;; ) {
$ msp430-gcc -O2 -mmcu=msp430g2211 -o dog-s102.elf dog-s102.c
$ mspdebug rf2500 "prog dog-s102.elf"
Maybe more experiments will follow. Since the DOGS102 doesn’t have a character generator, you’ll probably want to use a chip that has more than 2K of flash (i.e. the msp430g2211 wouldn’t be a great choice). You’ll need the space to hold something of a font.
A chip like the msp430g2553 would probably be better, if you intend to stick to through-hole DIP chips, and in that case you could also do much better than bit-banging the interface since you could use the USCI interface in the microcontroller. There are many capable chips if you don’t mind a harder soldering job or if surface mount is acceptable for you.
Bit-banging SPI communication is pretty easy, but in general it’s not a great approach. In particular, blowing time in a wait loop tends to consume a lot more power than is really necessary. It would be much better to sleep and let one of the MSP430 clocks handle communication timing.
So I decided to rewrite my DOGS102 program to use the USI interface of the msp430g2231 chip (and similar). I had to give up on the msp430g2211 since it doesn’t have hardware serial support.
If I had planned ahead, I would have carried out my initial bit-bang experiments using the data and clock pins of the USI interface. But I didn’t so I had to re-wire my LCD panel to my Launchpad.
The new connections are:
LCD pin 24 SDA — Launchpad P1.6
LCD pin 25 SCK — Launchpad P1.5
LCD pin 26 C/D — Launchpad P1.2
LCD pin 28 CS — Launchpad P1.1
The primary changes to the program are:
In spi_IO(), instead of bit banging, we load bytes into the serial register and sleep while the data sends.
In the main() function, we set up the clocks and registers for the USI (universal serial interface).
There is a new interrupt handler USI_ISR(), which wakes up the main program after each byte has been transmitted.
#include
#include
/* For USI, these are the required pin assignments:
* P1.5 SCLK -- serial clock
* P1.6 SDO -- serial data out (MOSI for master)
* P1.7 SDI -- serial data in (MISO for master) not connected
* in this program.
* Chip Select line can be anything.
* Command/Data line can be anything. */
#define CS BIT1 // Chip Select line
#define CD BIT2 // Command/Data mode line
while( i-- ) ;
#endif
* write-only, we don't worry about reading any bits. */
int i, n;
P1OUT &= ~CS;
USISRL = data[n]; // load byte into USI serial register (lower half)
USICNT = 8; // set count to 8 bits
__bis_SR_register( LPM0_bits + GIE ); // sleep until done
P1OUT |= CS;
0x27, // Set...
0x81, // ...
0x10, // ...contrast.
0xFA, // Set temp compensation...
0x90, // ...curve to -0.11 %/degC
0xAF // Display On
int i, j, page;
spi_IO( zeros, 3 );
int i, j, page;
spi_IO( ones, 3 );
void main( void ) {
WDTCTL = WDTPW + WDTHOLD;
P1DIR = CS + CD;
// Pins to enable:
// P1.6 -- SDO/MOSI Master-out Slave-In
// P1.5 -- SCLK serial clock
// Flags:
// most significant bit sent first
// enable output
// disable USI (for now)
USICTL0 = USIPE6 | USIPE5 | USIMST | USIOE | USISWRST;
// enable interrupts, but set the interrupt flag for now
USICTL1 = USIIE | USIIFG;
// Clock speed:
// Use clock divider 2^4=16.
// Use clock source 2 (submain clock?).
// Polarity and phase settings/flags for the clock:
// SPI Mode 0 --- CPOL=0,CPHA=0 --- USICKPH
// SPI Mode 1 --- CPOL=0,CPHA=1 --- 0
// SPI Mode 2 --- CPOL=1,CPHA=0 --- USICKPL|USICKPH
// SPI Mode 3 --- CPOL=1,CPHA=1 --- USICKPL *** this one for DOGS panel
USICKCTL = USIDIV_4 | USISSEL_2 | USICKPL;
// enable USI
USICTL0 &= ~USISWRST;
// Clear the USI interrupt flag
USICTL1 &= ~USIIFG;
init_lcd();
write_ones();
write_zeros();
write_ones();
write_zeros();
/* This interrupt triggers when the USI serial register gets
* empty. We use it to wake up the main program. */
interrupt(USI_VECTOR) USI_ISR(void) {
USICTL1 &= ~USIIFG; // clear the interrupt flag
__bic_SR_register_on_exit( LPM0_bits ); // wake on exit
Don Bindner
Table of Contents
1. Capacitive Touch
2. A Completely Minimal Paddle
3. An Iambic Keyer
4. A Standalone Keyer
5. Commercial circuit board
6. A simple straight key
7. Touch paddles
This page is a companion page for my MSP430 Launchpad page.
After learning how to do capacitive touch sensing with an MSP430 over at lcd_i2c.html#_capacitive_touch, I started thinking about something fun I might do with the technique. I thought it might be fun to make a paddle keyer for keying Morse code, so I copied the relevant parts of that page here.
1. Capacitive Touch
If you wire things correctly, a pair of pins on the MSP430 can monitor a pair of touch plates (which don’t have to be anything special, basically anything metal you can touch). For the examples that follow, I chose pins 1.4 and 1.7 on the MSP430. The configuration is simple. Connect the pins with a large value resistor; typical values I found in reading were 5M ohms and 5.1M ohms. Then connect a lead from pin 1.4 to one plate, and from pin 1.7 to another plate.
You can make a completely minimal touch paddle with only a single 5M ohm resistor and no plates at all. Bend the leads out, and connect pin 1.4 to pin 1.7, with the resistor straddling the MSP430. I took a picture of mine. I used a 10M ohm resistor here, since that is what I had on hand, but I would guess that value is a bit higher that optimal. It worked, but it seemed just a bit slow to recognize touches when I played with it.
