2705|1
256
quartus仿真的问题 [复制链接]
Warning (10631): VHDL Process Statement warning at rams.vhd(35): inferring latch(es) for signal or variable "dout", which holds its previous value in one or more paths through the process
Warning (10631): VHDL Process Statement warning at Vhdl2.vhd(29): inferring latch(es) for signal or variable "dout1", which holds its previous value in one or more paths through the process
Warning: Found pins functioning as undefined clocks and/or memory enables
Warning: Circuit may not operate. Detected 201 non-operational path(s) clocked by clock "clk" with clock skew larger than data delay. See Compilation Report for details.
我编辑的是一个存储矩阵,但是出现以上警告,况且仿真的时候,不能改变他的输入波形,
请各位大侠指教,
此帖出自FPGA/CPLD论坛
看你WARNING可以知道:     你CLK 不是专用管脚,导致CLK是非法路径,可能造成电路不工作,原因CLK抖动太大!    DOUT,DOUT1输出没有变化。说明这个两个输出没有用!  详情 回复 发表于 2012-5-25 13:30
6892
看你WARNING可以知道:
此帖出自FPGA/CPLD论坛
个人签名一个为理想不懈前进的人,一个永不言败人!
欢迎光临网上店铺!
