10043|11
36
ADC10序列通道单次转换数据怎样使用 [复制链接]
//  MSP430F21x2 Demo - ADC10, DTC Sample A2-0, AVcc, Single Sequence, DCO
//  Description: Sample A2/A1/A0 as single sequence with reference to AVcc.
//  Software sets ADC10SC to trigger sample sequence. In Mainloop MSP430 waits
//  in LPM0 to save power until ADC10 conversion complete, ADC10_ISR(DTC) will
//  force exit from any LPMx in Mainloop on reti. ADC10_ISR will force LPM0
//  exit. ADC10 internal oscillator times sample period (16x) and conversion
//  (13x). DTC transfers conversion code to RAM 200h - 206h. P1.0 set at start
//  of conversion burst, reset on completion.
//               MSP430F21x2
//        /|\|              XIN|-
//         --|RST          XOUT|-
//       >---|P2.2/A2      P1.0|-->LED
//       >---|P2.1/A1          |
//       >---|P2.0/A0          |
//  A. Dannenberg
//  Texas Instruments Inc.
//  December 2007
//  Built with CCE Version: 3.2.0 and IAR Embedded Workbench Version: 3.41A
#include "msp430x21x2.h"
void main(void)
  WDTCTL = WDTPW + WDTHOLD;                 // Stop WDT
  ADC10CTL1 = INCH_2 + CONSEQ_1;            // A2/A1/A0, single sequence
  ADC10CTL0 = ADC10SHT_2 + MSC + ADC10ON + ADC10IE;
  ADC10DTC1 = 0x03;                         // 3 conversions
  ADC10AE0 |= 0x07;                         // P2.2,1,0 ADC10 option select
  P1DIR |= 0x01;                            // Set P1.0 output
  for (;;)
    ADC10CTL0 &= ~ENC;
    while (ADC10CTL1 & BUSY);               // Wait if ADC10 core is active
    ADC10SA = 0x200;                        // Data buffer start
    P1OUT |= 0x01;                          // P1.0 = 1
    ADC10CTL0 |= ENC + ADC10SC;             // Sampling and conversion start
    __bis_SR_register(CPUOFF + GIE);        // LPM0, ADC10_ISR will force exit
    P1OUT &= ~0x01;                         // P1.0 = 0
// ADC10 interrupt service routine
#pragma vector=ADC10_VECTOR
__interrupt void ADC10_ISR(void)
  __bic_SR_register_on_exit(CPUOFF);        // Clear CPUOFF bit from 0(SR)
这是官网上的一个示例,我想问下A2,A1,A0口的转换好的数据都放在哪了,该怎样调用转换好的数据呀,ADC10MEM好像只能存放一个数据吧,请各位帮忙指点下吧~~~
选用什么基准电压啊?  详情 回复 发表于 2012-9-15 06:21
5015
裸片初长成(初级)
ADC10MEM确实只放一个数据,每次转换完成ADC10IFG会置位一次,先是A2 然后A1 再是A0
36
回复 沙发 wstt 的帖子
ADC10SA = 0x200; 是不是这个语句把A2中转换好的数据转移到0x200这个地址里啦,A1放到0X202里面啦,A0放到0x204里面啦~~我只要读这些数据地址里面的数据就可以了呢~~~但是里面的数据怎么读出呢,用啥语句?
[ 本帖最后由 woody13 于 2012-2-17 10:08 编辑 ]
65
MSP430的ADC10确实只有一个ADC10MEM,只能存储一次转换的数据。所以ADC10还设计了一个DTC模块(Data Transfer Controller),它可以自动的把ADC转换的数据搬移到RAM。所以,若要使用ADC10的单通道多次,序列通道单次以及序列通道多次采样,都必须要到DTC模块。楼主代码中ADC10SA = 0x200;就是设置DTC输出的RAM地址,而ADC10DTC1 = 0x03;  是设置RAM里的buffer长度为3。而代码中没有对ADC10DTC0的设置,那默认就是搬移3次后就结束。那转换完成后,读取0x200以后的6个byte,就是采样数据。
非常感谢!  详情 回复 发表于 2012-8-2 17:25
赞赏
查看全部赞赏
5015
裸片初长成(初级)
原帖由 woody13 于 2012-2-17 09:36 发表
是的,ADC10拥有DTC模块,可以直接将转换的数据存储到内存中。
这一部分参考DTC模块的使用方法,比较好理解
23
回复 板凳 woody13 的帖子
明明你在问有什么语句的么,别人都没回答到点上。
可能用a0=*0x200就可以读到里面的数据了吧。
麻烦LZ也告诉我一下你怎么读出来的
424
unsigned int a0, a1, a2;
a0 = *(unsigned int *)0x200;
a1 = *(unsigned int *)0x202;
a2 = *(unsigned int *)0x204;
读取是默认字读取不是字节读取的吗?  详情 回复 发表于 2012-7-30 16:27
36
回复 7楼 鸵鸟蝈蝈 的帖子
谢谢指点,这个方法好的,我是用protues仿真,可读出来的值出现错位了,不知是仿真软件有问题,还是自已数据转移有问题的~~
49
回复 7楼 鸵鸟蝈蝈 的帖子
读取是默认字读取不是字节读取的吗?
已经有强制类型转换了,会读16位出来  详情 回复 发表于 2012-8-1 05:18
424
回复 9楼 278023330 的帖子
已经有强制类型转换了,会读16位出来
回复 4楼 modernthink 的帖子
非常感谢!
选用什么基准电压啊?
