3502|0
管理员
[资料推荐]LM25117 -带模拟电流监视器的同步降压控制器! [复制链接]
The LM25117 is a synchronous buck controller intended for step-down regulator applications from a high voltage or widely varying input supply. The control method is based upon current mode control utilizing an emulated current ramp. Current mode control provides inherent line feed-forward, cycle-by-cycle current limiting and ease of loop compensation. The use of an emulated control ramp reduces noise sensitivity of the pulse-width modulation circuit, allowing reliable control of very small duty cycles necessary in high input voltage applications.
The operating frequency is programmable from 50 kHz to 750 kHz. The LM25117 drives external high-side and low-side NMOS power switches with adaptive dead-time control.
特性
# Emulated peak current mode control
# Wide operating range from 4.5V to 42V
# Robust 3.3A peak gate drives
# Adaptive dead-time output driver control
# Free-run or synchronizable clock up to 750kHz
# Optional diode emulation mode
# Programmable output from 0.8V
# Precision 1.5% voltage reference
# Analog current monitor
# Programmable current limit
# Hiccup mode over current protection
# Programmable soft-start and tracking
# Programmable line under-voltage lockout
# Programmable switch-over to external bias supply
# Thermal shutdown
更多技术文档,应用手册,参数下载: lm25117.pdf (746.71 KB, 下载次数: 10)
加EE小助手好友,
入技术交流群
EE服务号
精彩活动e手掌握
EE订阅号
热门资讯e网打尽
聚焦汽车电子软硬件开发
认真关注技术本身
加油!在电子行业默默贡献自己的力量!:)
