2954|2
xilinx sparter3e IP核控制lcd显示 [复制链接]
在下载比特流文件时产生的错误 我是用6个软件寄存器进行操作,错误却产生在lcd_ip.v看不懂,求大神帮忙
ERROR:Xst:2585 - Port <PLB_ABus> of instance <lcd_ip_0> does not exist in definition <lcd_ip>. Please compare the definition of block <lcd_ip> to its component declaration to detect the mismatch.
ERROR:Xst:2585 - Port <PLB_BE> of instance <lcd_ip_0> does not exist in definition <lcd_ip>. Please compare the definition of block <lcd_ip> to its component declaration to detect the mismatch.
ERROR:Xst:2585 - Port <PLB_MSize> of instance <lcd_ip_0> does not exist in definition <lcd_ip>. Please compare the definition of block <lcd_ip> to its component declaration to detect the mismatch.
ERROR:Xst:2585 - Port <PLB_PAValid> of instance <lcd_ip_0> does not exist in definition <lcd_ip>. Please compare the definition of block <lcd_ip> to its component declaration to detect the mismatch.
ERROR:Xst:2585 - Port <PLB_RNW> of instance <lcd_ip_0> does not exist in definition <lcd_ip>. Please compare the definition of block <lcd_ip> to its component declaration to detect the mismatch.
ERROR:Xst:2585 - Port <PLB_SAValid> of instance <lcd_ip_0> does not exist in definition <lcd_ip>. Please compare the definition of block <lcd_ip> to its component declaration to detect the mismatch.
ERROR:Xst:2585 - Port <PLB_TAttribute> of instance <lcd_ip_0> does not exist in definition <lcd_ip>. Please compare the definition of block <lcd_ip> to its component declaration to detect the mismatch.
ERROR:Xst:2585 - Port <PLB_UABus> of instance <lcd_ip_0> does not exist in definition <lcd_ip>. Please compare the definition of block <lcd_ip> to its component declaration to detect the mismatch.
ERROR:Xst:2585 - Port <PLB_abort> of instance <lcd_ip_0> does not exist in definition <lcd_ip>. Please compare the definition of block <lcd_ip> to its component declaration to detect the mismatch.
ERROR:Xst:2585 - Port <PLB_busLock> of instance <lcd_ip_0> does not exist in definition <lcd_ip>. Please compare the definition of block <lcd_ip> to its component declaration to detect the mismatch.
ERROR:Xst:2585 - Port <PLB_lockErr> of instance <lcd_ip_0> does not exist in definition <lcd_ip>. Please compare the definition of block <lcd_ip> to its component declaration to detect the mismatch.
ERROR:Xst:2585 - Port <PLB_masterID> of instance <lcd_ip_0> does not exist in definition <lcd_ip>. Please compare the definition of block <lcd_ip> to its component declaration to detect the mismatch.
ERROR:Xst:2585 - Port <PLB_rdBurst> of instance <lcd_ip_0> does not exist in definition <lcd_ip>. Please compare the definition of block <lcd_ip> to its component declaration to detect the mismatch.
ERROR:Xst:2585 - Port <PLB_rdPendPri> of instance <lcd_ip_0> does not exist in definition <lcd_ip>. Please compare the definition of block <lcd_ip> to its component declaration to detect the mismatch.
ERROR:Xst:2585 - Port <PLB_rdPendReq> of instance <lcd_ip_0> does not exist in definition <lcd_ip>. Please compare the definition of block <lcd_ip> to its component declaration to detect the mismatch.
ERROR:Xst:2585 - Port <PLB_rdPrim> of instance <lcd_ip_0> does not exist in definition <lcd_ip>. Please compare the definition of block <lcd_ip> to its component declaration to detect the mismatch.
ERROR:Xst:2585 - Port <PLB_reqPri> of instance <lcd_ip_0> does not exist in definition <lcd_ip>. Please compare the definition of block <lcd_ip> to its component declaration to detect the mismatch.
ERROR:Xst:2585 - Port <PLB_size> of instance <lcd_ip_0> does not exist in definition <lcd_ip>. Please compare the definition of block <lcd_ip> to its component declaration to detect the mismatch.
ERROR:Xst:2585 - Port <PLB_type> of instance <lcd_ip_0> does not exist in definition <lcd_ip>. Please compare the definition of block <lcd_ip> to its component declaration to detect the mismatch.
ERROR:Xst:2585 - Port <PLB_wrBurst> of instance <lcd_ip_0> does not exist in definition <lcd_ip>. Please compare the definition of block <lcd_ip> to its component declaration to detect the mismatch.
ERROR:Xst:2585 - Port <PLB_wrDBus> of instance <lcd_ip_0> does not exist in definition <lcd_ip>. Please compare the definition of block <lcd_ip> to its component declaration to detect the mismatch.
ERROR:Xst:2585 - Port <PLB_wrPendPri> of instance <lcd_ip_0> does not exist in definition <lcd_ip>. Please compare the definition of block <lcd_ip> to its component declaration to detect the mismatch.
