2376|5
151
IAR的问题! [复制链接]
急,请教了!
程序写好了,之前用MSP430F2132写的,调试完全ok,但是转用芯片MSP430G2201后,调试的时候设置断点居然跳出提示:
Could not run device(to breakpoint).
请问这是为什么呢?
151
自己先顶起来,请教高手啊!
151
这是我写的识别和单击和双击的程序,发现MCU老是会reset, 跑不下去,不知道为什么,求高手指教!
void Task_PortMonitor(void)
  switch(ClickvalueTemp)
  default:
      break;
  case NOCLICK:
      if(!(P1IN & BIT3))
        if(PortAction == KEEPACTION)
          PortAction = SWITCHACTION;
          PortCounter = 0u;
          Standbycounter = 0u;
        if(PortAction == SWITCHACTION)
          if(PortCounter > 5000u)
            ClickvalueTemp = SINGLECLICK;
          Standbycounter ++;
          PortCounter = 0u;
      else
        PortAction = KEEPACTION;
        PortCounter = 0u;
      break;
  case SINGLECLICK:
      if(!(P1IN & BIT3))
        if(PortAction == RETURNACTION)
        else if(PortAction == KEEPACTION)
          PortAction = TWICESWITCHACTION;
          PortCounter = 0u;
          //Standbycounter = 0u;// ?
        else if(PortAction == TWICESWITCHACTION)
            ClickvalueTemp = DOUBLECLICK;
          Standbycounter ++;
          PortCounter = 0u;
      else
          PortAction = RETURNACTION;
          SingleclickCounter = 0u;
          PortCounter = 0u;
        else if(PortAction == RETURNACTION)
            PortAction = KEEPACTION;       /* First click is finished */
          if(SingleclickCounter > 9u)
            Clickvalue = SINGLECLICK;      /* After single-click, wait for 500ms to confirm single-click */
            ClickvalueTemp = NOCLICK;      /* Wait for 500ms, no action on switch, return to initial status */
          SingleclickCounter ++;
          Standbycounter ++;
          PortCounter = 0u;
      break;
  case DOUBLECLICK:
      if(!(P1IN & BIT3))
          Standbycounter ++;
          PortCounter = 0u;
      else
          PortCounter = 0u;
            Clickvalue = DOUBLECLICK;
          Standbycounter ++;
          PortCounter = 0u;
      break;
151
程序运行到PortAction = RETURNACTION;的时候,就是按键第一次按下,抬起的时候,高手能帮忙看下么,大概就在这个时候单片机就reset了。
151
版主,大神,江湖救急啊!
151
先提示could not single step device, 然后MCU就reset了!
直播时间:3月12日(周三)上午10:00
直播奖励:多功能榨汁机、蓝牙音箱、手机支架
