2961|0
急急急.各位大神,小弟的需要帮助 [复制链接]
Loader: One or more sections of your program falls into a memory region that is not writable.  These regions will not actually be written to the target.  Check your linker configuration and/or memory map.
Error:  EMIF: Access 0x16540 is an access to a reserved area Requestor is Program Memory Controller
这个是在编译通过后  load的后  go main的时候出现的错误
