5448|2
ISE11.1 支持modelsim 10.0么? [复制链接]
ISE11.1是2009年的,MODELSIM10.0是2011年的,库貌似不能编译
Processing command line ...
Reading the compxlib configuration file - 'F:\FPGA\ISE\bin\nt\compxlib.cfg' ...
Library Source Paths => 'F:/FPGA/ISE'
Current Working Directory => 'F:\FPGA\ISE\bin\nt'
Compilation Mode = FAST
Execute Mode = ON
Scheduling library installation & compilation for architectures: all
Scheduling library installation & compilation for libraries: all
Signature:-
compxlib -s mti_se -cfg F:\FPGA\ISE\bin\nt\compxlib.cfg -log F:\FPGA\ISE\bin\nt\compxlib.log -l all -arch all -lib all -w
ERROR:Compxlib - Compxlib does not support mti_se version 6.4a or prior releases. Parsing through the path setting on your system we have identified that you are using mti_se '2011.07'.
Please contact Mentor Graphics to upgrade to a supported simulator version. If the path setting is incorrect, please ensure that you are pointing to the latest version and re-invoke compxlib.
The list of supported simulator versions are listed in the Simulation Chapter of the Synthesis and Simulation Design Guide on http://www.xilinx.com.
Simulator 'mti_se' is ignored.
求解?如果不行的话换哪个版本的modelsim
此帖出自FPGA/CPLD论坛
你好,请问解决了没 我也遇到这个问题了  详情 回复 发表于 2019-3-9 11:45
6892
还有这问题。应该不会啊,不过我从没用这么高级的版本
此帖出自FPGA/CPLD论坛
个人签名一个为理想不懈前进的人,一个永不言败人!
欢迎光临网上店铺!
你好,请问解决了没
我也遇到这个问题了
此帖出自FPGA/CPLD论坛