This program implements the touch detection. It simply lights one LED if you press the "dot" lead (traditionally, the left paddle). And it lights the other when you press the "dash" lead. I could perhaps modify it later to use a transistor, or maybe an optical isolator, to actually drive the keyer in my transmitter. And of course, I could connect it to real paddles.
#include
#define RED BIT0
#define GRN BIT6
#define DOT BIT4
#define DASH BIT7
volatile unsigned int timer_count;
void Port_1 (void) __attribute__((interrupt(PORT1_VECTOR)));
P1IFG = 0;
* connected by a large value resistor. Assumes key to be BIT4 or BIT7. */
P1OUT &= ~(BIT4 + BIT7); // Start with both keys low.
P1OUT &= ~(BIT4 + BIT7); // Set both keys to
P1DIR |= (BIT4 + BIT7); // active low.
long int total;
total = 0;
if( cap < small ) {
total += small;
small = cap;
total += large;
large = cap;
} else {
total += cap;
return total >> 4;
void WDT(void) __attribute__((interrupt(WDT_VECTOR)));
void WDT(void) {
/* Wake up the main program. */
int main(void) {
int i, j;
int baseline1=0, baseline2=0, samp1, samp2;
/* Set clock speed at 1Mhz. */
BCSCTL1 = CALBC1_1MHZ;
DCOCTL = CALDCO_1MHZ;
/* Both LEDs are output lines */
P1DIR |= RED + GRN;
P1DIR |= DASH + DOT;
/* Get maximum baseline values for each key. In the main loop, more than
* 125% of the baseline value will indicate a touch event. */
P1OUT |= RED + GRN; // Visually signal the calibration cycle.
for( i = 0; i < 32; i++ ) {
samp1 = sample_key(DASH);
if( samp1 > baseline1 ) baseline1 = samp1;
/* One paddle lights the green light. */
if( 4*samp1 > 5*baseline1 ) {
P1OUT |= GRN;
} else {
P1OUT &= ~GRN;
/* The other paddle lights the red. */
if( 4*samp2 > 5*baseline2 ) {
P1OUT |= RED;
} else {
P1OUT &= ~RED;
/* Set watchdog timer interval to wake us up in 0.5 ms. */
WDTCTL = WDT_MDLY_0_5;
IE1 |= WDTIE;
/* Go to sleep to save power until awoken by timer. */
__bis_SR_register(LPM0_bits);
The key to the program is the measure_key_capacitance() function. It actually takes two measures of the capacitance of the key; and you get to specify the key, either BIT4 or BIT7. First it charges the key, then measures the time for it to discharge through the 5M ohm resistor (by recording the value of a timer and setting an interrupt to trigger on Port 1 when the voltage has fallen). Then it takes a second reading by discharging the pin, and then charging the plate from the other pin through the same resister (again measuring the time with the Port 1 interrupt handler). The sum of the charge and discharge times becomes our measure of capacitance.
One other thing that I’ve done here is find the largest of a series of samples for the initial baselines, rather than just taking a single average. That seems to reduce the number of instances where the paddles are just too sensitive (and react to anything coming even near them).
3. An Iambic Keyer
First, it should be said that I’ve never actually used an electronic keyer, except the one I made for this project. I’m still a pretty new ham. So I don’t know if my keyer behaves in ways that experienced hams would appreciate.
There are a few things that I can note readily. The top speed of this keyer is probably fairly limited. I might be able to do better by raising the clock speed to 16mhz, but I haven’t tried that. Speed is probably more fundamentally limited by the time it takes to measure a capacitance.
Another thing to note, is that this keyer does not have a "dot buffer." That is to say, if it is playing a dash and you hit a dot (quickly) in the middle, it will not be remembered. Of course, if you keep the dot keyed, it will be picked up when the dash is finished. I toyed with adding a dot buffer, but it isn’t really compatible with my idea for this program.
For this program, I wanted something I could practice on. That is, I wanted to be able to key the paddles, and hear the appropriate result. And I wanted to do it with a minimum of parts (two paddles, one resistor, one salvaged electromagnetic transducer, and one Launchpad).
Doing anything while sound is playing creates easily discernible distortion in the tone. For a "real" keyer, where you aren’t trying to play your own sound, but rather where you key an actual radio it could probably be done fine. It would also be not too hard to hook two launchpads together, and let one do the keying and the other create sound (or use a 555 timer, or whatever).
I’ve coded it for the transducer to be hooked between pin P1.1 and ground. I used the red LED to give a visual indicator of inter-letter space, and the green LED to give a visual indicator of word space (so if you see the green light appear between letters instead of words, you are keying too slowly).
The configuration for the touch paddles is:
A 5M ohm resistor between pin 1.4 and pin 1.7.
Pin 1.4 is connected to the paddle that creates dots (usually the left).
Pin 1.7 is connected to the paddle that creates dashes (usually the right).
I connected a transducer that I salvaged from a broken cordless phone (a SoniCrest HC12G pulled from a Uniden phone) between pin 1.1 and ground (with a resistor to keep the volume down so my wife doesn’t go nuts). Jameco part #138722 looks like a good match, though I haven’t tried it.
A little hot glue, and a couple of scrap wood block put together a fairly clean keyer. I found that a couple of rubber bands around the ends of the base made for really good "non-slip feet." Enjoy a picture:
#include
#define AUDIO BIT1
#define RED BIT0
#define GRN BIT6
#define DOT BIT4
#define DASH BIT7
unsigned int wpm = 8;
unsigned int dotCount = 0, guardSpace = 0;
volatile int counter = 0;
volatile unsigned int countAdjust=0;
volatile int toneOn = 0;
volatile int dotKey = 0, dashKey = 0;
/* Key capacitance baseline values. */
unsigned int base_dash, base_dot;
/* State of the keyer.
* idle: no keys pressed recently
* dot: sent a dot
* dash: sent a dash
enum STATES { idle, dot, dash } state = idle;
P1IFG = 0;
* connected by a large value resistor. Assumes key to be BIT7 or BIT4. */
P1OUT &= ~(BIT7 + BIT4); // Start with both keys low.
P1OUT &= ~(BIT7 + BIT4); // Set both keys to
P1DIR |= (BIT7 + BIT4); // active low.
long int total;
total = 0;
if( cap < small ) {
total += small;
small = cap;
total += large;
large = cap;
} else {
total += cap;
return total >> 4;
/* Returns 1 if the key is touched (sufficiently past the baseline
* value) and 0 otherwise. Sampling can take a fair bit of time, so
* we adjust the counter for timerA. */
int key_touched( unsigned char key, unsigned int baseline ) {
unsigned int timeElapsed=0;
int touch;
/* Time elapsed is computed to adjust the delay time. */
timeElapsed = TAR;
touch = ( 4*sample_key(key) > 5*baseline );
/* Adjust the delay to account for key sampling time. */
countAdjust += TAR - timeElapsed;
return touch;
/* This interrupt counts the durations for playing dots and dashes,
* as well as the durations for dot-spaces and dash-spaces. */
void TimerA0(void) __attribute__((interrupt(TIMERA0_VECTOR)));
void TimerA0(void) {
CCR0 += 80;
if( counter-- > 0 ) {
if( toneOn ) {
P1OUT ^= AUDIO;
} else {
/* Wake up main program when count is finished. */
__bic_SR_register_on_exit(LPM0_bits);
void WDT(void) {
/* wake up the main program. */
__bic_SR_register_on_exit(LPM3_bits);
void do_space_with_polling( int guard, int minwait, int maxwait ) {
/* Waits the specified amount of time with polling at 4 points, at
* the beginning, at the end of the guard time, at the end of the minwait
* and at the end of the maxwait. Guard space keeps us from accidentally
* adding another symbol, but a dash is fine after a dot, and a dot is fine
* after a dash. Assumes guard <= minwait <= maxwait.*/
if( guard > 0 ) {
/* Immediately poll for a key, guarding against doubles. */
if( state != dash ) {
dashKey = key_touched(DASH, base_dash);
int main(void) {
int i, j;
unsigned int samp1, samp2;
/* Set ACLK to use VLO so we can sleep in LPM3 when idle. */
BCSCTL3 |= LFXT1S_2;
/* Set all output pins low. */
P1OUT = 0x00;
P1DIR = 0xFF;
P1DIR |= RED + GRN;
P1OUT &= ~(RED + GRN);
/* So is the Audio pin. */
P1DIR |= AUDIO;
P1OUT &= ~AUDIO;
/* One word per minute is 50 dots, which makes each dot 6/5 seconds. Since
* there are 1e6/4 clock ticks per second (because of the clock divider),
* and the counter is moved every 80 ticks, the length of a 1 wpm dot is
* 1e6/4/80*(6/5) = 3750. */
dotCount = 3750 / wpm;
guardSpace = dotCount/2; // guard space is 1/2 of a dot
* touch pads are set as output pins. Same settings used for tone generation. */
TACTL = MC_2 + TASSEL_2 + ID_2 + TACLR; // count up mode, SMCLK, /4
play_welcome("-.-."); // "C"
if( samp1 > base_dash ) base_dash = samp1;
countAdjust = 0; // no need to adjust during tone
CCR0 = TAR+80; // 80 * 4us = 320us -- for tone generation
CCTL0 |= CCIE; // CCR0 interrupt enabled
__bis_SR_register(LPM0_bits + GIE);
CCTL0 &= ~CCIE; // CCR0 interrupt disabled
} else if( dashKey ) {
state = dash;
counter = 3*dotCount;
toneOn = 1; // Play tone.
} else {
/* Set watchdog timer interval to wake us up in 43.7 ms
* (normally it would be 16 ms, but the VLO is slower). */
WDTCTL = WDT_ADLY_16;
IE1 |= WDTIE;
__bis_SR_register(LPM3_bits + GIE);
/* Hold the watchdog clock. */
continue;
dotKey = dashKey = 0;
/* Need at least a dot-space now, maybe more. */
toneOn = 0;
P1OUT &= ~AUDIO;
/* 0. Keys within this first space will add symbols to the current letter.
* We'll guard for dots after a dot, and dashes after a dash. We'll accept
* (sloppy) keys up to half a dot late. */
do_space_with_polling( guardSpace, dotCount, dotCount+dotCount/2 );
/* If a key was pressed, go back to the top to process it. */
if( dotKey || dashKey ) continue;
state = idle;
P1OUT |= RED; // visually indicate dash space between letters
/* 1.5 Now we finish the dash space, and start a new letter. No guard time.
* We'll accept (keys) up to half a dot late, for starting the next letter. */
do_space_with_polling( 0, dotCount+dotCount/2, 2*dotCount );
P1OUT &= ~RED; // end of dash space
/* 3.5 Another three and a half dots finishes the word space. Start with
* two and a half dots without polling. */
/* 7. A final dot space finishes the word-space. */
do_space_with_polling( 0, dotCount, dotCount );
/* Idle. Loop back to the top. */
I poll at select times, measured from the ending time of the previous dot or dash: after 0 dots of space, 0.5 dots, 1 dot, 1.5 dots, 3 dots, 3.5 dots, 6 dots, and 7 dots. It might make the keyer more responsive to poll more often, but I found it tricky to get that just right.
You should see a red light between letters, and a red-green transition between words. If you see the green between letters, or a red between symbols in the same letter, you are keying too slowly. If you fail to see a red between letters, or a green between words, you are keying too quickly.
(If you don’t have a speaker/transducer to connect to pin 1.1, change AUDIO to BIT0 or BIT6 and it will light one of the LEDs instead.)
It took me some missteps, but I really wanted to make my keyer free-standing, without the need for the Launchpad card. The page Design notes: Power was really helpful. They aren’t kidding about the capacitors, by the way. Without the proper filtering capacitors, my program would refuse to run, hang randomly, etc. A bunch of caps are definitely going into my next component order.
