5829|3
在线调试时,为什么程序跑到3F806D 6F00 SB 0,UNC 就停住了? [复制链接]
想利用2812实现简单的四路AD转换,主程序编写如下,可在线调试时,一跑到3F806D就停住了,四路a1,a2,a3,a4固定为77,不知道为什么,求大牛赐教,感激不尽!
interrupt void adc_isr(void);
Uint16 a1;
Uint16 a2;
Uint16 a3;
Uint16 a4;
main()
   InitSysCtrl();
   EALLOW;
   SysCtrlRegs.HISPCP.all = 0x3;  // HSPCLK = SYSCLKOUT/6
   EDIS;
   DINT;
   InitPieCtrl();
   IER = 0x0000;
   IFR = 0x0000;
   InitPieVectTable();
   EALLOW;  // This is needed to write to EALLOW protected register
   PieVectTable.ADCINT = &adc_isr;
   EDIS;    // This is needed to disable write to EALLOW protected registers
   InitAdc();  // For this example, init the ADC
   PieCtrlRegs.PIEIER1.bit.INTx6 = 1;
   IER |= M_INT1; // Enable CPU Interrupt 1
   EINT;          // Enable Global interrupt INTM
   ERTM;          // Enable Global realtime interrupt DBGM
   AdcRegs.ADCTRL1.bit.RESET=1;
   asm("NOP");
   AdcRegs.ADCTRL1.bit.RESET=0;
   AdcRegs.ADCTRL1.bit.SUSMOD=3;
   AdcRegs.ADCTRL1.bit.ACQ_PS=0;
   AdcRegs.ADCTRL1.bit.CPS=0;
   AdcRegs.ADCTRL1.bit.CONT_RUN=1;   //连续运转模式,当接收到EOC信号后,排序器将从CONV00(对于SEQ1)状态重新开始装换
   AdcRegs.ADCTRL1.bit.SEQ_CASC=1;   //级联模式,SEQ1与SEQ2作为一个单16状态序列发生器操作
   AdcRegs.ADCTRL3.bit.ADCCLKPS=1;
   AdcRegs.ADCTRL3.bit.SMODE_SEL=0;
   AdcRegs.ADCMAXCONV.all = 0x0003;       // Setup 2 conv's on SEQ1
   AdcRegs.ADCCHSELSEQ1.bit.CONV00 = 0x2; // Setup ADCINA2 as 1st SEQ1 conv.
   AdcRegs.ADCCHSELSEQ1.bit.CONV01 = 0x3; // Setup ADCINA3 as 2nd SEQ1 conv.
   AdcRegs.ADCCHSELSEQ1.bit.CONV02 = 0x4;
   AdcRegs.ADCCHSELSEQ1.bit.CONV03 = 0x5;
        AdcRegs.ADCTRL2.bit.EVB_SOC_SEQ=0;
        AdcRegs.ADCTRL2.bit.RST_SEQ1=0;
        AdcRegs.ADCTRL2.bit.INT_ENA_SEQ1=1;
        AdcRegs.ADCTRL2.bit.INT_MOD_SEQ1=0;
        AdcRegs.ADCTRL2.bit.EVA_SOC_SEQ1=0;
        AdcRegs.ADCTRL2.bit.EXT_SOC_SEQ1=0;
        AdcRegs.ADCTRL2.bit.RST_SEQ2=0;
        AdcRegs.ADCTRL2.bit.SOC_SEQ2=0;
        AdcRegs.ADCTRL2.bit.INT_ENA_SEQ2=0;
        AdcRegs.ADCTRL2.bit.INT_MOD_SEQ2=0;
        AdcRegs.ADCTRL2.bit.EVB_SOC_SEQ2=0;
        while(AdcRegs.ADCST.bit.SEQ1_BSY==0)
                        AdcRegs.ADCTRL2.bit.SOC_SEQ1=1;
   a1 = AdcRegs.ADCRESULT0 >>4;
   a2 = AdcRegs.ADCRESULT1 >>4;
   a3 = AdcRegs.ADCRESULT2 >>4;
   a4 = AdcRegs.ADCRESULT3 >>4;
  AdcRegs.ADCTRL2.bit.RST_SEQ1 = 1;         // Reset SEQ1
  AdcRegs.ADCST.bit.INT_SEQ1_CLR = 1;       // Clear INT SEQ1 bit
  PieCtrlRegs.PIEACK.all = PIEACK_GROUP1;   // Acknowledge interrupt to PIE
  return;
遇到了同样的问题 求解答  详情 回复 发表于 2014-9-22 14:38
遇到了同样的问题 求解答
我遇到了同样的问题,求指教
请问这个问题后来怎么解决了?我也遇到同样的问题了,求指教
遇到了同样的问题 求解答
