3182|2
89
我做了这个程序帮我看下哪里错了 [复制链接]
#include<reg51.h>
#define uchar unsigned char
#define uint unsigned int
// #define r0 P1
void xs(uchar nian0,uchar nian1,uchar nian2,uchar nian3,uchar yue0,uchar yue1,uchar ri0,uchar ri1,uchar shi0,uchar shi1,uchar fen0,uchar fen1,uchar miao0,uchar miao1);
uchar code table[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};
uchar a,i,nian0,nian1,nian2,nian3,yue0,yue1,ri0,ri1,shi0,shi1,fen0,fen1,miao0,miao1;
void et1();
void dealy(uint);
void main()
     et1();
     while(1)
        if(a==2);
                 xs(2,0,1,2);
                dealy(10);
        a=0;
        if(a==2);
                 xs(0,2,2,7);
                 dealy(10);
void et0() interrupt 3
    TH0=(65536-50000)/256;
    TL0=(65536-50000)%256;
    a++;
void et1()
    TMOD=0x01;
    EA=1;
 ET0=1;
    TR0=1;
    P2=0xff;
    P1=table[nian0];
    P2=0xF7;
    P2=0xff;
    P1=table[nian1];
    P2=0xfB;
    P2=0xff;
    P1=table[nian2];
    P2=0xfD;
    P2=0xff;
    P1=table[nian3];
    P2=0xfe;
    P2=0xff;
    P1=table[yue0];
    P2=0xfe;
    P2=0xff;
    P1=table[yue1];
    P2=0xfe;
    P2=0xff;
    P1=table[ri0];
    P2=0xfe;
    P2=0xff;
    P1=table[ri1];
    P2=0xfe;
    P2=0xff;
    P1=table[shi0];
    P2=0xfe;
    P2=0xff;
    P1=table[shi1];
    P2=0xfe;
    P2=0xff;
    P1=table[fen0];
    P2=0xfe;
    P2=0xff;
    P1=table[fen1];
    P2=0xfe;
    P2=0xff;
    P1=table[miao0];
    P2=0xfe;
    P2=0xff;
    P1=table[miao1];
    P2=0xfe;
void dealy(uint z)
        uint x,y;
        for(x=0;x<124;x++)
        for(y=0;y<z;y++);
Build target 'Target 1'
compiling 1.c...
1.C(27): warning C209: '_xs': too few actual parameters
1.C(21): warning C209: '_xs': too few actual parameters
linking...
Program Size: data=39.0 xdata=0 code=286
"1" - 0 Error(s), 2 Warning(s).
此帖出自51单片机论坛
头次见到这么多参数  详情 回复 发表于 2012-2-28 23:53
7230
195
xs(0,2,2,7);
你看看自己声明的函数里面有几个形参
太少的实参
此帖出自51单片机论坛
4008
头次见到这么多参数
此帖出自51单片机论坛
