3047|2
菜鸟问一个lm3s811串口的问题 [复制链接]
刚刚用这个板子,完全菜鸟,要想通过串口发送一串数据给arm,经过一点简单的运算,再把结果发送给pc。发送的多个数据是用空格隔开的,例如发送111   222    333过去,想让他算出他们的和666,目前找到的程序都是发送字符串,我也不知道发送到arm后它是怎么存储这些数据的,怎么才能让它自己以数组的形式存储为111,222,333三个数呢?怎么样对这些数进行操作?本人概念都比较模糊,希望哪位热心人给耐心的讲讲,或者给点例程。
//*****************************************************************************////! Converts a string into its numeric equivalent.//!//! \param pcStr is a pointer to the string containing the integer.//! \param ppcStrRet is a pointer that will be set to the first character past//! the integer in the string.//! \param iBase is the radix to use for the conversion; can be zero to//! auto-select the radix or between 2 and 16 to explicitly specify the radix.//!//! This function is very similar to the C library <tt>strtoul()</tt> function.//! It scans a string for the first token (that is, non-white space) and//! converts the value at that location in the string into an integer value.//!//! \return Returns the result of the conversion.////*****************************************************************************unsigned longustrtoul(const char *pcStr, const char **ppcStrRet, int iBase){unsigned long ulRet, ulDigit, ulNeg, ulValid;const char *pcPtr;//// Check the arguments.//ASSERT(pcStr);ASSERT((iBase == 0) || ((iBase > 1) && (iBase <= 16)));//// Initially, the result is zero.//ulRet = 0;ulNeg = 0;ulValid = 0;//// Skip past any leading white space.//pcPtr = pcStr;while((*pcPtr == ' ') || (*pcPtr == '\t')){pcPtr++;}//// Take a leading + or - from the value.//if(*pcPtr == '-'){ulNeg = 1;pcPtr++;}else if(*pcPtr == '+'){pcPtr++;}//// See if the radix was not specified, or is 16, and the value starts with// "0x" or "0X" (to indicate a hex value).//if(((iBase == 0) || (iBase == 16)) && (*pcPtr == '0') &&((pcPtr[1] == 'x') || (pcPtr[1] == 'X'))){//// Skip the leading "0x".//pcPtr += 2;//// Set the radix to 16.//iBase = 16;}//// See if the radix was not specified.//if(iBase == 0){//// See if the value starts with "0".//if(*pcPtr == '0'){//// Values that start with "0" are assumed to be radix 8.//iBase = 8;}else{//// Otherwise, the values are assumed to be radix 10.//iBase = 10;}}//// Loop while there are more valid digits to consume.//while(1){//// See if this character is a number.//if((*pcPtr >= '0') && (*pcPtr <= '9')){//// Convert the character to its integer equivalent.//ulDigit = *pcPtr++ - '0';}//// Otherwise, see if this character is an upper case letter.//else if((*pcPtr >= 'A') && (*pcPtr <= 'Z')){//// Convert the character to its integer equivalent.//ulDigit = *pcPtr++ - 'A' + 10;}//// Otherwise, see if this character is a lower case letter.//else if((*pcPtr >= 'a') && (*pcPtr <= 'z')){//// Convert the character to its integer equivalent.//ulDigit = *pcPtr++ - 'a' + 10;}//// Otherwise, this is not a valid character.//else{//// Stop converting this value.//break;}//// See if this digit is valid for the chosen radix.//if(ulDigit >= iBase){//// Since this was not a valid digit, move the pointer back to the// character that therefore should not have been consumed.//pcPtr--;//// Stop converting this value.//break;}//// Add this digit to the converted value.//ulRet *= iBase;ulRet += ulDigit;//// Since a digit has been added, this is now a valid result.//ulValid = 1;}//// Set the return string pointer to the first character not consumed.//if(ppcStrRet){*ppcStrRet = ulValid ? pcPtr : pcStr;}//// Return the converted value.//return(ulNeg ? (0 - ulRet) : ulRet);}复制代码  详情 回复 发表于 2012-4-13 13:12
1999
24
发送都是字符串,这些主要看接收方把他识别为什么,你在arm中把收到的字符串存为字符串数组,然后自己写个函数转化为长整形数字,再进行加法运算
1803
  1. //*****************************************************************************
    unsigned long
    const char *pcPtr;
    ASSERT(pcStr);
    ulRet = 0;
    ulNeg = 0;
    ulValid = 0;
    pcPtr = pcStr;
    pcPtr++;
    if(*pcPtr == '-')
    ulNeg = 1;
    pcPtr++;
    pcPtr++;
    pcPtr += 2;
    iBase = 16;
    if(iBase == 0)
    if(*pcPtr == '0')
    iBase = 8;
    else
    iBase = 10;
    while(1)
    else
    break;
    pcPtr--;
    break;
    ulRet *= iBase;
    ulRet += ulDigit;
    ulValid = 1;
    if(ppcStrRet)
复制代码
快来报名!
