4205|4
LM3S9B81以太网口LED不亮求解。 [复制链接]
刚在LMS3S9B81上调通了网络通讯功能,通讯功能一切正常,能ping,能打开里面的网页,PC网卡显示连接100M.美中不足的是网口的两个LED不亮,不知何故。
贴上初始化代码,使用了LM3S的库,请高手帮忙分析一下,
    unsigned long nEthClk, ulTemp;
    SysCtlClockSet(SYSCTL_SYSDIV_4 | SYSCTL_USE_PLL | SYSCTL_OSC_MAIN | SYSCTL_XTAL_16MHZ);// 系统时钟初始化
    // Enable and Reset the Ethernet Controller.
    SysCtlPeripheralEnable(SYSCTL_PERIPH_ETH);
    SysCtlPeripheralReset(SYSCTL_PERIPH_ETH);
    SysCtlPeripheralEnable (SYSCTL_PERIPH_GPIOF);
    GPIODirModeSet  (GPIO_PORTF_BASE, (GPIO_PIN_2 | GPIO_PIN_3), GPIO_DIR_MODE_HW);
    GPIOPadConfigSet(GPIO_PORTF_BASE, (GPIO_PIN_2 | GPIO_PIN_3), GPIO_STRENGTH_4MA, GPIO_PIN_TYPE_STD);
    // Intialize the Ethernet Controller and disable all Ethernet Controller
    // interrupt sources.
    EthernetIntDisable(ETH_BASE, (ETH_INT_PHY | ETH_INT_MDIO | ETH_INT_RXER | ETH_INT_RXOF | ETH_INT_TX | ETH_INT_TXER | ETH_INT_RX));
    ulTemp = EthernetIntStatus(ETH_BASE, false);
    EthernetIntClear(ETH_BASE, ulTemp);
    // Initialize the Ethernet controller for operation
    nEthClk = SysCtlClockGet();
    EthernetInitExpClk(ETH_BASE, nEthClk);
    // Configure the Ethernet controller for normal operation
    // Enable TX Duplex Mode
    // Enable TX Padding
    EthernetConfigSet(ETH_BASE, (ETH_CFG_TX_DPLXEN | ETH_CFG_TX_PADEN | ETH_CFG_TX_CRCEN));
    HWREG(ETH_BASE + MAC_O_THR) = 0x0;
    // Program the MAC Address
    EthernetMACAddrSet(ETH_BASE, nMACAddr);
    // Enable the Ethernet controller
    EthernetEnable(ETH_BASE);
您好,我最近在学习LM3S9B81,需要做一个项目,想请教一下您,能不能加一下QQ(735507934)。在线等。万分感谢了。   详情 回复 发表于 2014-9-17 15:07
补充一点,程序用的是查询方式,没有用以太网中断。
1803
ROM_SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOF);
    GPIOPinConfigure(GPIO_PF2_LED1);
    GPIOPinConfigure(GPIO_PF3_LED0);
    GPIOPinTypeEthernetLED(GPIO_PORTF_BASE, GPIO_PIN_2 | GPIO_PIN_3);
谢谢,回家试试看。
