5042|0
29
STM32-RTC-报警中断 中断无法进入 [复制链接]
不知道是哪里配置的问题,老是进入去中断
中断函数随便写了一个,代码没贴出来
初始化配置RTC_Config()
配置如下:
/*初次进入RTC配置*/
void RTC_Configuration(void)
 RCC_APB1PeriphClockCmd(RCC_APB1Periph_PWR,ENABLE);   //开启PWR时钟
 RCC_APB1PeriphClockCmd(RCC_APB1Periph_BKP,ENABLE);   //开启BKP时钟
 PWR_BackupAccessCmd(ENABLE);        //开启RTC和后备寄存器的访问
 BKP_DeInit();
 RCC_LSEConfig(RCC_LSE_ON);         //设置外部低速晶振
 while(RESET == RCC_GetFlagStatus(RCC_FLAG_LSERDY))   //等待时钟稳定
 RCC_RTCCLKConfig(RCC_RTCCLKSource_LSE);      //设置LSE为RTC时钟
 RCC_RTCCLKCmd(ENABLE);          //使能RTC时钟
 RTC_WaitForSynchro();          //等待时钟与APB1时钟同步
 RTC_WaitForLastTask();          //等待最近一次对RTC寄存器的操作完成
 RTC_SetPrescaler(32767);         //设置RTC的预分频值
 RTC_SetAlarm(RTC_GetCounter() + 10);           //设置闹铃的值
 RTC_ITConfig(RTC_IT_ALR,ENABLE);        //设置闹铃中断
void RTC_Config(void)
 if(0xA5A5 != BKP_ReadBackupRegister(BKP_DR1))
  RTC_Configuration();
  BKP_WriteBackupRegister(BKP_DR1,0xA5A5);
 }else
  if(RESET != RCC_GetFlagStatus(RCC_FLAG_LPWRRST))  //如果低功耗复位
  if(RESET != RCC_GetFlagStatus(RCC_FLAG_PINRST))   //如果wakeup复位
  RCC_ClearFlag();
中断配置:
void NVIC_Configuration(void)
 NVIC_InitTypeDef NVIC_InitStruction;
 EXTI_InitTypeDef EXTI_InitStructure;
#ifdef VECT_TAB_RAM
 NVIC_SetVectorTable(NVIC_VectTab_RAM,0x0);
#else
 NVIC_SetVectorTable(NVIC_VectTab_FLASH,0x0);
#endif //VECT_TAB_RAM
 NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);
 NVIC_InitStruction.NVIC_IRQChannel = RTCAlarm_IRQn;
 NVIC_InitStruction.NVIC_IRQChannelPreemptionPriority = 0;
 NVIC_InitStruction.NVIC_IRQChannelSubPriority = 1;
 NVIC_InitStruction.NVIC_IRQChannelCmd = ENABLE;
 NVIC_Init(&NVIC_InitStruction);
 EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt;
 EXTI_InitStructure.EXTI_Line = EXTI_Line17;
 EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Rising;
 EXTI_InitStructure.EXTI_LineCmd = ENABLE;
 EXTI_Init(&EXTI_InitStructure);
此帖出自stm32/stm8论坛
