2830|0
TS25L16BP-SCF [复制链接]
JLS1300-0101的详细描述:
    JLSsmall 系列
Lever Push Switches (small type)特长
  • 1. One unit of this switch is sufficient for both function selection and entry of the selected function.
  • 2. J-Lead type terminals located on the side of the body of the horizontal type help downsize equipment.
  • 3. Two options of a keytop-inclusion type and cap type are available.
  • 4. A long life of 1,000,000 cycles is also available.
规格
外形尺寸:
额定电压电流: DC5V 10mA
电路: Rotation SPDT, Push SPST
动作寿命: 100,000 cycles, 1,000,000 cycles
动作力: Rotation 1.4N , Push 2.5N,
行程: On 0.5mm、Full 0.8mm
用途
    Mobile phones, portable audio players, digital cameras and other small portable electronic equipment, etc.
此帖出自PCB设计论坛
