PIC16F877与ds1302驱动程序????用12864显示,protues仿真
#include
#define uchar unsigned char
#define uint unsigned int
#define nop() asm("nop")
#define ds1302_sec_add 0x80 //秒数据地址
#define ds1302_min_add 0x82 //分数据地址
#define ds1302_hr_add 0x84 //时数据地址
#define ds1302_date_add 0x86 //日数据地址
#define ds1302_month_add 0x88 //月数据地址
#define ds1302_day_add 0x8a //星期数据地址
#define ds1302_year_add 0x8c //年数据地址
#define ds1302_control_add 0x8e //控制数据地址 写保护
#define ds1302_charger_add 0x90 //充电
#define ds1302_clkburst_add 0xbe //突发
#define cs1 RB7
#define cs2 RB6
#define rs RB5
#define rw RB4
#define e RB3
#define lcd RC
//sbit sck=P3^6;
//sbit sda=P3^4;
//sbit rest=P3^5;
#define rest RA4
#define sda RE0
#define sck RE1
//#define RST_DIR TRISE2
#define DATA_DIR TRISE0
//#define SCLK_DIR TRISE1
void busy_wait();
void setpos(uchar row , uchar col);
void write_com(uchar i);
void write_data(uchar i);
void disp1(uchar *hz);
void disp2(uchar *hz);
void init();
void delay(uchar i);
void select(uchar x);
void Display_font(uchar Choose,uchar Row,uchar Col,uchar *num);
void Display_num(uchar Choose,uchar Row,uchar Col,uchar *num);
void delay(uchar i)
uchar x,y;
for(x=i;x--;x>0)
for(y=110;y--;y>0);
uchar t[]={11,3,3,18,51,55,2};
uchar a[8],b[7];
//显示字体
select(Choose);
Col=Col*8;
setpos(Row,Col);
disp1(num);
setpos(Row+1,Col); //下一页
disp2(num);
//显示数字或字母
uchar i,j;
select(Choose);
Col=Col*8;
setpos(Row,Col);
for(i=0;i<8;i++)
write_data(*(num+i));
setpos(Row+1,Col);
for(j=8;j<16;j++)
write_data(*(num+j));
void ClearScreen(uchar Screen)
uchar i,j;
for(i=0;i<8;i++)
{setpos(i,0);
for(j=0;j<64;j++)
write_data(0x00);
//按列取,且字符是倒着的,第二排是第一排的,显示汉字
// 0(0) 1(1) 2(2) 3(3) 4(4) 5(5) 6(6) 7(7) 8(8) 9(9)
uchar fenhao[16]={0x00,0x00,0x00,0xC0,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x30,0x30,0x00,0x00,0x00};/*":",0*/
uchar num_0[16]={0x00,0xE0,0x10,0x08,0x08,0x10,0xE0,0x00,0x00,0x0F,0x10,0x20,0x20,0x10,0x0F,0x00};/*"0",0*/
uchar num_1[16]={0x00,0x10,0x10,0xF8,0x00,0x00,0x00,0x00,0x00,0x20,0x20,0x3F,0x20,0x20,0x00,0x00};/*"1",1*/
uchar num_2[16]={0x00,0x70,0x08,0x08,0x08,0x88,0x70,0x00,0x00,0x30,0x28,0x24,0x22,0x21,0x30,0x00};/*"2",2*/
uchar num_3[16]={0x00,0x30,0x08,0x88,0x88,0x48,0x30,0x00,0x00,0x18,0x20,0x20,0x20,0x11,0x0E,0x00};/*"3",3*/
uchar num_4[16]={0x00,0x00,0xC0,0x20,0x10,0xF8,0x00,0x00,0x00,0x07,0x04,0x24,0x24,0x3F,0x24,0x00};/*"4",4*/
uchar num_5[16]={0x00,0xF8,0x08,0x88,0x88,0x08,0x08,0x00,0x00,0x19,0x21,0x20,0x20,0x11,0x0E,0x00};/*"5",5*/
uchar num_6[16]={0x00,0xE0,0x10,0x88,0x88,0x18,0x00,0x00,0x00,0x0F,0x11,0x20,0x20,0x11,0x0E,0x00};/*"6",6*/
uchar num_7[16]={0x00,0x38,0x08,0x08,0xC8,0x38,0x08,0x00,0x00,0x00,0x00,0x3F,0x00,0x00,0x00,0x00};/*"7",7*/
uchar num_8[16]={0x00,0x70,0x88,0x08,0x08,0x88,0x70,0x00,0x00,0x1C,0x22,0x21,0x21,0x22,0x1C,0x00};/*"8",8*/
uchar num_9[16]={0x00,0xE0,0x10,0x08,0x08,0x10,0xE0,0x00,0x00,0x00,0x31,0x22,0x22,0x11,0x0F,0x00};/*"9",9*/
uchar num_10[16]={0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff};