I took a bit of time to rebuild this as a stand-alone circuit, and I added 3 LEDs to my circuit board. One is tied to the audio pin, and glows as code is generated. The other two show the inter-letter and inter-word spaces. On my board, I chose green for the code light, amber for inter-letter space, and red for inter-word space.
The jumper in the picture is for turning off the speaker, so it doesn’t drive my wife nuts. I can still test without sound by watching the LEDs. For paddles, I eventually settled on PCI expansion bay covers salvaged from a broken PC. They worked fine, although it was a bit hard to get solder to stick to them.
To summarize:
P1.0 is connected to amber LED (for showing inter-letter space) and 100 ohm current limiting resistor.
P1.1 is connected to green LED and 100 ohm current limiting resistor, as well as to the transducer. (The transducer is connected through a jumper so it can be turned off.)
P1.6 is connected to red LED (for showing inter-word space) and 100 ohm current limiting resistor.
P1.7 is connected to DASH paddle.
P1.4 is connected to DOT paddle.
(I used the same 100 ohm resistor for all 3 LEDs putting it between the cathode and ground, and tying all the cathodes together.)
Other connections that were needed:
Vcc is connected to the positive terminal of a two AA battery pack.
GND is connected to the negative terminal of a two AA pack.
Vcc and GND are connected to each other by 0.1uF capacitor.
RST is connected to Vcc through a 47K resistor.
RST is connected to GND through a 0.001uF capacitor.
When idle, the circuit measures a current draw of 50 uA which means it should run for over a year on a pair of AA batteries, even if on all the time. You’d probably want to turn it off and on to recalibrate, at least when there are significant temperature or humidity changes. When being keyed, it probably draws closer to 15-20mA for lighting the LEDs and playing the buzzer.
I decided that I wanted to do up a circuit board for keyer project. It seems that part of the advantage of using a microcontroller is that you can customize your programs to suit different needs. For example, perhaps you only need a really nice touch interface, but your intent is to interface to a ham radio that already has a keyer. In that case you can trim all of the unnecessary program parts and focus on making clean and responsive touch paddle code. Perhaps you want to go even simpler and use it as a straight key.
I tried to plan my board so that it could be used in many different ways. It came back from the fab and it looks pretty nice. So far, I’ve written a couple of different simplified programs to run on it.
Here’s the board fully populated with components.
I did the board design using CadSoft Eagle. A schematic and board file are here: keyer.sch keyer.brd.
This is the component list:
U$1 is a MS430g2211 microcontroller (but the MSP430g2231 or other similar chips should also work).
C1 is a 0.1uF capacitor
C2 is a 0.001uF (1 nanofarad) capacitor
R1 and R6 are 49k ohm resistors
R2 is a 100 ohm resistor
R3 is a 5M ohm resistor
R4 and R5 are 56 ohm resistors
RED, YEL, GRN are 3mm LEDs
OK1 is an MCT61 optoisolator
SG1 is a magnetic transducer (sourced from Jameco)
Terminal blocks are TE Connectivity 282834-2 and 282834-3.
Jumper JP2 lets you connect or disconnect the speaker/transducer. Jumper JP1 allows you to program the MSP430 "in place" without having to always remove the chip to a Launchpad card. Simply provide power, then jumper these three lines to a Launchpad for programming.
Probably the conceptually simplest way to run morse code is via a "straight key." In the context of our paddle circuit touching a paddle (either one) will close the key. That’s what the next program achieves, with little fuss. It assumes that any side tone will be generated by your radio, and you only wish the microcontroller to handle the opening and closing of the key.
Many of the components of the board are optional if you want to create a minimal straight key. These are the components you need:
U$1: MS430g2211 microcontroller (but the MSP430g2231 or other similar chips should also work).
C1: 0.1uF capacitor
C2: 0.001uF (1 nanofarad) capacitor
R1: 49k ohm resistor
R3: 5M ohm resistor
R4, R5: 56 ohm resistors
OK1: MCT61 optoisolator
X1, X2, X3: 282834-2 and 282834-3 (or just solder connections straight to the pads).
You’ll need a way to get the signal into you radio. My Yaesu radio uses a mini stereo connector, so I connected the S, R, and T lines of X3 to the sleeve, ring, and tip of a stereo connector. Then I used a stereo patch cable to connect my radio. Technically, for a straight key, you may not need to connect the ring part of the connection.
You may optionally want to include the yellow and red LEDs and the 100 ohm resistor R3, but the program works fine without them. Here’s the code.
#include
#define YEL BIT0
#define RED BIT6
#define DOT BIT4
#define DASH BIT5
#define TIP BIT2
#define RING BIT3
P1IFG = 0;
* connected by a large value resistor. Assumes key to be DOT or DASH. */
P1OUT &= ~(DOT + DASH); // Start with both keys low.
P1OUT &= ~(DOT + DASH); // Set both keys to
P1DIR |= (DOT + DASH); // active low.
long int total;
total = 0;
if( cap < small ) {
total += small;
small = cap;
total += large;
large = cap;
} else {
total += cap;
return total >> 4;
* value) and 0 otherwise. */
inline int key_touched( unsigned char key, unsigned int baseline ) {
return ( 4*sample_key(key) > 5*baseline );
void WDT(void) {
int main(void) {
int i;
P1OUT = 0x00;
P1DIR = 0xFF;
P1DIR |= YEL + RED;
P1OUT &= ~(YEL + RED);
P1OUT |= YEL + RED;
/* Set watchdog timer interval to wake us up in 5.2 ms
* (normally it would be 1.9 ms, but the VLO is slower). */
WDTCTL = WDT_ADLY_1_9;
IE1 |= WDTIE;
The function of this program is not hard to understand. When the capacitive touch code detects that you’ve touched a paddle, it raises the output lines that go to the input side of the optoisolator. That causes the resistance in the output side of the optoisolator to fall, and the ring and tip connections are brought to ground (exactly as if you closed a physical key/switch). That triggers your radio to generate continuous wave (i.e. Morse code) signal. When you quit touching the paddles, the microcontroller drops its output lines and the optoisolator resistance recovers (as if a physical key/switch were opened).
