3464|6
314
LM3S程序求教 [复制链接]
//————————————————头文件————————————————————
#include "inc/hw_ints.h"//硬件中断
#include "inc/hw_memmap.h"
#include "inc/hw_types.h"//硬件类型
#include "driverlib/gpio.h"//GPIO
#include "driverlib/sysctl.h"//系统
#include "grlib/grlib.h"//画图
#include "drivers/kitronix320x240x16_ssd2119_8bit.h"
#include "drivers/set_pinout.h"
#include "driverlib/interrupt.h"//中断
#include "driverlib/comp.h"//comp
#include "driverlib/systick.h"//systick
#include "driverlib/adc.h"//adc
#include  <stdio.h>
tContext sContext;//声明绘图
tBoolean ADC_EndFlag = false;//定义A/D转换结束的标志
unsigned long TheSysClock = 12000000UL;//定义系统时钟12MHZ
// The error routine that is called if the driver library encounters an error.
#ifdef DEBUG4
void
__error__(char *pcFilename, unsigned long ulLine)
#endif
//  Initialize the System timer (SysTick)初始化
void SysTickInit(void)
{   // Set the period of the SysTick
    SysTickPeriodSet(TheSysClock);//SysTick(一个简单的定时器)的周期
    // Enable SysTick interrupts
    SysTickIntEnable();//使能SysTick中断
    // Enable System interrupts
    IntMasterEnable();//使能处理器中断
    // Enable the SysTick
    SysTickEnable();//使能SysTick计数器
// Display the temperature of the chip
void tmpDisplay(unsigned long ulValue)
    unsigned long ulTemp;
    char pcBuffer1[4];
    char pcBuffer2[3];
    ulTemp = 151040UL - 225 * ulValue;//(ADC采样值转化为温度值)的1024倍
    pcBuffer1[0] = ' ';//空格
    pcBuffer1[1] = (ulTemp/1024)%100/10 + '0';//十位
    pcBuffer1[2] = (ulTemp/1024)%10 + '0';//个位
    pcBuffer1[3] = '\0';//结束符
    GrContextFontSet(&sContext, &g_sFontCm36b);//字体设置
    GrStringDrawCentered(&sContext, pcBuffer1, -1, 110, 180, 1);//写整数部分
    pcBuffer2[0] = '.';//小数点
    pcBuffer2[1] = (ulTemp%1024)/102+'0';//小数
    pcBuffer2[2] = '\0';//结束符
    GrStringDrawCentered(&sContext, pcBuffer2, -1, 150, 180, 1);//写小数部分
//  SysTick ISR SysTick的中断服务函数
void SysTick_ISR(void)
{    //  Just used to wake up CPU,do nothing 唤醒CPU
//  ADC Sequence 3 ISR   ADC序列3的中断服务函数
void ADC_Sequence_3_ISR(void)
{    unsigned long ulStatus;
    //Get interrupt status
    ulStatus = ADCIntStatus(ADC_BASE, 3, true);//获取当前的中断状态
    // Clear interrupts
    ADCIntClear(ADC_BASE, 3);//清除中断状态,重要
    // If interrupt status is ture, set ADC ending flag as ture
    //如果中断状态有效,置位ADC采样结束标志
    if (ulStatus != 0)
        ADC_EndFlag = true;
//如果中断状态值为真,则将中断结束标志置为真,真表示需要屏蔽的中断状态
//假表示需要原始的中断状态
int main(void)
{    unsigned long ulValue;
    // Set the clocking to run directly from the crystal.
    SysCtlClockSet(SYSCTL_SYSDIV_1|SYSCTL_USE_OSC|SYSCTL_XTAL_16MHZ|SYSCTL_OSC_MAIN);
    // Get system clock
    TheSysClock = SysCtlClockGet();//获取处理器时钟速率
    // Initialize the device pinout appropriately for this board.
    //—————————————初始化显示驱动—————————————————
    PinoutSet();
    // Initialize the display driver and graphics context.