uchar *p[]={num_0,num_1,num_2,num_3,num_4,num_5,num_6,num_7,num_8,num_9,num_10};
/*显示字符*/
//uchar zifu[]="123";
void busy_wait()
e = 1;
rs = 0;
rw = 1;
PORTC = 0x00;
while(PORTC&0x80);
e=0;
void write_com(uchar i) //输入控制字,
busy_wait();
//rw=1;
rs=0;
//PORTC=0x00;
e=1;
//do{ACC=lcd; //是否忙
// e=0; }
//while(busy);
//delay(5);
e=0;
rw=0;
PORTC=i;
//delay(1);
//busy_wait();
e=1;
//delay(5);
e=0;
void write_data(uchar i) //输入数据,
busy_wait();
//rw=1;
//rs=0;
//PORTC=0;
e=1;
//do{ACC=lcd;
// e=0;}
//while(busy);
//delay(5);
e=0;
rw=0;
rs=1;
PORTC=i;
//delay(1);
//busy_wait();
e=1;
//delay(5);
e=0;
void setpos(uchar row , uchar col) //选择行(8行),列(左右各64列),
write_com(0xb8+row);
write_com(0x40+col);
void lcd_init(void) //初始化
write_com(0xc0);
write_com(0x3f);
void disp1(uchar *hz) //显示汉字上半区,
uchar i;
for(i=0;i<16;i++)
write_data(*(hz+i));
void disp2(uchar *hz) //显示汉字下半区 ,
uchar i;
for(i=16;i<32;i++)
{ switch(x)
case 0: cs1=0;cs2=0;break; //全屏
case 1: cs1=0;cs2=1;break; //左屏,
case 2: cs1=1;cs2=0;break; //右屏,
//default:cs2=0;cs2=0;
uchar readbyte()
uchar i,num;
DATA_DIR=1;
for(i=0;i<8;i++)
num >>=0x01;
if(sda)num|=0x80;
sck=1;
nop();nop();nop();
sck=0;
nop();nop();nop();
return num;
void writebyte(uchar addr)
uchar i;
DATA_DIR=0;
for(i=0;i<8;i++)
if(addr & 0x01)sda=1;
else sda=0;
sck=1;;
nop();nop();nop();
sck=0;
nop();nop();nop();
addr >>=0x01;
uchar read(uchar addr)
uchar num;
rest=1;
writebyte(addr);
num=readbyte();
nop();nop();nop();nop();nop();nop();
rest=0;
nop();nop();nop();
return num;
void write(uchar addr,uchar num)
rest=1;
writebyte(addr);
writebyte(num);
rest=0;
nop();nop();nop();
void init()
TRISB=0x00;
TRISA=0x00;
TRISC=0x00;
TRISE1=0;
TRISE2=0;
TRISE0=0;
PORTA=0x0f;
TRISD=0x0f;
sck=0;
rest=0;
sda=0;
void readtime()
uchar i,temp;
t[3]=read(ds1302_hr_add+1);//hour
t[4]=read(ds1302_min_add+1);//min
t[5]=read(ds1302_sec_add+1);//sec
for(i=3;i<6;i++)
temp=t/16;
t=temp*10+t%16;
void writetime()
uchar i,temp;
for(i=0;i<7;i++) //十进制转BCD码
temp=t/10;
b=temp*16+t%10;
write(ds1302_control_add,0x00); //关写保护
write(ds1302_sec_add,0x80); //暂停
// write(ds1302_charger_add,0xa9); //充电
write(ds1302_year_add,b[0]); //年
write(ds1302_month_add,b[1]); //月
write(ds1302_day_add,b[2]); //日
write(ds1302_hr_add,b[3]); //时
write(ds1302_min_add,b[4]); //分
write(ds1302_sec_add,b[5]); //秒
write(ds1302_date_add,b[6]); //周
write(ds1302_control_add,0x80); //开写保护
void delayus(uint i)
while(i--);
void display_ds1302()
//第二行
Display_num(1,2,5,p[a[0]]);
Display_num(1,2,6,p[a[1]]);
Display_num(1,2,7,fenhao);
Display_num(2,2,0,p[a[2]]);
Display_num(2,2,1,p[a[3]]);
Display_num(2,2,2,fenhao);
Display_num(2,2,3,p[a[4]]);
Display_num(2,2,4,p[a[5]]);
delay(5);
void main()
init();
lcd_init();
writetime();
while(1)
readtime();
delay(50);
a[0]=t[3]/10;
a[1]=t[3]%10;
a[2]=t[4]/10;
a[3]=t[4]%10;
a[4]=t[5]/10;
a[5]=t[5]%10;
display_ds1302();
delay(1000);
12864显示没问题,我显示过
pic单片机我选用的是4M晶振
调试了好几天,ds1302都没驱动,我的qq873283984
