10388|32
34
今天学习了TI学堂ADC10,写了一个单通道AD转换并通过1602显示的程序 [复制链接]
#include <intrinsics.h>
#include <msp430g2553.h>
#include <msp430.h>
                                                     端口定义
#define LCD_EN_PORT P1OUT    //以下2个要设为同一个口
#define LCD_EN_DDR P1DIR
#define LCD_RS_PORT P1OUT    //以下2个要设为同一个口
#define LCD_RS_DDR P1DIR
#define LCD_DATA_PORT P2OUT  //以下3个要设为同一个口
#define LCD_DATA_DDR P2DIR   //一定要用高4位
#define LCD_RS BIT6
#define LCD_EN BIT7
#define LCD_DATA    BIT7|BIT6|BIT5|BIT4   //4位数据线连接模式
                                                          预定义函数
void LCD_init(void);
void LCD_init_first(void);
void LCD_en_write1(void);  //上升沿使能
void LCD_en_write2(void);  //下降沿使能
void LCD_write_command(unsigned char command);
void LCD_write_data(unsigned char data);
void LCD_set_xy (unsigned char x, unsigned char y);
void LCD_write_string(unsigned char X,unsigned char Y, unsigned char *s);
void LCD_write_char(unsigned char X,unsigned char Y, unsigned char data);
void delay_1ms(void);
void delay_nus(unsigned int n);
void delay_nms(unsigned int n);
void lcd_diaoyong();
void lcd_diaoyong1();
unsigned char LCDBuf1[]={"0123456789"};   //第一行要显示的内容
unsigned char LCDBuf2[]={"DY:.V"};     //第二行要显示的内容
unsigned int j=0,i=0;
unsigned int  shuzhi=0,qushu=0;
                                               主函数
void main()
   WDTCTL = WDTPW + WDTHOLD;     // 关闭看门狗
    ADC10CTL0 = ADC10SHT_2 + ADC10ON + ADC10IE; // ADC10ON, interrupt enabled
    ADC10CTL1 = INCH_1;                         // input A1模拟信号输入选择通道A1即p1.1
    ADC10AE0 |= 0x02;                           // PA.1 ADC option select使p1.1允许AD模拟输入信号
    P1DIR |= 0x01;                              // Set P1.0 to output direction
    LCD_init_first();
    LCD_init();
    TA0CCTL0 = CCIE;                             // CCR0 1ms中断
    TA0CCR0 = 312;
    TA0CTL = TASSEL_2 + MC_1;                  // SMCLK, upmode
    //_BIS_SR(LPM0_bits + GIE);                 // Enter LPM0 w/ interrupt
    TA1CCTL0 = CCIE;                             // CCR0 1ms中断
    TA1CCR0 = 312;
    TA1CTL = TASSEL_2 + MC_1;                  // SMCLK, upmode
    while(1)
    { if(j>100)
       shuzhi=qushu*35/10;
       lcd_diaoyong();
       j=0;
lcd子函数
void lcd_diaoyong()
  LCD_write_char(0,0,LCDBuf2[0]);
  LCD_write_char(1,0,LCDBuf2[1]);
  LCD_write_char(2,0,LCDBuf2[2]);
  i=(shuzhi/1000);
  LCD_write_char(3,0,LCDBuf1);
  LCD_write_char(4,0,LCDBuf2[3]);
  i=(shuzhi-i*1000)/100;
  LCD_write_char(5,0,LCDBuf1);
  i=(shuzhi/10)%10;
  LCD_write_char(6,0,LCDBuf1);
  LCD_write_char(7,0,LCDBuf2[4]);
lcd子函数1
  LCD_write_char(0,1,LCDBuf2[0]);
  LCD_write_char(1,1,LCDBuf2[1]);
  LCD_write_char(2,1,LCDBuf2[2]);
  i=(shuzhi/1000);
  LCD_write_char(3,1,LCDBuf1);
  LCD_write_char(4,1,LCDBuf2[3]);
  LCD_write_char(5,1,LCDBuf1);
  i=(shuzhi/10)%10;
  LCD_write_char(6,1,LCDBuf1);
  LCD_write_char(7,1,LCDBuf2[4]);
定时器Timer0_A
#pragma vector=TIMER0_A0_VECTOR
__interrupt void Timer0_A (void)
  ADC10CTL0 |= ENC + ADC10SC;             // Sampling and conversion start开始转换
        qushu=ADC10MEM;
        j++;
       __bis_SR_register(CPUOFF + GIE);        // LPM0, ADC10_ISR will force exit
       __bic_SR_register_on_exit(CPUOFF);        // Clear CPUOFF bit from 0(SR)
定时器Timer1_A
#pragma vector=TIMER1_A0_VECTOR
__interrupt void Timer1_A (void)
  P1OUT ^= 0x01;
#pragma vector=ADC10_VECTOR