7. Touch paddles
Only slightly more complex than a straight key, two paddles allows you to connect to a radio and separately indicate dots and dashes. This requires essentially the same components as the straight key:
C1: 0.1uF capacitor
R3: 5M ohm resistor
You’ll need a way to get the signal into you radio, just as with the straight key version of the program. My Yaesu radio uses a mini stereo connector, so I connected the S, R, and T lines of X3 to the sleeve, ring, and tip of a stereo connector. Then I used a stereo patch cable to connect my radio. For this version of the program you will need to connect the ring part of the connection.
You may optionally want to include the yellow and red LEDs and the 100 ohm resistor R3, but the program works fine without them. Also, if you include the switch, as well as 49k ohm resistor R6, you’ll be able to reverse the function of paddles on the fly (that is, which paddle generates dots and which generates dashes).
Here’s the code.
#include
#define SWITCH BIT7
#define YEL BIT0
#define RED BIT6
#define DOT BIT4
#define DASH BIT5
#define TIP BIT2
#define RING BIT3
volatile unsigned int bounce_count=0;
volatile unsigned int dash=DASH, dot=DOT;
* measure_key_capacitance(). Also triggers if we press the switch, and
* schedules a check of the switch after a debouncing delay. */
if( P1IFG & SWITCH ) {
P1IFG &= ~SWITCH;
bounce_count = 6;
P1IE &= ~SWITCH; // Disable switch while we measure.
P1IE |= SWITCH; // Re-enable switch.
long int total;
total = 0;
if( cap < small ) {
total += small;
small = cap;
total += large;
large = cap;
} else {
total += cap;
return total >> 4;
/* When count hits 0, it's time to check the switch */
if( !bounce_count ) {
if( P1IN & BIT7 ) { // key press, swap dash and dot
dash ^= DASH+DOT;
dot ^= DASH+DOT;
} else {
int main(void) {
int i;
P1OUT = 0x00;
P1DIR = 0xFF;
P1DIR |= YEL + RED;
/* Set switch as input pin triggering on rise. */
P1IES &= ~SWITCH; // Trigger on voltage rise.
P1IE |= SWITCH; // Interrupt on.
P1DIR &= ~SWITCH; // Input pin.
P1OUT |= YEL + RED;
IE1 |= WDTIE;
This program functions nearly identically to the straight key program, except for two differences. The ring and tip connections are driven independently, and the Port 1 interrupt handler has been adapted to detect when the switch is pressed. A small change was also required in the measure_key_capacitance() function to prevent races when the switch is pressed.
When I had a FRAM board turn south, I programmed a Launchpad to erase it and get things going again: fram_bsl.html
Recovering a FRAM Experimenter’s Board
Don Bindner
I had a FRAM experimenter’s board that I lent to a student for use with mspgcc4 and mspdebug. After a few hours of work, my student informed me that the board quit working and mspdebug presented an error about the fuse being blown.
It seemed improbable that the fuse had become blown (which you do by carefully flashing specific values to special addresses in the flash memory), since we were not experimenting with anything remotely related to fuse setting. A few Google searches turned up this thread, http://www.mail-archive.com/mspgcc-users@lists.sourceforge.net/msg10446.html,and TI tech support suggested that I use the Boot-Strap Loader (BSL) to reset the chip http://www.ti.com/lit/ug/slau319a/slau319a.pdf
Since I’ve worked through UART communications with the Launchpad at MSP430 Launchpad, it seemed obvious that the way to recover my FRAM board is to program a Launchpad to access the Flash BSL (detailed in Chapter 3 of the pdf) and give the Mass Erase command.
#include
/* FRAM experimenter Mass Erase application. Invokes the FRAM
* boot-strap loader and gives the the Mass Erase command via
* 9600 bps UART communication, 8 bit data, even parity, 1 stop bit.
* This code requires an external clock crystal for calibration
* of 4 Mhz clock speed, unless you change HAVE_CRYSTAL below.
#define RED_LED BIT0
#define GRN_LED BIT6
#define HAVE_CRYSTAL 1 // Or 0 if you don't have a clock crystal.
#define FRAM_RST BIT4 // Connect Launchpad 1.4 to FRAM RST pin.
#define FRAM_TEST BIT5 // Connect Launchpad 1.5 to FRAM TEST pin.
#define TXD BIT1 // Connect Launchpad 1.1 to FRAM RXD pin.
#define RXD BIT2 // Connect Launchpad 1.2 to FRAM TXD pin.
