2053|0
89
在DS1302上遇到点麻烦,求各位大虾看看程序 [复制链接]
这个是我的DS1302 谁帮我试下,SCLK=P1^0,IO=P1^1,REST=P2^4;数码管段是P3口,位是P2^0-P2^3,可是我显示出来的是1100,不知道怎么回事,帮我改下 谢谢
#include<reg51.h>
#include <intrins.h>
#define uchar unsigned char
#define uint unsigned int
sbit sck=P1^0;
sbit io=P1^1;
sbit rst=P2^4;
sfr P0M0=0X93;
sfr P0M1=0x94;
sfr P1M0=0X91;
sfr P1M1=0x92;
sfr P2M0=0X95;
sfr P2M1=0x96;
unsigned char code smg_du[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0x88,0x83,0xa7,0xa1};//0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71,0x00,0x10};
unsigned char code smg_we[]={0x01,0x02,0x04,0x08};//0x08,0x18,0x28,0x38,0x48,0x58,0x68,0x78};
uchar time_data[]={0,0,0,0};//,11,58,30}; //年周月日时分秒
uchar write_add[7]={0x8c,0x8a,0x88,0x86,0x84,0x82,0x80};
uchar read_add[7]={0x8d,0x8b,0x89,0x87,0x85,0x83,0x81};
uchar disp[4];
void write_ds1302_byte(uchar dat);
void write_ds1302(uchar add,uchar dat);
uchar read_ds1302(uchar add);
void set_rtc(void);
void read_rtc(void);
void time_pros(void);
void display(void);
//延时函数,在12MHz的晶振频率下
//大约50us的延时
void delay_50us(uint t)
 uchar j;
 for(;t>0;t--)
        for(j=19;j>0;j--);
//延时函数,在12MHz的晶振频率下
//大约50ms的延时
void delay_50ms(uint t)
 uint j;
 for(;t>0;t--)
 for(j=6245;j>0;j--);
 uchar i;
 for(i=0;i<8;i++)
  sck=0;
  io=dat&0x01;
  dat=dat>>1;
  sck=1;
 rst=0;
 _nop_();
 sck=0;_nop_();
 rst=1;
 _nop_();
 write_ds1302_byte(add);
 write_ds1302_byte(dat);
 rst=0;
 _nop_();
 io=1;
 sck=1;
 uchar i,value;
 rst=0;
 _nop_();
 sck=0;
 _nop_();
 rst=1;
 _nop_();
 for(i=0;i<8;i++)
  value=value>>1;
  sck=0;
  if(io)
  value=value|0x80;
  sck=1;
 rst=0;
 _nop_();
 sck=0;
 _nop_();
 sck=1;
 io=1;
 return value;
void set_rtc(void)
 uchar i,j;
 for(i=0;i<4;i++)
  j=time_data/10;
  time_data=time_data%10;
  time_data=time_data+j*16;
 write_ds1302(0x8e,0x00); //去除写保护
 for(i=0;i<4;i++)
  write_ds1302(write_add,time_data);
 write_ds1302(0x8e,0x80); //加写保护
void read_rtc(void)
 uchar i;
 for(i=0;i<4;i++)
  time_data=read_ds1302(read_add);
 disp[0]=time_data[4];//%16;
 disp[1]=time_data[4];///16;
 disp[2]=time_data[3];//%16;//16;
 disp[3]=time_data[3];///16;//time_data[5]%16;
/* disp[4]=time_data[5]/16;
 disp[5]=16;
 disp[6]=time_data[4]%16;
 disp[7]=time_data[4]/16;
void display(void)
 uchar i;
 for(i=0;i<4;i++)
 P3=smg_du[disp];
 P2=smg_we;
 delay_50us(20);
void main(void)
// set_rtc();
  P0M0=0X00;
  P0M1=0xff;
  P1M0=0X00;
  P1M1=0xff;
  P2M0=0X00;
  P2M1=0xff;
 while(1)
  read_rtc();
  time_pros();
  display();
此帖出自51单片机论坛