__interrupt void ADC10_ISR(void)
            LCD液晶操作函数
void LCD_init_first(void)         //LCD1602液晶初始化函数(热启动)
        delay_nms(500);
     LCD_DATA_DDR|=LCD_DATA;   //数据口方向为输出
     LCD_EN_DDR|=LCD_EN;       //设置EN方向为输出
     LCD_RS_DDR|=LCD_RS;       //设置RS方向为输出
        delay_nms(50);
        LCD_write_command(0x30);
        delay_nms(50);
        delay_nms(5);
        delay_nms(500);
 *             LCD1602液晶初始化函数
void LCD_init(void)
 delay_nms(500);
 delay_nms(500);
 LCD_write_command(0x28);  //4位数据接口
 delay_nms(50);
 delay_nms(50);
 delay_nms(50);
    LCD_en_write2();
    delay_nms(50);
 delay_nms(500);
 LCD_write_command(0x01); //清屏
 LCD_write_command(0x0c); //显示开,关光标,不闪烁
    LCD_write_command(0x06); //设定输入方式,增量不移位
 delay_nms(50);
 *             液晶使能上升沿
    LCD_EN_PORT&=~LCD_EN;
    delay_nus(10);
    LCD_EN_PORT|=LCD_EN;
 *             液晶使能下降沿
   delay_nus(10);
 *               写指令函数
   delay_nus(16);
   P2SEL=0x00;
   LCD_RS_PORT&=~LCD_RS; //RS=0
   LCD_en_write1();
   LCD_DATA_PORT&=0X0f; //清高四位
   LCD_DATA_PORT|=command&0xf0; //写高四位
   delay_nus(16);
   LCD_en_write2();
   command=command<<4; //低四位移到高四位
   LCD_en_write1();
   LCD_DATA_PORT&=0x0f; //清高四位
   LCD_DATA_PORT|=command&0xf0; //写低四位
   LCD_en_write2();
 *               写数据函数
   delay_nus(16);
   P2SEL=0x00;
   LCD_RS_PORT|=LCD_RS;      //RS=1
   LCD_en_write1();          //E上升沿
   LCD_DATA_PORT|=data&0xf0; //写高四位
   delay_nus(16);
   LCD_en_write2();
   data=data<<4;             //低四位移到高四位
   LCD_en_write1();
   LCD_DATA_PORT|=data&0xf0; //写低四位
   LCD_en_write2();
 *               写地址函数
void LCD_set_xy( unsigned char x, unsigned char y )
   unsigned char address;
   if (y == 0) address = 0x80 + x;
   else address = 0xc0 + x;
   LCD_write_command( address);
 *LCD在任意位置写字符串,列x=0~15,行y=0,1
void LCD_write_string(unsigned char X,unsigned char Y,unsigned char *s)
 LCD_set_xy( X, Y ); //写地址
    while (*s)          //写显示字符
      LCD_write_data( *s );
      s++;
 *     LCD在任意位置写字符,列x=0~15,行y=0,1
void LCD_write_char(unsigned char X,unsigned char Y,unsigned char data)
   LCD_write_data( data);
 *               1us延时函数
void delay_1us(void)
   asm("nop");
 *               N us延时函数
   unsigned int i;
   for (i=0;i<n;i++)
   delay_1us();
 *               1ms延时函数
   unsigned int i;
   for (i=0;i<1140;i++);
 *               N ms延时函数
   unsigned int i=0;
   for (i=0;i<n;i++)
   delay_1ms();
这个程序大家可以参考一下,结果是对的,但我觉得方法可能有点问题。
屌爆了  详情 回复 发表于 2014-7-22 17:25
唔唔~~  详情 回复 发表于 2012-7-25 14:01
为什么要用AD转换呢?不是直接可以接1602然后就可以演示了吗??  详情 回复 发表于 2012-7-19 10:53
unsigned char LCDBuf1[]={\"0123456789\"}; LCD_write_char(3,1,LCDBuf1); 这个貌似会报错吧  详情 回复 发表于 2012-7-18 22:30
问题上没有,就是要的IO口太多了  详情 回复 发表于 2012-7-17 11:13
请教一下,你的430和1602是直接传信的吗?为什么我的430和12864直接传送指令无法显示?是电平的原因吗?  详情 回复 发表于 2012-7-15 15:16
点赞 关注(1)
2057
很不错啊!!
学习了
xuexila
216
给力啊楼主!
还有,弱弱的问一句,我的浏览器怎么看不了视频啊???
216
哈哈,回完帖瞬间就可以咯,之前一直看不了啊。看来回帖有好处啊!!!
34
回复 5楼 千里千寻 的帖子
看不了什么视频?是咱们TI大学堂的视频吗?还是普通的网页视频
216
回复 7楼 董宝君 的帖子
嗯嗯,是TI大学堂的视频,之前一直看不了,现在已经能看咯!!!
31
参考一下~
回复 楼主 董宝君 的帖子
回复 楼主 董宝君 的帖子
问题上没有,就是要的IO口太多了
那lcd怎么和单片机端口接啊??有图没有啊 、???
38
回复 楼主 董宝君 的帖子
unsigned char LCDBuf1[]={"0123456789"};       LCD_write_char(3,1,LCDBuf1); 这个貌似会报错吧
怎么改啊  详情 回复 发表于 2013-8-11 21:20
我来学习~~~~
36
回复 楼主 董宝君 的帖子
是单通道单次转换还是多次 怎么没见设置呢
没见设置的就是用的默认设置的  详情 回复 发表于 2012-8-2 22:44
有个问题就是,用直流电源输入,输出十分不稳定啊
那个怎么看啊? 我进去了有的看不了啊
学习ax
好东西正好学习一下感谢楼主