/* Ticks per bit, and ticks per half. Use the following values
* based on speed: 9600 bps -> 52
#define TPB 52
#define TPH TPB/2
volatile unsigned int parity = 0;
volatile unsigned int TXWord = 0;
volatile unsigned int RXWord = 0;
volatile unsigned int rxbitcnt = 0;
volatile unsigned int txbitcnt = 0;
/* circular buffers for characters received/to send */
#define BSIZE 16 // must be power of 2
volatile unsigned char send_buffer[BSIZE];
volatile unsigned char recv_buffer[BSIZE];
volatile unsigned int sbhead=0, sbtail=0, rbhead=0, rbtail=0,
bytestosend=0, bytesreceived=0;
/* function prototypes */
unsigned char set_dco_c(unsigned int delta);
void initUart( void );
inline void RX_Start( void );
unsigned char RX_Byte( void );
void TX_Byte( unsigned char c );
/* A crude delay function. Tune by changing the constant. */
inline void delay( unsigned int n ) {
volatile unsigned int i = n<<2;
while( i-- ) ;
/* Transition Test then Reset in order */
P1OUT |= FRAM_TEST;
delay(n);
P1OUT |= FRAM_RST;
delay(n);
P1OUT &= ~FRAM_TEST; // final transition starts the BSL
delay(1500);
/* Start listening for data, and enable interrupts, 9600 8E1. */
RX_Start();
/**** Serial is listening from here forward. ****/
__bis_SR_register( GIE );
/* Send the Mass Erase command. */
P1OUT |= RED_LED;
for( i = 0; i < sizeof( erase ); i++ ) {
TX_Byte( erase );
/* Wait for acknowledgement. */
while( ! bytesreceived ) ;
P1OUT |= GRN_LED;
c = RX_Byte();
if( c == 0x00 ) { // Response of 0x00 is success
P1OUT &= ~RED_LED;
for( ; ; ) {
/* go to sleep and wait for data */
/* Pass a delta value to set the DCO speed. Values for delta:
* 244 -> 1 MHz 1220 -> 5 Mhz 2197 -> 9 Mhz 3173 -> 13 Mhz
* 488 -> 2 Mhz 1464 -> 6 Mhz 2441 -> 10 Mhz 3417 -> 14 Mhz
* 732 -> 3 Mhz 1708 -> 7 Mhz 2685 -> 11 Mhz 3662 -> 15 Mhz
* 976 -> 4 Mhz 1953 -> 8 Mhz 2929 -> 12 Mhz 3906 -> 16 Mhz
* General formula:
* floor(x hz / 4096) -> delta
* Return values:
* 0 - DCO set
* 255 - Timeout
* Adapted from code by J. B. Remnant.
unsigned char set_dco_c(unsigned int delta) {
unsigned int Compare, Oldcapture = 0;
int direction=0;
volatile int i;
unsigned char signchg=0;
/* set auxiliary clock to use /8 divider (requires external crystal) */
BCSCTL1 |= DIVA_3;
/* Timer A0 capture positive edge, select input 1, capture mode */
TACCTL0 = CM_1 + CCIS_1 + CAP;
/* Timer A use submain clock, continuous up mode, clear timer */
TACTL = TASSEL_2 + MC_2 + TACLR; // SMCLK, cont-mode, clear
/* loop 10000 times to set clock */
for ( i = 10000; i && (signchg<3); i-- ) {
while (!(CCIFG & TACCTL0)) ; // Wait until capture occurred
TACCTL0 &= ~CCIFG; // Capture occurred, clear flag
Compare = TACCR0; // Get current captured SMCLK
Compare = Compare - Oldcapture; // SMCLK difference
Oldcapture = TACCR0; // Save current captured SMCLK
if (delta == Compare)
break; // If equal, leave the loop
else if (delta < Compare)
DCOCTL--; // DCO is too fast, slow it down
if (DCOCTL == 0xFF) // Did DCO roll under?
if (BCSCTL1 & 0x0f)
BCSCTL1--; // Select lower RSEL
if( direction > 0 ) { // catch for successive direction changes
signchg++; // and increment count when one happens
} else {
signchg=0;
direction = -1;
else
DCOCTL++; // DCO is too slow, speed it up
if (DCOCTL == 0x00) // Did DCO roll over?
if ((BCSCTL1 & 0x0f) != 0x0f)
BCSCTL1++; // Sel higher RSEL
if( direction < 0 ) { // catch for successive direction changes
} else {
signchg=0;
direction = +1;
/* i>0 means that DCO is set correctly -- set return value accordingly */
Compare = (i) ? 0 : 255;
/* delay loop */
for (i = 0; i < 0x4000; i++) ;
return Compare;
void initUart( void ) {
/* Set clock speed to 4 Mhz, no divider. */
#if HAVE_CRYSTAL
set_dco_c( 976 );
#else
/* If no crystal, this setting will probably work. */
BCSCTL1 = CALBC1_1MHZ + 4;
#endif
BCSCTL2 &= ~(DIVS_3);
/* Set timer A to use continuous mode 4 Mhz / 8 = 500 khz. */
TACTL = TASSEL_2 + MC_2 + ID_3;
/* When TXD isn't being used, it should be set to binary 1. */
TACCTL0 = OUT;
/* TXD and RXD set for timer function, RXD input, TXD output */
P1SEL |= TXD + RXD;
P1DIR &= ~ RXD;
P1DIR |= TXD;
/* This continuously sends bits of the TXWord starting from the
* least significant bit (the 0 start bit). One bit is sent every
* time the handler is activated. When the bits run out, a new
* byte is loaded from the data pointer, until bytestosend equals 0.
void TimerA0 (void) __attribute__((interrupt(TIMERA0_VECTOR)));
int i;
if( txbitcnt ) {
/* Send least significant bit, by changing output mode to
* Reset (OUTMOD0|OUTMOD2) for binary 0 and Set (OUTMOD0) for 1. */
if( TXWord & 0x01 ) {
TACCTL0 &= ~OUTMOD2;
} else {
TACCTL0 |= OUTMOD2;
TXWord >>= 1;
txbitcnt --;
/* If there are no bits left, load the next byte */
if( !txbitcnt ) {
if( bytestosend ) {
TXWord = send_buffer[sbtail++];
sbtail &= BSIZE-1;
bytestosend --;
/* Get the parity bit to make even parity. */
parity = 0;
parity = ( parity ^ (TXWord>>i));
parity &= 1;
/* Load next byte with even parity, 1 stop bit 0x200, and shifted
* left to make the start bit. */
TXWord = ( 0x200 | (parity<<8) | TXWord ) << 1;
/* 1 start bit + 8 data bits + 1 parity + 1 stop bit */
txbitcnt = 11;
} else {
/* turn off interrupts if not receiving */
if( ! rxbitcnt ) TACCTL0 &= ~ CCIE;
/* add ticks per bit to trigger again on next bit in stream */
CCR0 += TPB;
/* reset the interrupt flag */
TACCTL0 &= ~CCIFG;
/* Stuffs a byte into the buffer, and schedules it to be sent. */
void TX_Byte( unsigned char c ) {
if( bytestosend < BSIZE ) {
send_buffer[sbhead++] = c;
sbhead &= BSIZE-1;
bytestosend ++;
/* Turn on transmitting if needed. */
if( ! (TACCTL0 & CCIE)) {
/* Start sending after 1 more bit of mark time. */
CCR0 = TAR + TPB;
/* Transmit 1/Mark (OUTMOD0) and enable interrupts */
TACCTL0 = CCIS0 + OUTMOD0 + CCIE;
/* Retrieves a byte from the receive buffer. */
unsigned char RX_Byte( void ) {
unsigned char c = 0;
void TimerA1 (void) __attribute__((interrupt(TIMERA1_VECTOR)));
void TimerA1(void) {
/* If we just caught the 0 start bit, then turn off capture
* mode (it'll be all compares from here forward) and add
* ticks-per-half so we'll catch signals in the middle of
* each bit.
