2483|0
大家帮忙看看 [复制链接]
#include
#include  "BoardConfig.h"
unsigned int overflow=0;
unsigned int width[]={0};
unsigned int i=0,j=0;
float temp=0.000000,sum=0.000000;
void sys_init(void);
void main()
WDTCTL = WDTPW + WDTHOLD;                 // 关狗
BoardConfig(0x00);
sys_init();
while(1)
  CCR0=330;
  CCTL1 = OUTMOD_7;
  CCR1= 150;
  CCTL2 = OUTMOD_7;
  CCR2=150;
        if(overflow==40)
        if(temp<0.050000)
                        while(1)
                                CCR0=330;
                                CCTL1 = OUTMOD_7;
                                CCR1=0;
                                CCTL2 = OUTMOD_7;
                                CCR2=0;
                                if(overflow==40)
                                        break;
                else if(temp>0.050000&&temp<0.100000)
                        while(1)
                                CCR0=330;
                                CCTL1 = OUTMOD_7;
                                CCR1=180;
                                CCTL2 = OUTMOD_7;
                                CCR2=180;
                                if(overflow==40)
                                        break;
                else if(temp>0.100000&&temp<0.150000)
                        while(1)
                                CCR0=330;
                                CCTL1 = OUTMOD_7;
                                CCR1=210;
                                CCTL2 = OUTMOD_7;
                                CCR2=210;
                                if(overflow==40)
                                        break;
                else if(temp>0.150000&&temp<0.200000)
                        while(1)
                                CCR0=330;
                                CCTL1 = OUTMOD_7;
                                CCR1=240;
                                CCTL2 = OUTMOD_7;
                                CCR2=240;
                                if(overflow==40)
                                        break;
                else if(temp>0.200000&&temp<0.250000)
                        while(1)
                                CCR0=330;
                                CCTL1 = OUTMOD_7;
                                CCR1=270;
                                CCTL2 = OUTMOD_7;
                                CCR2=270;
                                if(overflow==40)
                                        break;
                else while(1)
                                CCR0=330;
                                CCTL1 = OUTMOD_7;
                                CCR1=330;
                                CCTL2 = OUTMOD_7;
                                CCR2=330;
                                if(overflow==40)
                                        break;
        overflow=0;
void sys_init(void)
//P5DIR = 0xff;                   //P5设置为输出
//P5OUT = 0x00;
P1DIR |= 0x0C;                            // P1.2 and P1.3 output
P1SEL |= 0x0C;
TACTL = TASSEL_2 + MC_1;
P4SEL =BIT0;                          //P4.0作为捕获模块功能的输入端输入方波
   //-------开晶振XT2---------
   BCSCTL1&=~XT2OFF;                //打开XT2振荡器
   do
   IFG1 &= ~OFIFG;                     // 清除振荡器失效标志
   for (i=256;i>0;i--);                     // 延时,等待XT2起振
  while ((IFG1 & OFIFG) != 0);            // 判断XT2是否起振
  BCSCTL2 =SELM_2+SELS;             //选择MCLK=SMCLK为XT2
  TBCCTL0&=~(CCIS1+CCIS0);          // 捕获源为P4.0,即CCI0A(也是CCI0B)
  TBCCTL0 =CM_2+SCS+CAP;           //下降沿捕获,同步捕获,工作在捕获模式
  TBCCTL0 =CCIE;                     //允许捕获比较模块提出中断请求
  TBCTL =ID_3+MC_2+TBSSEL_2+TBCLR+TBIE;
  _EINT();
#pragma vector=TIMERB0_VECTOR
__interrupt void TimerB0(void)
   if(TBCCTL0&CM1)                        //捕获到下降沿
       TBCTL =TBCLR;
       TBCCTL0=(TBCCTL0&(~CM1))| CM0;    //改为上升沿捕获:CM1置零,CM0置一
   else if(TBCCTL0&CM0)                    //捕获到上升沿
       width[i++]=TBCCR0;                  //记录下结束时间
       TBCCTL0=(TBCCTL0&(~CM0)) |CM1;   //改为下降沿捕获:CM0置零,CM1置一
#pragma vector=TIMERB1_VECTOR
__interrupt void TimerB1(void)
  switch(TAIV)
   case 2: break;
   case 4: break;
   case 6: break;
   case 8: break;
   case 10: break;
   case 12: break;
   case 14: overflow++;
          if(overflow==40)
            for(j=0;j                 {
                        sum+=width[j++];
                temp=sum/26214000;
                i=0;
捕获PWM波的低脉冲率。好像是定时器定时的问题,进入主循环后,只执行CCR0=330;
  CCTL1 = OUTMOD_7;
  CCR1= 150;
  CCTL2 = OUTMOD_7;
  CCR2=150;
大家帮忙看看是什么原因,谢谢
ADI &文晔 探索季第一站,邀您在活动帖跟帖,ADI资深工程师将与您一道寻求解决之道! ...
春晚,最出圈当属穿着棉马甲跳秧歌的机器人”秧Bot”。
转手绢、飞手绢、变换队形,精准度和稳定性甚至超越人类,这背后少不了电机控制技术。
