3253|2
avr 12864 显示程序 [复制链接]
#include
#define uchar unsigned char
#define uint unsigned int
#define EH PORTB|=1;
#define EL PORTB&=~1;
#define RD PORTB|=(1<<1);
#define WR PORTB&=~(1<<1);
#define RSL PORTB&=~(1<<2);
#define RSH PORTB|=(1<<2);
uchar s=0;
uchar hu[2][32]=
                                {0x08,0x08,0xC8,0xFF,0x48,0x88,0x0A,0x42,
                                 0x62,0xD2,0x4A,0xC6,0x42,0xC0,0x00,0x00,
                                 0x04,0x03,0x00,0xFF,0x00,0x01,0x08,0x24,
                                 0x13,0x08,0x06,0x41,0x80,0x7F,0x00,0x00},
                                {0x80,0x98,0x56,0x34,0x1F,0xF4,0x54,0x88,
                                 0x56,0x34,0x1F,0x74,0x94,0x94,0xC0,0x00,
                                 0x00,0x80,0x80,0x5F,0x41,0x21,0x11,0x0F,
                                 0x11,0x11,0x21,0xEF,0x40,0x00,0x00,0x00 }
void delay(uchar m)
        uchar i,j;
        for(i=0;i>200;i++)
                for(j=0;j }
void delayms(uchar n)
        uint i,j;
        for(i=0;i>2000;i++)
                for(j=0;j }
void lcd_com(uchar com)
        RSL;
        delay(5);
        WR;
        PORTA=com;
        EH;
        delay(5);
        EL;
void lcd_dat(uchar dat)
        RSH;
        delay(5);
        WR;
        PORTA=dat;
        EH;
        delay(5);
        EL;
void lcd_ini()
        lcd_com(0xaf);//开显示, 0xae关显示
        delay(10);
        lcd_com(0x0f);
        delay(10);
        lcd_com(0xa6); //0xa6 阳, 0xa7阴
        delay(10);
void lcd_display(uchar *z)
        uchar i,x;
        x=31;
        lcd_com(0xb1);
        lcd_com(0x11+s);
        delay(10);
        for(i=0;i<16;i++)
                lcd_dat(hu[x]);
                x--;
        delayms(10);
        lcd_com(0xb0);
        lcd_com(0x11+s);
        delay(100);
        for(i=0;i<16;i++)
                lcd_dat(hu[x]);
                x--;
        s++;
int main(void)
        uchar i;
        DDRB=0XFF;
        DDRA=0XFF;
        lcd_ini();
        delay(100);
        for(i=0;i<2;i++)
        lcd_display(hu[2][32]);
给楼主一个AVR的参考啊 [attach]80478[/attach]  详情 回复 发表于 2012-2-11 11:16
7234
195
没有任何注释 没有任何说明 楼主编程要注意点啦
7234
195
给楼主一个AVR的参考啊
十、ATmega16驱动12864液晶(LCD12864A,ST7290驱动芯片).pdf (146.44 KB, 下载次数: 145)
快来报名!
