5545|2
272
做串口通讯时出现的问题,求大虾指导 [复制链接]
编译时出现如下代码,刚出来实习,懂的不多! 你们看看有没有可能是软件版本不一致的问题,用的是IAR6.10,问几位大哥了,都不太清楚,因为项目之前直接编译通过了,现在就提个串口出来,编译出现这样的情况~
Error[Li005]: no definition for "assert_failed" [referenced from F:\arm\code\10.20 SOFT\Project\ChargePegSTM32F\EWARM\ChargePegV3\Obj\stm32f10x_usart.o]
此帖出自ARM技术论坛
需要在函数中添加:     #ifdef  USE_FULL_ASSERT /**  * @brief  Reports the name of the source file and the source line number  *   where the assert_param error has occurred.  * @param  file: pointer to the source file name  * @param  line: assert_param error line source number  * @retval None  */void assert_failed(uint8_t* file, uint32_t line){   /* User can add his own implementation to report the file name and line number,     ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */   /* Infinite loop */  while (1)  {  }}#endif   复制代码  详情 回复 发表于 2012-7-7 09:45
272
拜托啦
此帖出自ARM技术论坛
4997
裸片初长成(初级)
需要在函数中添加:
  1.
  2. #ifdef  USE_FULL_ASSERT
  3. /**
      * @retval None
  4.   /* Infinite loop */
      while (1)
    #endif
  5.
复制代码
此帖出自ARM技术论坛
个人签名我的博客
