---------------------------------------------------------------------------------- -- Company: -- Engineer: -- -- Create Date: 10:42:01 04/22/2012 -- Design Name: -- Module Name: top1 - Behavioral -- Project Name: -- Target Devices: -- Tool versions: -- Description: -- -- Dependencies: -- -- Revision: -- Revision 0.01 - File Created -- Additional Comments: -- ---------------------------------------------------------------------------------- library IEEE; use IEEE.STD_LOGIC_1164.ALL;
-- Uncomment the following library declaration if using -- arithmetic functions with Signed or Unsigned values --use IEEE.NUMERIC_STD.ALL;
-- Uncomment the following library declaration if instantiating -- any Xilinx primitives in this code. --library UNISIM; --use UNISIM.VComponents.all;
entity top1 is port( clk : in std_logic; ad : in std_logic_vector(7 downto 0); an : OUT std_logic_vector(3 downto 0); a_to_h : OUT std_logic_vector(7 downto 0); eoc : IN std_logic; OE : out STD_LOGIC; ale : OUT std_logic; start : OUT std_logic; ADC_ONECLK: INOUT STD_LOGIC ); end top1;
architecture Behavioral of top1 is signal temp : std_logic_vector(7 downto 0); COMPONENT ad_hgq PORT( d : IN std_logic_vector(7 downto 0); clk : IN std_logic; eoc : IN std_logic; oneUSCLK : INOUT std_logic; oe : OUT std_logic; ale : OUT std_logic; start : OUT std_logic; q : OUT std_logic_vector(7 downto 0) ); END COMPONENT; COMPONENT top PORT( sw : IN std_logic_vector(7 downto 0); clk : IN std_logic; a_to_h : OUT std_logic_vector(7 downto 0); an : OUT std_logic_vector(3 downto 0) ); END COMPONENT;
begin Inst_ad_hgq: ad_hgq PORT MAP( d => ad, clk =>clk , eoc => eoc, oe =>oe , ale =>ale , start =>start , q => temp, oneUSCLK => ADC_ONECLK ); Inst_top: top PORT MAP( a_to_h => a_to_h, sw => temp , clk => clk , an =>an );
end Behavioral;
library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.STD_LOGIC_ARITH.ALL; use IEEE.STD_LOGIC_UNSIGNED.ALL; entity ad_hgq is port( d :in std_logic_vector(7 downto 0);---AD输入; clk,eoc :in std_logic; ---eoc:转换结束状态信号; oe : out std_logic; ale,start:out std_logic; ---ale:允许地址锁存; q :out std_logic_vector(7 downto 0); oneUSCLK : inout std_logic ); ---转换数据输出显示; end ad_hgq; architecture behaviour of ad_hgq is type state is (st0,st1,st2,st3,st4,st5,st6,st7); ---以枚举类型定义各状态子类型; signal current_state,next_state :state:=st0; signal regl :std_logic_vector(7 downto 0); signal addrx :std_logic_vector(2 downto 0):="000"; signal lock :std_logic; ---转换后数据输出锁存时钟信号; signal hex :std_logic_vector(7 downto 0); signal clkCount: std_logic_vector (6 downto 0); --signal oneUSCLK :std_logic; begin process(current_state,eoc) begin case current_state is when st0=> ale<='0';start<='0';oe<='0';lock<='0'; next_state<=st1; ---初始态ST0向下一状态ST1转换,0809采样控制信号初始化; when st1=> ale<='1';start<='0';oe<='0';lock<='0'; next_state<=st2; ---由ALE的上升沿将通道地址'001'锁入0809的地址寄存器; when st2=> ale<='1';start<='1';oe<='0';lock<='0'; next_state<=st3; ---启动采样信号; when st3=> ale<='0';start<='1';oe<='0';lock<='0'; if(eoc='0') then next_state<=st4; ---转换即将结束,转换至下一状态; else next_state<=st3; ---转换未结束,继续在状态ST3中等待; end if; when st4=> ale<='0';start<='0';oe<='0';lock<='0'; if(eoc='1') then next_state<=st5; ---EOC由0恢复1,转换结束; else next_state<=st4; ---转换未结束,等待; end if; when st5=> ale<='0';start<='0';oe<='1';lock<='0'; next_state<=st6; --开启输出允许OE; when st6=> ale<='0';start<='0';oe<='1';lock<='1'; next_state<=st7; --开启数据锁存LOCK; when st7=> ale<='0';start<='0';oe<='0';lock<='1'; next_state<=st0; when