17649|11
312
定位ARM Hard Fault 的方法 [复制链接]
1,  Keil的话,可以做如下操作:
先将fault中断函数的内容改为:
HardFault_Handler\
                PROC
                ;EXPORT  HardFault_Handler         [WEAK]
                ;B                  .
                                IMPORT hard_fault_handler_c
                                TST LR, #4
                                ITE EQ
                                MRSEQ R0, MSP
                                MRSNE R0, PSP
                                B hard_fault_handler_c
                ENDP
然后在源程序里添加下面的函数代码:
// hard fault handler in C,
// with stack frame location as input parameter
void hard_fault_handler_c(unsigned int * hardfault_args)
unsigned int stacked_r0;
unsigned int stacked_r1;
unsigned int stacked_r2;
unsigned int stacked_r3;
unsigned int stacked_r12;
unsigned int stacked_lr;
unsigned int stacked_pc;
unsigned int stacked_psr;
stacked_r0 = ((unsigned long) hardfault_args[0]);
stacked_r1 = ((unsigned long) hardfault_args[1]);
stacked_r2 = ((unsigned long) hardfault_args[2]);
stacked_r3 = ((unsigned long) hardfault_args[3]);
stacked_r12 = ((unsigned long) hardfault_args[4]);
stacked_lr = ((unsigned long) hardfault_args[5]);
stacked_pc = ((unsigned long) hardfault_args[6]);
stacked_psr = ((unsigned long) hardfault_args[7]);
printf ("[Hard fault handler]\n");
printf ("R0 = %x\n", stacked_r0);
printf ("R1 = %x\n", stacked_r1);
printf ("R2 = %x\n", stacked_r2);
printf ("R3 = %x\n", stacked_r3);
printf ("R12 = %x\n", stacked_r12);
printf ("LR = %x\n", stacked_lr);
printf ("PC = %x\n", stacked_pc);
printf ("PSR = %x\n", stacked_psr);
printf ("BFAR = %x\n", (*((volatile unsigned long *)(0xE000ED38))));
printf ("CFSR = %x\n", (*((volatile unsigned long *)(0xE000ED28))));
printf ("HFSR = %x\n", (*((volatile unsigned long *)(0xE000ED2C))));
printf ("DFSR = %x\n", (*((volatile unsigned long *)(0xE000ED30))));
printf ("AFSR = %x\n", (*((volatile unsigned long *)(0xE000ED3C))));
while(1)
如果使用调试器,则可以在第一个printf处设置断点.没有的话看串口打印结果
通过查看stacked_lr的内容可以知道程序运行到哪个位置出现fault
然后查看编译后汇编代码,可以知道源程序是哪个函数哪一步出现问题,
配合其它寄存器的内容来分析找出原因
2IAR的话,startup_ewarm.c文件中的FaultISR()函数的内容改为:
volatile unsigned int stacked_r0;
volatile unsigned int stacked_r1;
volatile unsigned int stacked_r2;
volatile unsigned int stacked_r3;
volatile unsigned int stacked_r12;
volatile unsigned int stacked_lr;
volatile unsigned int stacked_pc;
volatile unsigned int stacked_psr;
//unsigned long cc;
  while(1)
配合其它寄存器的内容来分析找出原因
ccs呢??  详情 回复 发表于 2015-4-7 22:56
这个帖子完全copy了我原创的博客,不注明出处还说是原创的~~ 汗!! 这个方法和帖子的部分内容我早在2008年就发表在ouravr.com : http://www.amobbs.com/thread-2013982-1-1.html 后来在2011年整理成博客文  详情 回复 发表于 2013-8-28 00:26
这个有用,赞一个
2002
24
很感谢,处理无头绪的问题很有用
2453
mark,以后可能会用到
78
谢谢
1181
看着这些代码让人兴奋。
1944
32
IAR下面 hardfault_args怎么定义啊?
5310
453
回复 楼主hansonhe 的帖子
汗!!
后来在2011年整理成博客文章,原文在这里:http://hi.baidu.com/mastergan/item/046bebd0cb7e889b270ae715
欢迎楼主转贴,但请请注明出处!
32
知道了寄存器内容也找不出原因啊.
164
ccs呢??