ERROR:Xst:2585 - Port <PLB_wrPendReq> of instance <lcd_ip_0> does not exist in definition <lcd_ip>. Please compare the definition of block <lcd_ip> to its component declaration to detect the mismatch.
ERROR:Xst:2585 - Port <PLB_wrPrim> of instance <lcd_ip_0> does not exist in definition <lcd_ip>. Please compare the definition of block <lcd_ip> to its component declaration to detect the mismatch.
ERROR:Xst:2585 - Port <SPLB_Clk> of instance <lcd_ip_0> does not exist in definition <lcd_ip>. Please compare the definition of block <lcd_ip> to its component declaration to detect the mismatch.
ERROR:Xst:2585 - Port <SPLB_Rst> of instance <lcd_ip_0> does not exist in definition <lcd_ip>. Please compare the definition of block <lcd_ip> to its component declaration to detect the mismatch.
ERROR:Xst:2585 - Port <Sl_MBusy> of instance <lcd_ip_0> does not exist in definition <lcd_ip>. Please compare the definition of block <lcd_ip> to its component declaration to detect the mismatch.
ERROR:Xst:2585 - Port <Sl_MIRQ> of instance <lcd_ip_0> does not exist in definition <lcd_ip>. Please compare the definition of block <lcd_ip> to its component declaration to detect the mismatch.
ERROR:Xst:2585 - Port <Sl_MRdErr> of instance <lcd_ip_0> does not exist in definition <lcd_ip>. Please compare the definition of block <lcd_ip> to its component declaration to detect the mismatch.
ERROR:Xst:2585 - Port <Sl_MWrErr> of instance <lcd_ip_0> does not exist in definition <lcd_ip>. Please compare the definition of block <lcd_ip> to its component declaration to detect the mismatch.
ERROR:Xst:2585 - Port <Sl_SSize> of instance <lcd_ip_0> does not exist in definition <lcd_ip>. Please compare the definition of block <lcd_ip> to its component declaration to detect the mismatch.
ERROR:Xst:2585 - Port <Sl_addrAck> of instance <lcd_ip_0> does not exist in definition <lcd_ip>. Please compare the definition of block <lcd_ip> to its component declaration to detect the mismatch.
ERROR:Xst:2585 - Port <Sl_rdBTerm> of instance <lcd_ip_0> does not exist in definition <lcd_ip>. Please compare the definition of block <lcd_ip> to its component declaration to detect the mismatch.
ERROR:Xst:2585 - Port <Sl_rdComp> of instance <lcd_ip_0> does not exist in definition <lcd_ip>. Please compare the definition of block <lcd_ip> to its component declaration to detect the mismatch.
ERROR:Xst:2585 - Port <Sl_rdDAck> of instance <lcd_ip_0> does not exist in definition <lcd_ip>. Please compare the definition of block <lcd_ip> to its component declaration to detect the mismatch.
ERROR:Xst:2585 - Port <Sl_rdDBus> of instance <lcd_ip_0> does not exist in definition <lcd_ip>. Please compare the definition of block <lcd_ip> to its component declaration to detect the mismatch.
ERROR:Xst:2585 - Port <Sl_rdWdAddr> of instance <lcd_ip_0> does not exist in definition <lcd_ip>. Please compare the definition of block <lcd_ip> to its component declaration to detect the mismatch.
ERROR:Xst:2585 - Port <Sl_rearbitrate> of instance <lcd_ip_0> does not exist in definition <lcd_ip>. Please compare the definition of block <lcd_ip> to its component declaration to detect the mismatch.
ERROR:Xst:2585 - Port <Sl_wait> of instance <lcd_ip_0> does not exist in definition <lcd_ip>. Please compare the definition of block <lcd_ip> to its component declaration to detect the mismatch.
ERROR:Xst:2585 - Port <Sl_wrBTerm> of instance <lcd_ip_0> does not exist in definition <lcd_ip>. Please compare the definition of block <lcd_ip> to its component declaration to detect the mismatch.
ERROR:Xst:2585 - Port <Sl_wrComp> of instance <lcd_ip_0> does not exist in definition <lcd_ip>. Please compare the definition of block <lcd_ip> to its component declaration to detect the mismatch.
ERROR:Xst:2585 - Port <Sl_wrDAck> of instance <lcd_ip_0> does not exist in definition <lcd_ip>. Please compare the definition of block <lcd_ip> to its component declaration to detect the mismatch.
ERROR:MDT - Aborting XST flow execution!
[ 本帖最后由 xingdong 于 2012-3-15 17:40 编辑 ]
查看本帖全部内容,请登录或者注册
你需要在你的顶层模块中声明的  详情 回复 发表于 2012-3-21 16:58
高手帮忙,急用
你需要在你的顶层模块中声明的
电源解决方案和技术 | DigiKey 应用探索站