if( TACCTL1 & CAP ) {
/* 9 bits pending = 8 bits + 1 parity */
rxbitcnt = 9;
RXWord = 0;
/* next interrupt in 1.5 bits (i.e. in middle of next bit) */
CCR1 += TPH + TPB;
/* reset capture mode and interrupt flag */
TACCTL1 &= ~ ( CAP + CCIFG );
return;
/* Otherwise we need to catch another bit. We'll shift right
* the currently received data, and add new bits on the left.
RXWord >>= 1;
if( TACCTL1 & SCCI ) {
RXWord |= 0x100;
rxbitcnt --;
/* last bit received */
if( ! rxbitcnt ) {
/* Record this byte and reset for next.
* Put character in circular recv_buffer (unless full).
if( bytesreceived < BSIZE ) {
recv_buffer[rbhead++] = (unsigned char)RXWord;
rbhead &= BSIZE-1;
bytesreceived ++;
/* we're done, reset to capture */
TACCTL1 = SCS + OUTMOD0 + CM1 + CAP + CCIE;
return;
CCR1 += TPB;
TACCTL1 &= ~CCIFG;
This code was designed for a Launchpad board that has the clock crystal soldered in place (since it uses that clock to calibrate the main system clock to 4Mhz instead of the default 1Mhz speed). But if you don’t have a crystal, you can change the value of HAVE_CRYSTAL to 0, and the program will try a "best guess" that will probably work.
On your FRAM board, remove the jumpers from TXD, RXD, RST, and TEST. You’re going to connect the "chip side" of these jumpers to your Launchpad board. On your Launchpad board, remove the TXD and RXD jumpers.
These are the connections to make between the boards:
FRAM TXD to Launchpad RXD (P1.2)
FRAM RXD to Launchpad TXD (P1.1)
FRAM RST to Launchpad P1.4
FRAM TEST to Launchpad P1.5
FRAM Vcc to Launchpad Vcc
FRAM GND to Launchpad GND
Connect the USB cable from your computer to your Launchpad card, and load the program.
$ mspdebug rf2500 "prog fram_bsl.elf"
When the program runs on your Launchpad, you should briefly see the red LED come on. If it was successful, the red LED will go dark and the green LED will remain lit. At that point, your FRAM board should be erased and ready to use again (don’t forget to re-install the jumpers on both boards).
I was asked by someone to provide an elf file, since different compilers can sometimes want slightly different source and syntax. I have generated one and uploaded it. This one is compiled with HAVE_CRYSTAL defined to 0, so it should work on a Launchpad with or without the clock crystal. I believe it will work fine on an msp430g2211, an msp430g2231, or an msp430f2012; perhaps others as well.
Don Bindner
Table of Contents
1. Keypad control
When I was young, I had an electronics kit, and my favorite circuits were the alarms. I burned out one of the transistors in my set, so I couldn’t build the "burglar alarm" for a long time. But, there was a light-activated alarm circuit that I constructed over and over. I eventually learned to substitute another part for my broken transistor, and the burglar alarm came to be as well. I even wired it to the screws in the latch of my door, running the wire down the door jam and under my dresser. It worked great too, until the batteries on the detector circuit ran down at 6am the next morning. The separate siren circuit still had a solid set of batteries, so everyone in the house pretty much got up early.
My 10-year-old daughter is enamored with the idea of an intruder alarm, so I’m back at it with my MSP430. I’m using an msp430g2452 because it has 16 general purpose IO pins, enough to run a keypad plus detector plus piezo speaker plus some status LEDs.
Here’s a picture of the prototype so far:
Components in the picture:
One Radio Shack prototyping board
One Radio Shack 2-AA battery box.
One piezo speaker and transformer from http://www.dealextreme.com/p/wireless-entry-alarm-826
One TI MSP430G2452
One 20-pin DIP socket
One Jameco keypad (part number 2081828)
One 0.1uF capacitor (between Vcc and GND)
One 0.001uF capacitor (between RST and GND)
One 47k ohm resistor (between RST and Vcc)
Two 3mm LEDs (anodes on pins p2.6 and p2.7)
One 100 ohm resistor (between cathodes of LEDs and GND)
One terminal block for power
1. Keypad control
My first tasks were to get the LEDs to light, and to get usable input from the keypad. The LEDs were fairly easy after accounting for one detail. They are hooked to p2.7 and p2.6, but those pins also double as XIN and XOUT (if you use an external clock crystal). Clearing the P2SEL bits for those pins, changes their behavior to standard I/O pins.
They keypad was a bit more work. For one thing, it didn’t come with any kind of data sheet or instructions. So I had to take it apart and follow the traces to see how the 10 wires of the keypad are controlled by the 12 keys. These are the wire connections I discovered:
black — 1 — blue
white — 4 — blue
violet — 7 — blue
black — 2 — green
white — 5 — green
violet — 8 — green
black — 3 — yellow
white — 6 — yellow
gray — 9 — yellow
violet — 0 — yellow
orange — * — red
brown — # — red
They configuration is not as efficient as it could be (3 wires for columns and 4 wires for rows would be better), but it is what it is. I decided to consider the 6 colors on the left of my list to be "supply" wires, and the 4 colors on the right are "receive" wires. I connected blue, green, yellow, and red wires to pins on Port 2, p2.1-p2.4 respectively. That way I can detect keypresses by asserting a voltage on one supply wire and letting that trigger a corresponding interrupt on the Port 2 interrupt handler. The black, white, gray, violet, orange, and brown wires are connected, respectively, to Port 1 pins p1.0-p1.5.
