// 2012-2 by naga lee
#include <reg51.h> #include <intrins.h> //_nop_();
sbit Max7129_DIN = P1^3; // Serial-Data Input: rising edge sbit Max7129_LOAD = P1^5; // Load-Data Input: rising edge sbit Max7129_CLK = P1^4; // Serial-Clock Input: maximum 10MHz unsigned char k1,k2,k3,k4,k5,k6,k7=0x00,k8=0x00; unsigned int cnt=0;
#define MSB 0x80 #define LSB 0x01 #define HIGH 1 #define LOW 0 // max7129 暫存器說明 #define DECODE_MODE 0x09 // 解碼方式 #define INTENSITY 0x0A // 顯示亮度 #define SCAN_LIMIT 0x0B // 掃描位數 #define SHUT_DOWN 0x0C // 掉電模式 #define DISPLAY_TEST 0x0F // 顯示測試
// x是後 y是前 unsigned char code buf_x[10][8]={ {0x00,0x83,0x03,0x03,0x03,0x03,0x03,0x83},//0 {0x00,0x83,0x80,0x80,0x80,0x80,0x82,0x80},//1 {0x00,0x83,0x02,0x02,0x83,0x01,0x01,0x83},//2 {0x00,0x83,0x01,0x01,0x83,0x01,0x01,0x83},//3 {0x00,0x01,0x01,0x01,0x83,0x03,0x03,0x03},//4 {0x00,0x83,0x01,0x01,0x83,0x02,0x02,0x83},//5 {0x00,0x83,0x03,0x03,0x83,0x02,0x02,0x83},//6 {0x00,0x01,0x01,0x01,0x01,0x01,0x01,0x83},//7 {0x00,0x83,0x03,0x03,0x83,0x03,0x03,0x83},//8 {0x00,0x83,0x01,0x01,0x83,0x03,0x03,0x83} //9 }; unsigned char code buf_y[10][8]={ {0x00,0x2c,0x0c,0x0c,0x0c,0x0c,0x0c,0x2c},//0- {0x00,0x2c,0x20,0x20,0x20,0x20,0x24,0x20},//1- {0x00,0x2c,0x04,0x04,0x2c,0x08,0x08,0x2c},//2- {0x00,0x2c,0x08,0x08,0x2c,0x08,0x08,0x2c},//3- {0x00,0x08,0x08,0x08,0x2c,0x0c,0x0c,0x0c},//4- {0x00,0x2c,0x08,0x08,0x2c,0x04,0x04,0x2c},//5- {0x00,0x2c,0x0c,0x0c,0x2c,0x04,0x04,0x2c},//6- {0x00,0x08,0x08,0x08,0x08,0x08,0x08,0x2c},//7- {0x00,0x2c,0x0c,0x0c,0x2c,0x0c,0x0c,0x2c},//8- {0x00,0x2c,0x08,0x08,0x2c,0x0c,0x0c,0x2c} //9- }; // void Max7219_WriteByte(unsigned char byte); void Max7219_WriteData_01(unsigned char addr, unsigned char dat0,unsigned char dat1,unsigned char dat2,unsigned char dat3); void Max7219_Init(void); void Init_IRQ(void); void Init_IRQ() {
ET1 = 0x01; //Enable Timer Interrupt 1
TMOD = 0X10 ; TH1 = 0X00 ; TL1 = 0XA0 ; EA = 0x01 ; //Enable All Interrupt TR1 = 0X01 ; //START TIMER1
} // 送出1byte: // 上升沿發送數據 // MSB first void Max7219_WriteByte(unsigned char byte) {
unsigned char i;
for (i=0; i<8; i++) {
_nop_(); Max7129_CLK = LOW; Max7129_DIN = (bit)(byte & MSB);//運算結果=0即輸出0,不是0即輸出1 byte <<= 1; Max7129_CLK = HIGH; }
} // write a byte to register // 先address 後data void Max7219_WriteData_01(unsigned char addr, unsigned char dat0,unsigned char dat1,unsigned char dat2,unsigned char dat3) { Max7129_LOAD = HIGH; // 使Max7129_LOAD HI _nop_(); Max7129_LOAD = LOW; // 使Max7129_LOAD LOW 串列資料傳送ENABLE _nop_(); Max7219_WriteByte(addr); Max7219_WriteByte(dat0);
Max7219_WriteByte(addr); Max7219_WriteByte(dat1);
Max7219_WriteByte(addr); Max7219_WriteByte(dat2);
Max7219_WriteByte(addr); Max7219_WriteByte(dat3); _nop_(); Max7129_LOAD = HIGH; // 使Max7129_LOAD HI 串列資料傳送DISABLE _nop_(); _nop_(); _nop_(); }
void OUT_0(void) { Max7219_WriteData_01(1, buf_x[k1][0]|buf_y[k2][0],buf_x[k3][0]|buf_y[k4][0],buf_x[k5][0]|buf_y[k6][0],buf_x[k7][0]|buf_y[k8][0]); Max7219_WriteData_01(2, buf_x[k1][1]|buf_y[k2][1],buf_x[k3][1]|buf_y[k4][1],buf_x[k5][1]|buf_y[k6][1],buf_x[k7][1]|buf_y[k8][1]); Max7219_WriteData_01(3, buf_x[k1][2]|buf_y[k2][2],buf_x[k3][2]|buf_y[k4][2],buf_x[k5][2]|buf_y[k6][2],buf_x[k7][2]|buf_y[k8][2]); Max7219_WriteData_01(4, buf_x[k1][3]|buf_y[k2][3],buf_x[k3][3]|buf_y[k4][3],buf_x[k5][3]|buf_y[k6][3],buf_x[k7][3]|buf_y[k8][3]);
Max7219_WriteData_01(5, buf_x[k1][4]|buf_y[k2][4],buf_x[k3][4]|buf_y[k4][4],buf_x[k5][4]|buf_y[k6][4],buf_x[k7][4]|buf_y[k8][4]); Max7219_WriteData_01(6, buf_x[k1][5]|buf_y[k2][5],buf_x[k3][5]|buf_y[k4][5],buf_x[k5][5]|buf_y[k6][5],buf_x[k7][5]|buf_y[k8][5]); Max7219_WriteData_01(7, buf_x[k1][6]|buf_y[k2][6],buf_x[k3][6]|buf_y[k4][6],buf_x[k5][6]|buf_y[k6][6],buf_x[k7][6]|buf_y[k8][6]); Max7219_WriteData_01(8, buf_x[k1][7]|buf_y[k2][7],buf_x[k3][7]|buf_y[k4][7],buf_x[k5][7]|buf_y[k6][7],buf_x[k7][7]|buf_y[k8][7]); }
void Max7219_Init(void) { Max7219_WriteData_01(SHUT_DOWN, 0x01,0X01,0X01,0X01); // 掉電模式 : 1, 正常操作; 0, 睡眠模式
Max7219_WriteData_01(DISPLAY_TEST, 0x00,0X00,0X00,0X00); // 顯示測試 : 0, 正常模式; 1, 測試模式
Max7219_WriteData_01(DECODE_MODE, 0x00,0X00,0X00,0X00); // 解碼方式:0, 不解碼; 1, BCD解碼
Max7219_WriteData_01(SCAN_LIMIT, 0x07,0X07,0x07,0X07); // 掃描位數 : 0 ~ 7 最多支援8位數字
Max7219_WriteData_01(INTENSITY, 0x01,0X01,0X01,0X01); // 顯示亮度: 0 ~ F F最亮 }
void Timer_Interrupt_1() interrupt 3 { cnt++;
TH1 = 0X01 ; //a8 ; TL1 = 0X88 ; }
void main(void) { Max7129_LOAD = HIGH; // 使Max7129_LOAD HI Max7129_CLK = HIGH; // 使Max7129_CLK HI Max7219_Init(); _nop_(); Init_IRQ(); while(1) { k1 = cnt % 10 ; k2 = (cnt/10)%10 ; k3 = (cnt/100)%10 ; k4 = (cnt/1000)%10 ; k5 = (cnt/10000)%10 ; k6 = (cnt/100000)%10 ; OUT_0(); } }