others=>next_state<=st0; ---其它状态返回ST0; end case; end process; process (CLK) begin if (CLK = '1' and CLK'event) then if(clkCount = "1100011") then --1100011--99 clkCount <= "0000000"; oneUSClk <= not oneUSClk; else clkCount <= clkCount + 1; end if; end if; end process; process(oneUSClk) begin if(oneUSClk'event and oneUSClk='1') then current_state<=next_state; end if; ---在时钟上升沿,转换至下一状态; end process ; ---由信号current_state将当前状态带出进程,进入下一进程; process(lock) begin if (lock='1'and lock'event) then regl<=d; end if; --在lock上升沿,将转换好的数据锁存入8位锁存器中; end process; q<=regl; ---数据输出; --process(oneUSClk) -- begin -- if( oneUSClk'event and oneUSClk ='1') then if oe='1' then hex<=q; ---将数据送给hex; -- end if; -- end if; --end process; end behaviour;
library IEEE; use IEEE.STD_LOGIC_1164.ALL; use ieee.std_logic_unsigned.all; use ieee.std_logic_arith.all;
entity top is port( a_to_h : out std_logic_vector(7 downto 0); sw : in std_logic_vector(7 downto 0); clk : in std_logic; an : out std_logic_vector(3 downto 0) );
end top;
architecture Behavioral of top is type mstate is ( qian, bai, shi, ge ); type ConvADCState is ( DispInit, DispConv1, DispConv2 ); signal select1 : std_logic_vector(3 downto 0); signal clkcount : std_logic_vector(6 downto 0); signal oneusclk : std_logic; signal regl : integer range 0 to 255; signal ADCThou,ADCHun,ADCTen,ADCNum: integer range 0 to 9:= 0; signal DisplayADCState : ConvADCState := DispInit; signal weishu : mstate := qian; signal display :integer range 0 to 9;
begin regl<=conv_integer(sw); process(clk) begin if clk='1' and clk'event then if clkcount="1100011" then clkcount<="0000000"; oneusclk<= not oneusclk; else clkcount<=clkcount+1; end if; end if; end process; process(oneusclk) variable regl1 : integer range 0 to 49980; variable ADCThou1,ADCHun1,ADCTen1,ADCNum1:integer range 0 to 9; begin if (oneUSClk = '1' and oneUSClk'event) then case DisplayADCState is when DispInit=> regl1:=(regl)*196; ADCThou1:=0; ADCHun1:=0; ADCTen1:=0; ADCNum1:=0; DisplayADCState<=DispConv1; when DispConv1=> if regl1>9999 then ADCThou1:=ADCThou1+1; regl1:=regl1-10000; DisplayADCState<=DispConv1; elsif regl1>999 then ADCHun1:=ADCHun1+1; regl1:=regl1-1000; DisplayADCState<=DispConv1; elsif regl1>99 then ADCTen1:=ADCTen1+1; regl1:=regl1-100; DisplayADCState<=DispConv1; elsif regl1>9 then ADCNum1:=ADCNum1+1; regl1:=regl1-10; DisplayADCState<=DispConv1; else DisplayADCState<=DispConv2; end if; when DispConv2=> ADCThou<=ADCThou1; ADCHun<=ADCHun1; ADCTen<=ADCTen1; ADCNum<=ADCNum1; DisplayADCState <= DispInit; end case; end if; end process; process(display) begin case display is when 0=>a_to_h(6 downto 0)<="1000000"; when 1=>a_to_h(6 downto 0)<="1111001"; when 2=>a_to_h(6 downto 0)<="0100100"; when 3=>a_to_h(6 downto 0)<="0110000"; when 4=>a_to_h(6 downto 0)<="0011001"; when 5=>a_to_h(6 downto 0)<="0010010"; when 6=>a_to_h(6 downto 0)<="0000010"; when 7=>a_to_h(6 downto 0)<="1111000"; when 8=>a_to_h(6 downto 0)<="0000000"; when 9=>a_to_h(6 downto 0)<="0010000"; end case; end process; process(oneusclk,display) begin if (oneUSClk = '1' and oneUSClk'event) then case weishu is when qian=> an<="0111"; display<=ADCThou; a_to_h(7)<='0'; weishu<=bai; when bai=> an<="1011"; display<=ADCHun; a_to_h(7)<='1'; weishu<=shi; when shi=> an<="1101"; display<=ADCTen; a_to_h(7)<='1'; weishu<=ge; when ge=> an<="1110"; display<=ADCNum; a_to_h(7)<='1'; weishu<=qian; end case; end if; end process;
end Behavioral;
