3096|2
23
帮忙看看24c64程序哪出问题了 [复制链接]
#include "MSP430F5438A.H"
#define uchar unsigned char
#define uint unsigned int
#define at2464_PIN P9OUT
#define at2464_RED P9IN
#define at2464_DIR P9DIR
#define at2464_SCL_H at2464_PIN|=BIT1
#define at2464_SCL_L at2464_PIN&=~BIT1
#define at2464_SCL BIT1
#define at2464_SDA_H at2464_PIN|=BIT0
#define at2464_SDA_L at2464_PIN&=~BIT0
#define at2464_SDA BIT0
#define at2464_SDA_IN at2464_DIR&=~at2464_SDA
#define at2464_SDA_OUT at2464_DIR|=at2464_SDA
uchar ack()
uchar error;
at2464_SDA_IN;
at2464_SCL_H;
if(at2464_RED&at2464_SDA) error=1;
else error=0;
at2464_SCL_L;
at2464_SDA_OUT;
return error;
void sent_byte(uchar dat)
uchar i;
at2464_SDA_OUT;
for(i=0;i<8;i++)
at2464_SCL_L;
if(dat&0x80) at2464_SDA_H;
else at2464_SDA_L;
at2464_SCL_H;_NOP();
dat<<=1;
at2464_SCL_L;
void write_byte(uchar byte_addr_h,uchar byte_addr_l,uchar dat)
uchar error=1;
at2464_SDA_OUT;
while(error)
at2464_SCL_H;
at2464_SDA_H;
at2464_SDA_L;
at2464_SCL_L;//start bit
sent_byte(0xA0);//device address write
error=ack();
sent_byte(byte_addr_h);//word address
error=ack();
sent_byte(byte_addr_l);
error=ack();
sent_byte(dat);//data
error=ack();
at2464_SCL_H;
at2464_SDA_L;
at2464_SDA_H;
at2464_SCL_L;//stop bit
uchar read_byte()
uchar buf,i,error=1;
while(error)
at2464_SDA_OUT;
at2464_SCL_H;
at2464_SDA_H;
at2464_SDA_L;
sent_byte(0xA1);//device address read
error=ack();
at2464_SDA_IN;
for(i=0;i<8;i++)
buf>>=1;
at2464_SCL_H;
if(at2464_RED&at2464_SDA) buf|=0x80;
at2464_SCL_L;_NOP();
at2464_SDA_OUT;
at2464_SCL_H;
at2464_SCL_L;
at2464_SCL_H;
at2464_SDA_L;
at2464_SDA_H;
return (buf);
void main()
uchar t;
WDTCTL = WDTPW + WDTHOLD;
P10DIR=0XFF;
P10OUT=0XAA;
at2464_DIR|=at2464_SCL;
write_byte(0x00,0x0a,0x33);
t=read_byte();
P10OUT=t;
while(1);
对着时序图看不知哪出错了,麻烦大家帮忙看看
如果自己实在是看不出问题的话,方便的用逻辑分析仪测吧!  详情 回复 发表于 2012-1-16 18:51
1729
23
最悲剧的就在这里了,放假回家了什么仪器都没,还有个18b20的用DCO做时钟总无法检测到存在脉冲,悲剧了