    Kitronix320x240x16_SSD2119Init();
    GrContextInit(&sContext, &g_sKitronix320x240x16_SSD2119);//初始化a drawning context
    //————————————————设置方框—————————————————
    tRectangle sRect;
    sRect.sXMin = 0;
    sRect.sYMin = 0;
    sRect.sXMax = GrContextDpyWidthGet(&sContext) - 1;
    sRect.sYMax = 23;
    GrContextForegroundSet(&sContext, ClrDarkBlue);
    GrRectFill(&sContext, &sRect);
    GrContextForegroundSet(&sContext, ClrWhite);
    GrRectDraw(&sContext, &sRect);
    GrContextFontSet(&sContext, &g_sFontCm20);
    GrStringDrawCentered(&sContext, "Lab7-2: ADC Controls", -1,GrContextDpyWidthGet(&sContext) / 2, 10, 0);
    // Operation Tips
    GrContextFontSet(&sContext, &g_sFontCm26b);
    GrStringDrawCentered(&sContext, "Temperature Sample", -1,GrContextDpyWidthGet(&sContext) / 2, 60, 1);
    GrContextFontSet(&sContext, &g_sFontCm16);
    GrStringDrawCentered(&sContext, "Sample from the internal temperature sensor,", -1,GrContextDpyWidthGet(&sContext) / 2, 100, 1);
    GrStringDrawCentered(&sContext, "the current temperature of MCU is :", -1,GrContextDpyWidthGet(&sContext) / 2, 140, 1);
    GrStringDrawCentered(&sContext, "o", -1,GrContextDpyWidthGet(&sContext) / 2+20, 165, 1);
    GrContextFontSet(&sContext, &g_sFontCm36);
    GrStringDrawCentered(&sContext, "C", -1,GrContextDpyWidthGet(&sContext) / 2+35, 180, 1);
    // Initialize the ADC0.
    // Enable ADC0
    SysCtlPeripheralEnable(SYSCTL_PERIPH_ADC0);//使能ADC0
    // Set the sample rate of ADC0
    SysCtlADCSpeedSet(SYSCTL_ADCSPEED_125KSPS);//设置ADC采样速率
    // Disable before setting
    ADCSequenceDisable(ADC_BASE, 3);//禁止一个采样序列
    // Configure sample sequence:ADC base address,sample sequence number,trigger event,and priority
    ADCSequenceConfigure(ADC_BASE, 3, ADC_TRIGGER_PROCESSOR, 0);//采样序列配置,0表示最高优先级
    // Sample step setup:ADC base address,sample sequence number,step value,channel setting
    ADCSequenceStepConfigure(ADC_BASE, 3, 0, ADC_CTL_TS|ADC_CTL_END|ADC_CTL_IE);//采样步进设置
    // Enable ADC interrupt
    ADCIntEnable(ADC_BASE, 3);//使能ADC中断
    // Enable interrupt for ADC sequence 3
    IntEnable(INT_ADC3);//使能ADC采样序列中断
    // Enable system clock
    // Start Sampling
    ADCSequenceEnable(ADC_BASE, 3);//使能采样序列
    // Initialize SysTick
    SysTickInit();//SysTick初始化
    while(1)
    { // fall into sleep mode
      SysCtlSleep();//使处理器进入睡眠模式
      //  Process
      ADCProcessorTrigger(ADC_BASE, 3);//处理器触发采样序列
      // Waiting for sample complete
      while (!ADC_EndFlag);
      // Clear flag
      ADCSequenceDataGet(ADC_BASE, 3, &ulValue);//获取采样序列3捕获的数据
      // Display the current temperature of the CPU
      tmpDisplay(ulValue);
      GrFlush(&sContext);
为什么执行到SysCtlSleep()就停止执行了,恳求高手帮忙。
没有注册中断向量表?  详情 回复 发表于 2012-3-17 00:13
424
进入睡眠模式,CPU睡了,所以就停止了
314
回复 沙发 鸵鸟蝈蝈 的帖子
这个是光盘里自带的程序啊,光盘中那个工作区能够执行这个程序,自己新建工作区后,把这个程序直接复制过后就执行到那停止了,感觉好奇怪。
2453
没有注册中断向量表?
赞赏
查看全部赞赏
314
回复 4楼 zca123 的帖子
如何注册中断向量表啊?