Since I envision this burglar alarm as battery powered, I’d like it to sleep in the lowest power modes as much as possible. For that reason, in the code that follows, I have configured the auxilliary clock to use the Very Low-power Oscillator (VLO), and I trigger the Watchdog timer interrupt from that every 44 milleseconds. The Watchdog interrupt handler charges each of the keypad supply wires briefly (with interrupts re-enabled) so the Port 2 handler can trigger.
For reliability, I chose to use two successive triggers as the definition of a keypress and two successive misses as the definition of a key release. This worked very well. I don’t get accidental "doubles," yet the pad is responsive.
Here’s my first set of sample code. It lights both LEDs, briefly, each time a key is pressed.
#include
// Port 1 connections to the keypad.
#define KEY_BLACK BIT0
#define KEY_WHITE BIT1
#define KEY_GRAY BIT2
#define KEY_VIOLET BIT3
#define KEY_ORANGE BIT4
#define KEY_BROWN BIT5
// Port 2 connections to the keypad.
#define KEY_BLUE BIT1
#define KEY_GREEN BIT2
#define KEY_YELLOW BIT3
#define KEY_RED BIT4
// Port 2 has LED status lights and reed switch.
#define REED_SWITCH BIT0
#define LED_GRN BIT7
#define LED_RED BIT6
// Port 1 has the piezo speaker.
#define SPEAKER0 BIT6
#define SPEAKER1 BIT7
// Set chip to calibrated 1mhz clock rate.
// Set the auxiliary clock to use the VLO. We'll use this to wake up
// via the watchdog and scan for keypresses.
// Set all keys initially to low, but as output pins.
P1OUT &= ~( KEY_BLACK + KEY_WHITE + KEY_GRAY + KEY_VIOLET + KEY_ORANGE + KEY_BROWN );
P1DIR |= KEY_BLACK + KEY_WHITE + KEY_GRAY + KEY_VIOLET + KEY_ORANGE + KEY_BROWN;
// Set piezo leads to low, but as output pins.
P1OUT &= ~( SPEAKER0 + SPEAKER1 );
P1DIR |= SPEAKER0 + SPEAKER1;
// Set LED status lights off, but as output pins.
P2SEL &= ~( LED_GRN + LED_RED );
P2OUT &= ~( LED_GRN + LED_RED );
P2DIR |= LED_GRN + LED_RED;
// Set pull down resistors on port 2 pins that monitor keypad.
P2DIR &= ~( KEY_BLUE + KEY_GREEN + KEY_YELLOW + KEY_RED );
P2OUT &= ~( KEY_BLUE + KEY_GREEN + KEY_YELLOW + KEY_RED );
P2REN |= KEY_BLUE + KEY_GREEN + KEY_YELLOW + KEY_RED;
// Interrupt on rising edges.
P2IES &= ~( KEY_BLUE + KEY_GREEN + KEY_YELLOW + KEY_RED );
// Set pull up resistor on port 2 pin for reed switch.
P2DIR &= ~( REED_SWITCH );
P2OUT |= REED_SWITCH;
P2REN |= REED_SWITCH;
// Interrupt on falling edges.
P2IES |= REED_SWITCH;
// Enable interrupts for all of the port 2 pins we monitor.
P2IE |= KEY_BLUE + KEY_GREEN + KEY_YELLOW + KEY_RED +
REED_SWITCH;
// Set watchdog timer to trigger every 16*32.768k/12k = 44 ms.
// Clear the watchdog timer interrupt flag.
IFG1 &= ~WDTIFG;
// Enable watchdog interrupts.
IE1 |= WDTIE;
/* Do nothing...forever */
for( ; ; ) {
/* Go into low power mode 3, general interrupts enabled */
// Handle key pad symbols.
void do_key( char c ) {
// Visually signify the press by blinking a light (the reset
// happens in the watchdog handler).
P2OUT ^= LED_GRN + LED_RED;
clear_key_light = 1;
void WDT_ISR(void) __attribute__((interrupt(WDT_VECTOR)));
void WDT_ISR(void) {
int i;
// Decrement the counts in key_pending[] and record any key releases.
for( i = 0; i < NUM_KEYS; i++ ) {
if( key_pending ) key_pending--;
if( !key_pending ) key_pressed = 0;
/* Port 2 interrupt service routine. Triggered by presses of
* the keypad or by opening of the reed switch.
void Port_2 (void) __attribute__((interrupt(PORT2_VECTOR)));
void Port_2(void) {
int i;
int mask = 0;
if( P2IFG & p2_color ) { // Check if this color triggered the interrupt.
mask |= p2_color;
if( P1OUT & p1_color ) { // Check if the other color for this key is also on.
if( key_pending && !key_pressed ) {
key_pressed = 1;
do_key( key_symbol );
key_pending = 2; // Remember for next time.
// Clear interrupt flag.
P2IFG &= ~mask;
if( P2IFG & REED_SWITCH ) {
P2IFG &= ~REED_SWITCH;
At this point, I don’t have a reed switch, though there is code there that will eventually trigger on that. I also haven’t made use of the piezo speaker in this code, though it operates on Port 1 pins p1.6 and p1.7.
The key_pending[] array is how the code checks that a key has triggered on two successive interrupts before registering a key press (and how it checks that a key has failed to trigger on two successive timer interrupts for a key release). In Port_2() it is set to 2 each time a key triggers, and in WDT_ISR() it is decremented.
This code was built with msp430-gcc version 4.5.3 and installed:
