3001|3
9B96屏幕怎么改变显示方向啊 [复制链接]
9B96屏幕怎么改变上下显示方向啊
在drivers/kitronix320x240x16_ssd2119_8bit.c中修改如下的宏,就可以改变显示的方向了。//***************************************************************************** // // This driver operates in four different screen orientations. They are: // // * Portrait - The screen is taller than it is wide, and the flex connector is // on the left of the display. This is selected by defining // PORTRAIT. // // * Landscape - The screen is wider than it is tall, and the flex connector is // on the bottom of the display. This is selected by defining // LANDSCAPE. // // * Portrait flip - The screen is taller than it is wide, and the flex // connector is on the right of the display. This is // selected by defining PORTRAIT_FLIP. // // * Landscape flip - The screen is wider than it is tall, and the flex // connector is on the top of the display. This is // selected by defining LANDSCAPE_FLIP. // // These can also be imagined in terms of screen rotation; if portrait mode is // 0 degrees of screen rotation, landscape is 90 degrees of counter-clockwise // rotation, portrait flip is 180 degrees of rotation, and landscape flip is // 270 degress of counter-clockwise rotation. // // If no screen orientation is selected, "landscape flip" mode will be used. // //***************************************************************************** #if ! defined(PORTRAIT) && ! defined(PORTRAIT_FLIP) && \ ! defined(LANDSCAPE) && ! defined(LANDSCAPE_FLIP) #define LANDSCAPE_FLIP #endif  详情 回复 发表于 2012-5-23 19:58
1803
回复 楼主 wzp2007 的帖子
需要对 LCD 控制器的驱动比较熟悉,不过不知道 LCD 控制器有没有这样的寄存器。
否则就比较麻烦一点。
回复 沙发 Study_Stellaris 的帖子
修改驱动上面的一个宏定义就OK了
245
// PORTRAIT.
// LANDSCAPE.
#endif
个人签名学习靠的就是努力,靠的就是坚持……