314
回复 4楼 zca123 的帖子
中断向量表:
__root const uVectorEntry __vector_table[] @ ".intvec" =
    { .ulPtr = (unsigned long)pulStack + sizeof(pulStack) },
                                            // The initial stack pointer
    __iar_program_start,                    // The reset handler
    NmiSR,                                  // The NMI handler
    FaultISR,                               // The hard fault handler
    IntDefaultHandler,                      // The MPU fault handler
    IntDefaultHandler,                      // The bus fault handler
    IntDefaultHandler,                      // The usage fault handler
    0,                                      // Reserved
    0,                                      // Reserved
    0,                                      // Reserved
    0,                                      // Reserved
    IntDefaultHandler,                      // SVCall handler
    IntDefaultHandler,                      // Debug monitor handler
    0,                                      // Reserved
    IntDefaultHandler,                      // The PendSV handler
    SysTick_ISR,                            // The SysTick handler
    IntDefaultHandler,                      // GPIO Port A
    IntDefaultHandler,                      // GPIO Port B
    IntDefaultHandler,                      // GPIO Port C
    IntDefaultHandler,                      // GPIO Port D
    IntDefaultHandler,                      // GPIO Port E
    IntDefaultHandler,                      // UART0 Rx and Tx
    IntDefaultHandler,                      // UART1 Rx and Tx
    IntDefaultHandler,                      // SSI0 Rx and Tx
    IntDefaultHandler,                      // I2C0 Master and Slave
    IntDefaultHandler,                      // PWM Fault
    IntDefaultHandler,                      // PWM Generator 0
    IntDefaultHandler,                      // PWM Generator 1
    IntDefaultHandler,                      // PWM Generator 2
    IntDefaultHandler,                      // Quadrature Encoder 0
    IntDefaultHandler,                      // ADC Sequence 0
    IntDefaultHandler,                      // ADC Sequence 1
    IntDefaultHandler,                      // ADC Sequence 2
    ADC_Sequence_3_ISR,                     // ADC Sequence 3
    IntDefaultHandler,                      // Watchdog timer
    IntDefaultHandler,                      // Timer 0 subtimer A
    IntDefaultHandler,                      // Timer 0 subtimer B
    IntDefaultHandler,                      // Timer 1 subtimer A
    IntDefaultHandler,                      // Timer 1 subtimer B
    IntDefaultHandler,                      // Timer 2 subtimer A
    IntDefaultHandler,                      // Timer 2 subtimer B
    IntDefaultHandler,                      // Analog Comparator 0
    IntDefaultHandler,                      // Analog Comparator 1
    IntDefaultHandler,                      // Analog Comparator 2
    IntDefaultHandler,                      // System Control (PLL, OSC, BO)
    IntDefaultHandler,                      // FLASH Control
    IntDefaultHandler,                      // GPIO Port F
    IntDefaultHandler,                      // GPIO Port G
    IntDefaultHandler,                      // GPIO Port H
    IntDefaultHandler,                      // UART2 Rx and Tx
    IntDefaultHandler,                      // SSI1 Rx and Tx
    IntDefaultHandler,                      // Timer 3 subtimer A
    IntDefaultHandler,                      // Timer 3 subtimer B
    IntDefaultHandler,                      // I2C1 Master and Slave
    IntDefaultHandler,                      // Quadrature Encoder 1
    IntDefaultHandler,                      // CAN0
    IntDefaultHandler,                      // CAN1
    IntDefaultHandler,                      // CAN2
    IntDefaultHandler,                      // Ethernet
    IntDefaultHandler,                      // Hibernate
    IntDefaultHandler,                      // USB0
    IntDefaultHandler,                      // PWM Generator 3
    IntDefaultHandler,                      // uDMA Software Transfer
    IntDefaultHandler,                      // uDMA Error
    IntDefaultHandler,                      // ADC1 Sequence 0
    IntDefaultHandler,                      // ADC1 Sequence 1
    IntDefaultHandler,                      // ADC1 Sequence 2
    IntDefaultHandler,                      // ADC1 Sequence 3
    IntDefaultHandler,                      // I2S0
    IntDefaultHandler,                      // External Bus Interface 0
    IntDefaultHandler                       // GPIO Port J
主程序中定义的两个中断这个向量表里有的啊。。。。。
314
回复 4楼 zca123 的帖子
这个问题解决了,要把向量表动一下再改回去就可以了,好神奇啊,谢谢你的提醒。。。
