4143|3
STM32 DMA发送 中断接收 的串口程序-------偶是菜鸟 [复制链接]
菜鸟,很想入门,请求热心大虾 相助
此帖出自stm32/stm8论坛
#include "stm32f10x_lib.h" #include "USART1.h" #define USART1_DR_Base  0x40013804 const u8 USART_INIT_MESSAGE[2]="OK"; u8 Received_Data_Buffer[COM_PACKET_SIZE]; /* void DMA1_Channel5_IRQHandler(void) {         if (Received_Data_Buffer[0]==RUNCOMMAND_FIRST_CHAR) {//COM Command                         }           //DMA1->IFCR |= DMA1_FLAG_TC5;        //清除传输完成标记 }*/ void DMA_USART_Config(void) {         GPIO_InitTypeDef GPIO_InitStructure;         USART_InitTypeDef USART_InitStructure;         DMA_InitTypeDef DMA_InitStructure;         //clock     RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1 | RCC_APB2Periph_GPIOA , ENABLE);         RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE);           /* Configure USART1 Tx (PA.09) as alternate function push-pull */         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;           GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;           GPIO_Init(GPIOA, &GPIO_InitStructure);           GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;           GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;           GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;           GPIO_Init(GPIOA, &GPIO_InitStructure);         //usart init         USART_InitStructure.USART_BaudRate = 9600;           USART_InitStructure.USART_WordLength = USART_WordLength_8b;           USART_InitStructure.USART_StopBits = USART_StopBits_1;           USART_InitStructure.USART_Parity = USART_Parity_No;           USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;           USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;         USART_Init(USART1, &USART_InitStructure);         /***************DMA*************************/           USART_DMACmd(USART1, USART_DMAReq_Tx, ENABLE);           USART_DMACmd(USART1, USART_DMAReq_Rx, ENABLE);           /* DMA1 Channel5 RX Config */           DMA_DeInit(DMA1_Channel5);           DMA_InitStructure.DMA_PeripheralBaseAddr = USART1_DR_Base;           DMA_InitStructure.DMA_MemoryBaseAddr = (u32)Received_Data_Buffer;           DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;           DMA_InitStructure.DMA_BufferSize = COM_PACKET_SIZE;         DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;           DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;           DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Byte;           DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_Byte;           DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;//循环模式           DMA_InitStructure.DMA_Priority = DMA_Priority_Low;           DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;           DMA_Init(DMA1_Channel5, &DMA_InitStructure);         DMA_Cmd(DMA1_Channel5, ENABLE);           USART_Cmd(USART1, ENABLE);         //DMA_ITConfig(DMA1_Channel5, DMA_IT_TC, ENABLE);           /* DMA1 Channel4 TX Config */           DMA_DeInit(DMA1_Channel4);           DMA_InitStructure.DMA_PeripheralBaseAddr = USART1_DR_Base;           DMA_InitStructure.DMA_MemoryBaseAddr = (u32)USART_INIT_MESSAGE;           DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralDST;           DMA_InitStructure.DMA_BufferSize = sizeof(Received_Data_Buffer);         DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;           DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;           DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Byte;           DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_Byte;           DMA_InitStructure.DMA_Mode = DMA_Mode_Normal;           DMA_InitStructure.DMA_Priority = DMA_Priority_Low;           DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;           DMA_Init(DMA1_Channel4, &DMA_InitStructure);         DMA_Cmd(DMA1_Channel4, ENABLE);        //触发一次,使TC置1 } void USART1_DMASendData(u8 *buf,u8 size) {         if ((DMA1->ISR & DMA1_FLAG_TC4)==0) return;//上次DMA发送未完成         DMA1->IFCR |= DMA1_FLAG_TC4;                 //清除发送完成标记         DMA_Cmd(DMA1_Channel4, DISABLE);         DMA1_Channel4->CMAR = (u32)buf;         DMA1_Channel4->CNDTR= size;         DMA_Cmd(DMA1_Channel4, ENABLE); } void USART1_SendByteData(u8 dat) {         if ((DMA1->ISR & DMA1_FLAG_TC4)==0) return;//DMA发送未完成         while ((USART1->SR & USART_FLAG_TXE)==0);         USART1->DR=dat; } 我的。。。  详情 回复 发表于 2012-3-23 07:09
求求
此帖出自stm32/stm8论坛
求回帖
此帖出自stm32/stm8论坛
4008
#include "USART1.h"
        //clock
        //usart init
        USART1->DR=dat;
我的。。。
此帖出自stm32/stm8论坛
