2142|0
F1232串口中断接收 [复制链接]
通过串口接收一包数据(5字节),结果总出差,如果一个一个接收就正常,代码:
1.485初始化
void init485(void)
 UCTL0 = CHAR;                         // 8-bit character
   UTCTL0 = SSEL0;                       // UCLK = ACLK
   UBR00 = 0x03;                         // 32k/9600
   UBR10 = 0;
   UMCTL0 = 0x4a;
   ME2 |=  URXE0;
   IE2 |= URXIE0;
2.485中断接收一包数据
#pragma vector = UART0RX_VECTOR
__interrupt void r485(void)
  for(cycle = 0;cycle < 5;cycle ++)
  {rxbuf[cycle] = RXBUF0; }
  cycle = 0;
