5691|7
78
在做两块LM3S9B96用spi通信,从机收不到数。 [复制链接]
把主机发送和从机接收的程序附上
请大家帮我看看问题出在哪里?先谢谢了。
SPI_rec_slave(从机接收程序)
#include "inc/hw_memmap.h"
#include "inc/hw_ssi.h"
#include "inc/hw_types.h"
#include "driverlib/ssi.h"
#include "driverlib/gpio.h"
#include "driverlib/sysctl.h"
#include "driverlib/uartstdio.h"
#define NUM_SSI_DATA 8
#define USER_BITRATE  115200
InitConsole(void)
    SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOA);
    GPIOPinConfigure(GPIO_PA0_U0RX);
    GPIOPinConfigure(GPIO_PA1_U0TX);
    GPIOPinTypeUART(GPIO_PORTA_BASE, GPIO_PIN_0 | GPIO_PIN_1);
    UARTStdioInit(0);
int
main(void)
    unsigned long ulDataRx[NUM_SSI_DATA];
unsigned long ulindex;
    // Set the clocking to run directly from the external crystal/oscillator.
    // TODO: The SYSCTL_XTAL_ value must be changed to match the value of the
    // crystal on your board.
    SysCtlClockSet(SYSCTL_SYSDIV_1 | SYSCTL_USE_OSC | SYSCTL_OSC_MAIN |
                   SYSCTL_XTAL_16MHZ);
InitConsole();
    //SSI1时钟允许
    SysCtlPeripheralEnable(SYSCTL_PERIPH_SSI1);
    //允许GPIOE模块的时钟,因为GPIOE0,GPIOE1,GPIOE2,GPIOE3是SSI1引脚,允许时钟后才能使用SSI1模块
    SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOE);
    //设定PA2&PA3&PA4&PA5为SSI1引脚,GPIOPinConfigure设定GPIOPCTL和GPIOAPSEL寄存器.
    GPIOPinConfigure(GPIO_PE0_SSI1CLK);
    GPIOPinConfigure(GPIO_PE1_SSI1FSS);
    GPIOPinConfigure(GPIO_PE2_SSI1RX);
    GPIOPinConfigure(GPIO_PE3_SSI1TX);
    //GPIOPinTypeSSI中设定相关引脚的方向和上拉大小,推挽式无弱上拉
    GPIOPinTypeSSI(GPIO_PORTE_BASE, GPIO_PIN_3 | GPIO_PIN_2 | GPIO_PIN_1 |
                   GPIO_PIN_0);
    //SSIConfigSetExpClk(SSI的基础地址,供给SSI的时钟即系统时钟的30分频,SSI的数据格式SPI格式还是TI格式,
    //                      SSI是作为主模式还是从模式,设置BITRATE,设置数据长度)
    SSIConfigSetExpClk(SSI1_BASE, SysCtlClockGet()/30,
                       SSI_FRF_MOTO_MODE_0,
                       SSI_MODE_SLAVE, USER_BITRATE, 8);
    //设置SSICR1[SSE]寄存器,允许SSI1
    SSIEnable(SSI1_BASE);
UARTprintf("\n\nTest Start.\n\n");
    //接收数据,直到无数据直接返回0
    while(SSIDataGetNonBlocking(SSI1_BASE, &ulDataRx[0]))
    for(ulindex = 0; ulindex < NUM_SSI_DATA; ulindex++)
        //接收数据,把一个数据读出SSI1 的RX FIFO(如无数据直接返回)
        //前面用SSIBusy确认数据都发完了,所以可以NonBlocking
        SSIDataGetNonBlocking(SSI1_BASE, &ulDataRx[ulindex]);
        // 只要低八位
        ulDataRx[ulindex] &= 0x00FF;
        //输出接收到的数据
        UARTprintf("'%c' ", ulDataRx[ulindex]);
    // 说明测试通过
    // Return no errors
    return(0);
SPI_send_master(主机发送程序)
int
main(void)
    unsigned long ulDataTx[NUM_SSI_DATA];
                   SYSCTL_XTAL_16MHZ);
    // The SSI0 peripheral must be enabled for use.
