根据前面对MCP3201芯片硬件和时序研究,设计如下FPGA 程序访问MCP3201
library ieee; use ieee.std_logic_1164.all; use ieee.std_logic_arith.all; use ieee.std_logic_signed.all; entity get_ad_mcp3201 is port ( clk: in std_logic; --------系统时钟20MHZ rst: in std_logic; --------低电平复位 mcp3201_ncs: out std_logic; mcp3201_clk: out std_logic; mcp3201_dout:in std_logic; mcp3201_ad_data: out std_logic_vector(11 downto 0) ); end get_ad_mcp3201;
architecture arch_get_ad_mcp3201 of get_ad_mcp3201 is signal state : std_logic_vector(3 downto 0); signal clk_400k:std_logic; signal cnt: std_logic_vector(5 downto 0); signal data_reg: std_logic_vector(11 downto 0); signal clk_period_num: std_logic_vector(4 downto 0); begin process(clk,rst) begin if (rst='0') then clk_400k<='0'; cnt<=(others=>'0'); elsif clk'event and clk='1' then if (cnt="000000") then cnt<="110001"; ---49 clk_400k<='1'; else cnt<=cnt-"000001"; end if; end if; end process;
process(clk,rst) begin if (rst='0') then mcp3201_ncs<='1'; mcp3201_clk<='0'; mcp3201_ad_data<=(others=>'0'); clk_period_num<=(others=>'0'); data_reg<=(others=>'0'); state<=x"0"; elsif clk'event and clk='1' then if (clk_400k='1') then if (state=x"0") then mcp3201_ncs<='1'; state<=x"1"; elsif (state=x"1") then mcp3201_ncs<='0'; mcp3201_clk<='0'; state<=x"2"; elsif (state=x"2") then mcp3201_clk<='1'; if (clk_period_num="01110") then clk_period_num<=(others=>'0'); state<=x"3"; else clk_period_num<=clk_period_num+"00001"; state<=x"1"; end if;
if (clk_period_num>="00011") then data_reg<=data_reg(11 downto 1) & mcp3201_dout; end if; elsif (state=x"3") then mcp3201_ncs<='1'; state<=x"0"; mcp3201_ad_data<=data_reg; else mcp3201_ncs<='1'; state<=x"0"; end if ; end if; end if; end process; end arch_get_ad_mcp3201;
仿真时序图如下:
