3340|0
2606
CODE_SECTION pragma [复制链接]
The CODE_SECTION pragma allocates space for the func in a section named section name. The CODE_SECTION pragma is useful if you have code objects that you want to link into an area separate from the .text section.
The syntax of the pragma in C is:
#pragma CODE_SECTION (func, "section name")
The syntax of the pragma in C++ is:
#pragma CODE_SECTION ("section name")
The following example demonstrates the use of the CODE_SECTION pragma.
Using the CODE_SECTION Pragma
a)  C source file
char bufferA[80];
char bufferB[80];
#pragma CODE_SECTION(funcA, "codeA")
char funcA(int i);
char funcB(int i);
void main()
 char c;
 c = funcA(1);
 c = funcB(2);
char funcA (int i)
 return bufferA;
char funcB (int j)
 return bufferB[j];
b)  Assembly source file
.sect   ".text"
        .global _main
;* FNAME: _main                         FR SIZE:   2           *
;* FUNCTION ENVIRONMENT                                        *
;* FUNCTION PROPERTIES                                         *
;*                            0 Parameter,  1 Auto,  0 SOE     *
_main:
        ADDB      SP,#2
        MOVB      AL,#1                 ; |12|
        LCR       #_funcA               ; |12|
        ; call occurs [#_funcA] ; |12|
        MOV       *-SP[1],AL            ; |12|
        MOVB      AL,#1                 ; |13|
        LCR       #_funcB               ; |13|
        ; call occurs [#_funcB] ; |13|
        MOV       *-SP[1],AL            ; |13|
        SUBB      SP,#2
        LRETR
       ; return occurs
.sect   "codeA"
        .global _funcA
;* FNAME: _funcA                        FR SIZE:   1           *
_funcA:
        ADDB      SP,#1
        MOV       *-SP[1],AL            ; |17|
        MOVZ      AR6,*-SP[1]           ; |18|
        ADD       AR6,#_bufferA         ; |18|
        SUBB      SP,#1                 ; |18|
        MOV       AL,*+XAR6[0]          ; |18|
        LRETR
        ;return occurs
         .sect   ".text"
         .global _funcB
;* FNAME: _funcB                        FR SIZE:   1           *
_funcB:
        ADDB      SP,#1
        MOV       *-SP[1],AL            ; |22|
        MOVZ      AR6,*-SP[1]           ; |23|
        ADD       AR6,#_bufferB         ; |23|
        SUBB      SP,#1                 ; |23|
        MOV       AL,*+XAR6[0]          ; |23|
        LRETR
        ;return occurs