     //SSI0时钟允许
    SysCtlPeripheralEnable(SYSCTL_PERIPH_SSI0);
    //允许GPIOA模块的时钟,因为GPIOA2,GPIOA3,GPIOA4,GPIOA5是SSI0引脚,允许时钟后才能使用SSI0模块
    //设定PA2&PA3&PA4&PA5为SSI0引脚,GPIOPinConfigure设定GPIOPCTL和GPIOAPSEL寄存器.
    GPIOPinConfigure(GPIO_PA2_SSI0CLK);
    GPIOPinConfigure(GPIO_PA3_SSI0FSS);
    GPIOPinConfigure(GPIO_PA4_SSI0RX);
    GPIOPinConfigure(GPIO_PA5_SSI0TX);
    GPIOPinTypeSSI(GPIO_PORTA_BASE, GPIO_PIN_5 | GPIO_PIN_4 | GPIO_PIN_3 |
                   GPIO_PIN_2);
    //                      SSI是作为主模式,设置BITRATE,设置数据长度)
    SSIConfigSetExpClk(SSI0_BASE, SysCtlClockGet()/30,
                       SSI_MODE_MASTER, USER_BITRATE, 8);
    //设置SSICR1[SSE]寄存器,允许SSI0
    SSIEnable(SSI0_BASE);
    //接收数据,直到无数据直接返回0
    while(SSIDataGetNonBlocking(SSI0_BASE, &ulDataRx[0]))
    // Initialize the data to send.
    //初始化需要发送的数据
    ulDataTx[0] = 'M';
    ulDataTx[1] = '3';
    ulDataTx[2] = 'S';
    ulDataTx[3] = 'P';
    ulDataTx[4] = 'I';
    ulDataTx[5] = 'A';
    ulDataTx[6] = 'B';
    ulDataTx[7] = 'C';
        //发送数据,把一个数据写入SSI0 的TX FIFO(如无空间一直等待)
        SSIDataPut(SSI0_BASE, ulDataTx[ulindex]);
   return(0);
楼主你的程序可否发下给我呀??最近在研究,搞不定   详情 回复 发表于 2015-3-27 10:50
点赞 关注(1)
569
楼主示波器上,能看到主机有发送数据吗?
78
回复 沙发 hlx3012 的帖子
没有波形,我之前在一块板子上使用SSI0模块为主,SSI1模块为从,一个发送一个接收。成功了。我把这个程序拆开分别下到两个板子里一个不停的发送,另一个不停的接收就不行了。弄了一天了。
569
我提几点建议,楼主看看有没帮助:
1、既然“之前在一块板子上使用SSI0模块为主,SSI1模块为从,一个发送一个接收。成功了"那么说明软件是正确的
2、既然没有发送波形说明主机没有发出数据,那么先检查主机
3、在你之前的一块板子上,把你的主机程序放进去有数据发出吗?如果有,那么同样的程序同样的芯片。你现在这块板子为什么会没有数据发出,硬件有问题?
78
回复 4楼 hlx3012 的帖子
应该没有问题,应该是程序的问题,我再好好检查检查,改好了再和大家一起分享下心得。
回复【在做两块LM3S9B96用spi通信,从机收不到数。】
SSI只有在主机模式下,才能产生SCLK。即从机若想发送数据,反过来想就是主机接收从机数据(读取从机),可这样写函数://接收一个字节
unsigned char ssi_Get_c(void)
   unsigned long ReadData;
   SSIDataPut(SSI0_BASE, 0xff);//发送一个无效字节,以产生接收时钟
   SSIDataGet(SSI0_BASE, &ReadData);
   return (unsigned char)ReadData;
注:飞思卡尔的SPI模式为全双工通信,即同时收发。无论是要主机收发动作,还是从机收发动作,归根结底都先要在主机上产生SCLK,如“SSIDataPut(SSI0_BASE, 0xff);//发送一个无效字节,以产生接收时钟”,就是这个目的。
41
参考一下SD卡的例程,里面有SPI通信代码,从机接收最好用中断。
24
