2792|2
lm3s8962 tcp数据的试验 我是菜鸟 谢谢帮忙 试验现象没有 [复制链接]
#include <string.h>
#include "inc/hw_ints.h"
#include "inc/hw_memmap.h"
#include "inc/hw_nvic.h"
#include "inc/hw_types.h"
#include "inc/hw_sysctl.h"
#include "driverlib/ethernet.h"
#include "driverlib/gpio.h"
#include "driverlib/interrupt.h"
#include "driverlib/sysctl.h"
#include "driverlib/systick.h"
#include "utils/lwiplib.h"
#include "utils/ustdlib.h"
#define My_Mac_ID  {0X00,0x14,0x97,0x0F,0x1D,0xE3}  //存储以太网控制器的物理地址,即MAC地址
#define MY_IP_ID        {192,168,0,100}                   //以太网通信的IP地址
#define IP_MARK_ID    {255,255,255,0}             //255.255.255.0,子网掩码
#define MY_GATEWAY_ID   {192,168,0,1}                     //以太网通信的网关地址
static const unsigned char pucMACAddress[]=My_Mac_ID;
static const unsigned char IPAddress[] = MY_IP_ID;
static const unsigned char NetMaskAddr[] = IP_MARK_ID;
static const unsigned char GwWayAddr[] = MY_GATEWAY_ID;
static const unsigned char TCP_TestData[]="This is LwIP TCP Client 在Luminary Cortex-M3上的测试!\r\n";
#define SYSTICKHZ 100
#define SYSTICKMS (1000 / SYSTICKHZ)
#define SYSTICKUS (1000000 / SYSTICKHZ)
#define SYSTICKNS (1000000000 / SYSTICKHZ)
void Delay(unsigned long ulVal) /* 利用循环产生一定的延时 */
while ( --ulVal != 0 );
err_t TcpCli_Connected(void *arg,struct tcp_pcb *pcb,err_t err)
tcp_write(pcb,TCP_TestData,sizeof(TCP_TestData),0); /* 发送数据 */
tcp_close(pcb);
return ERR_OK;
void TCP_Client_Init()
  struct tcp_pcb *Clipcb;
  struct ip_addr ipaddr;
  IP4_ADDR(&ipaddr,192,168,0,127);
  Clipcb = tcp_new();                       // 建立通信的TCP控制块(Clipcb)
  tcp_bind(Clipcb,IP_ADDR_ANY,1026);       // 绑定本地IP地址和端口号
  tcp_connect(Clipcb,&ipaddr,1026,TcpCli_Connected);
void
SysTickIntHandler(void)
lwIPTimer(SYSTICKMS);
void
enet_udp(void)
   struct ip_addr ulIPAddr,ulNetMask,ulGWAddr;
      if(REVISION_IS_A2)
        SysCtlLDOSet(SYSCTL_LDO_2_75V);
    SysCtlClockSet(SYSCTL_SYSDIV_4 | SYSCTL_USE_PLL | SYSCTL_OSC_MAIN |
                   SYSCTL_XTAL_8MHZ);
    SysCtlPeripheralEnable(SYSCTL_PERIPH_ETH);
    SysCtlPeripheralReset(SYSCTL_PERIPH_ETH);
    SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOF);
    GPIOPinTypeEthernetLED(GPIO_PORTF_BASE, GPIO_PIN_2 | GPIO_PIN_3);
    SysTickPeriodSet(SysCtlClockGet() / SYSTICKHZ);
    SysTickEnable();
    SysTickIntEnable();
    IntMasterEnable();
        IP4_ADDR(&ulIPAddr,IPAddress[3],IPAddress[2],IPAddress[1],IPAddress[0]);
        IP4_ADDR(&ulNetMask,NetMaskAddr[3],NetMaskAddr[2],NetMaskAddr[1],NetMaskAddr[0]);
        IP4_ADDR(&ulGWAddr,GwWayAddr[3],GwWayAddr[2],GwWayAddr[1],GwWayAddr[0]);
        lwIPInit(pucMACAddress,ulIPAddr.addr, ulNetMask.addr, ulGWAddr.addr, IPADDR_USE_STATIC);
while(1)
    TCP_Client_Init();
    SysCtlDelay(SysCtlClockGet()/3);
TcpCli_Connected() 没看到呢  详情 回复 发表于 2012-5-30 08:13
1803
回复 楼主 zyjstrong 的帖子
什么意思啊?那个我程序里面不是有么?  我是菜鸟,你能说明白点么?
福禄克有奖直播:高精度测温赋能电子制造 报名中!
直播时间:2025年2月28日(周五)上午10:00
直播主题:高精度测温赋能电子制造
小伙伴们儿快来报名直播吧~好礼等你拿!
