3258|5
在做毕设,硬件电路以及程序如下。但是液晶显示无变化。求指导修改 [复制链接]
#include"reg51.h"
#include"stdio.h"
#define uchar unsigned char
#define uint unsigned int
#define LCM_data P0
sbit lcd_flag=P0^7;
sbit AD0832do=P1^0;
sbit AD0832cs=P1^1;
sbit AD0832clk=P1^2;
sbit LCM_RS=P2^0;
sbit LCM_RW=P2^1;
sbit LCM_E=P2^2;
sbit TLC5615_SCLK=P2^3;
sbit TLC5615_CS=P2^4;
sbit TLC5615_DIN=P2^5;
uchar H;
uchar dis1[16];
uchar dis2[16]={"Temp:"};
void delay(uchar m)
uint i;
for(i=0;ix[n+1])
p=x[n];
x[n]=x[n+1];
x[n+1]=p;
float ZZLB()
uchar m,n;
uchar arrx[5]={0},arry[5]={0};   //
float p;
for(m=0;m<5;m++)
H=0;
arrx[m]=tlccread();
delay(2);
for(n=0;n<5;n++)
H=1;
arry[n]=tlccread();
PAIXU(arrx);
PAIXU(arry);
p=TBC(arrx[2],arry[2]);
return(p);
uint zxh(float a)     //线性化子程序
uint T;
float k1=25.445,k2=24.549,k3=25.786,k4=26.123,k5=26.596,k6=27.278;//标度变换求温度
if(a<28.456) T=700+(uint)(k1*(a-24.526));
else if(a<32.370) T=800+(uint)(k2*(a-28.456));
else if(a<36.248) T=900+(uint)(k3*(a-32.370));
else if(a<40.076) T=1000+(uint)(k4*(a-36.248));
else if(a<43.836) T=1100+(uint)(k5*(a-41.966));
else T=1200+(uint)(k6*(a-43.836)+14);
return(T);
bit lcd_busy()        //RS=Low,RW=High,E=High:读状态
{ //判断是否忙碌函数
        bit flag;
   LCM_RS=0;        //寄存器为Low
        LCM_RW=1;        //是否读写为High
        LCM_E=1;        //使能端为High
        if (lcd_flag==1) flag=1;
        else flag=0;
        LCM_E=0;
        return(flag);        //返回标志,判断是否LCD忙碌
void lcd_putcommand(uchar command)                                  //RS=Low,RW=Low,E=High:写指令
{ //写指令函数
        while (lcd_busy());                                                          //判断是否忙碌
        LCM_RS=0;
        LCM_RW=0;
        LCM_E=0;        //置E=low
        LCM_data=command;                                                          //输入指令
        LCM_E=1;        //置E=High
        LCM_E=0;
void lcd_putchar(uchar putchar)                                          //RS=High,RW=Low,E=High:写数据
{ //写数据函数
        while(lcd_busy());                                                          //判断是否忙碌
        LCM_RS=1;
        LCM_RW=0;
        LCM_E=0;        //置E=Low
        LCM_data=putchar;                                                          //输入数据
        LCM_E=1;        //置E=High
        LCM_E=0;
void lcd_moveto(uchar x, uchar y)                                  //第X行Y列(X=1 or 2,Y=1-16)
{ //设计输入位置函数
        if ((x-1)==0) lcd_putcommand(0x80|y-1);                   //判断是否第一行,并设计为第Y列
        if ((x-1)==1) lcd_putcommand(0xc0|y-1);                                  //判断是否第二行,并设计为第Y列
void lcd_delay(unsigned char t)
{ //设计延时函数
        unsigned int i;
        for(;t>0;t--)
                for(i=0;i<124;i++);
void lcd_init(void)
        lcd_putcommand(0x38);                                                  //LCD为2行,5×7字
        lcd_delay(1);
        lcd_putcommand(0x0c);                                                  //打开显示,显示光标
        lcd_delay(1);
        lcd_putcommand(0x06);                                                  //光标右移,字符不动
        lcd_delay(1);
void lcd_display(uchar *sztext1,uchar *sztext2)
{  uchar m;
   lcd_moveto(1,1);                                                  //光标至第1行第1列
                m=0;
                while(sztext1[m]!='\0')
                        lcd_putchar(sztext1[m]);                                  //写数据
                        m++;
                        lcd_delay(30);
            lcd_moveto(2,1);                                                  //光标至第2行第1列
                m=0;
                while(sztext2[m]!='\0')
                        lcd_putchar(sztext2[m]);                                  //写数据
                        m++;
                        lcd_delay(30);
                //lcd_putcommand(0x01);                                //清屏
void main(void)
   uchar a;
   uint b;
   lcd_init();
while(1)
a=ZZLB();
b=zxh(a);
if((b<0)||(b>1200))
dis1[2]='b';
dis1[3]='a';
dis1[4]='d';
dis1[0]='w';
dis1[1]='d';
if((b>=0)&&(b<=1200))
dis1[2]=':';
dis1[3]=(b%1000)/100+0x30;
dis1[4]=(b%100)/10+0x30;
dis1[5]=(b%10)+0x30;
dis1[6]='C';
lcd_display(dis2,dis1);
[ 本帖最后由 zhanghao8911 于 2012-5-6 10:43 编辑 ]
此帖出自单片机论坛
void delay(uchar m) { uint i; for(i=0;ix[n+1]) { p=x[n]; x[n]=x[n+1]; x[n+1]=p; } } 延时程序有问题,不知道是你上传错了还是本来就写错了  详情 回复 发表于 2012-5-6 15:18
77
void delay(uchar m)
uint i;
for(i=0;ix[n+1])
p=x[n];
x[n]=x[n+1];
x[n+1]=p;
此帖出自单片机论坛
回复 沙发 seasky208 的帖子
这个是真心上传的时候传错了。
void delay(uchar m)
uint i;
for(i=0;i }
这段是延时。
此帖出自单片机论坛
回复 沙发 seasky208 的帖子
void delay(uchar m)
uint i;
for(i=0;i }
此帖出自单片机论坛
回复 沙发 seasky208 的帖子
Void  delay (uchar  m)
   uint i;
  for(i=0;i }
此帖出自单片机论坛
回复 沙发 seasky208 的帖子
这是什么个情况啊?void delay(uchar m){ uint i; for(  i=0;i <  m;  i++);}
此帖出自单片机论坛
