6160|2
44
关于winavr编译的问题 [复制链接]
初学avr,使用win7+winavr的环境,不过常年写java代码,实在是不习惯winavr的编译器,后来找到了eclipse的插件,很好用,但是编译有问题。
Build的时候会出现这个问题:
Problems occurred building the selected resources.
  Errors running builder 'CDT Builder' on project 'GCC-4'.
    java.lang.NullPointerException
控制台打印:
**** Clean-only build of configuration Release for project GCC-4 ****
make clean
rm -rf  ./key_scan.o ./led.o ./main.o  ./key_scan.d ./led.d ./main.d  GCC-4.eep  GCC-4.hex  GCC-4.lss  sizedummy  GCC-4.elf
**** Build of configuration Release for project GCC-4 ****
make all
Building file: ../key_scan.c
Invoking: AVR Compiler
In file included from ../key_scan.c:3:
../led.h:8:20: warning: no newline at end of file
../key_scan.c: In function `key_scan':
../key_scan.c:6: warning: unused variable `m'
/usr/bin/sh: /d/WinAVR/bin/avr-objdump: Invalid argument
make: [GCC-4.lss] Error 126 (ignored)
/usr/bin/sh: /d/WinAVR/bin/avr-objcopy: Invalid argument
make: [GCC-4.hex] Error 126 (ignored)
make: [GCC-4.eep] Error 126 (ignored)
换到winavr的环境下编译,能生产hex文件,但是还是出错的。
> "make.exe" all
-------- begin --------
avr-gcc (GCC) 3.4.3
Copyright (C) 2004 Free Software Foundation, Inc.
This is free software; see the source for copying conditions.  There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
Compiling: main.c
avr-gcc -c -mmcu=atmega16 -I. -gdwarf-2 -DF_CPU=3686400UL  -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-adhlns=main.lst  -std=gnu99 -MD -MP -MF .dep/main.o.d main.c -o main.o
main.c:14: warning: function declaration isn't a prototype
Compiling: led.c
avr-gcc -c -mmcu=atmega16 -I. -gdwarf-2 -DF_CPU=3686400UL  -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-adhlns=led.lst  -std=gnu99 -MD -MP -MF .dep/led.o.d led.c -o led.o
Compiling: key_scan.c
avr-gcc -c -mmcu=atmega16 -I. -gdwarf-2 -DF_CPU=3686400UL  -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-adhlns=key_scan.lst  -std=gnu99 -MD -MP -MF .dep/key_scan.o.d key_scan.c -o key_scan.o
In file included from key_scan.c:3:
Linking: main.elf
avr-gcc -mmcu=atmega16 -I. -gdwarf-2 -DF_CPU=3686400UL  -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-adhlns=main.o  -std=gnu99 -MD -MP -MF .dep/main.elf.d main.o led.o key_scan.o --output main.elf -Wl,-Map=main.map,--cref    -lm
Creating load file for Flash: main.hex
avr-objcopy -O ihex -R .eeprom main.elf main.hex
Creating load file for EEPROM: main.eep
avr-objcopy -j .eeprom --set-section-flags=.eeprom="alloc,load" \
--change-section-lma .eeprom=0 -O ihex main.elf main.eep
Creating Extended Listing: main.lss
avr-objdump -h -S main.elf > main.lss
Creating Symbol Table: main.sym
avr-nm -n main.elf > main.sym
/usr/bin/sh: /d/WinAVR/bin/avr-nm: Invalid argument
make.exe: *** [main.sym] Error 126
> Process Exit Code: 2
hex文件在protues中能正常运行。不知道啥问题。
望高人指点一二。
太难了。太难了。。。。  详情 回复 发表于 2012-3-18 23:51
194
用avrstudio 内嵌 winavr吧,那个好用。
太难了。太难了。。。。
