#include <msp430x16x.h>
// Global variables char value = 0; // 8-bit value to write to segment A char* Flash_ptr; // Flash pointer char* RAM_ptr; // RAM pointer char* END_ptr; // End of FlashWrite routine
// Function prototypes void FlashWrite(); void CopyRoutine(); void End_of_FlashWrite();
void main(void) { WDTCTL = WDTPW + WDTHOLD; // Stop watchdog timer
_DINT(); // Diable Interrupts CopyRoutine(); // Copy FlashWrite routine to RAM _EINT(); // Enable Interrupts
while(1) // Repeat forever { Flash_ptr = (char *) 0x1000; // Initialize Flash pointer FCTL2 = FWKEY + FSSEL1 + FN0; // MCLK/2 for Flash Timing Generator FCTL1 = FWKEY + ERASE; // Set Erase bit FCTL3 = FWKEY; // Clear Lock bit
*Flash_ptr = 0; // Dummy write to erase Flash segment while(!(FCTL3 & WAIT)); // WAIT until Flash is ready asm("CALL #300h"); // Execute FlashWrite from RAM // Inline Assembly value++; // Increment value _NOP(); // SET BREAKPOINT HERE } }
void CopyRoutine() { Flash_ptr = (char*)FlashWrite; // Set pointer to FlashWrite routine RAM_ptr = (char*)0x0300; // Set pointer to RAM END_ptr = (char*)End_of_FlashWrite; // Set pointer to End_of_FlashWrite
while(END_ptr != Flash_ptr) // Check for end of FlashWrite { *RAM_ptr = *Flash_ptr; // Copy word to RAM Flash_ptr++; // Increment Flash pointer RAM_ptr++; // Increment RAM pointer } }
void FlashWrite() { volatile int i; // Use as write counter Flash_ptr = (char*)0x1000; // Initialize Flash pointer while(FCTL3 & BUSY); // Check Flash BUSY bit FCTL1 = FWKEY + BLKWRT + WRT; // Enable block-write operation for(i = 0; i < 64; i++) { *Flash_ptr = value; // Write value to flash Flash_ptr++; // Double-increment Flash pointer while(!(FCTL3 & WAIT)); // WAIT until Flash is ready } FCTL1 = FWKEY; // Clear BLKWRT & WRT bits while(FCTL3 & BUSY); // Check Flash BUSY bit FCTL3 = FWKEY + LOCK; // Reset LOCK bit return; // Exits routine }
void End_of_FlashWrite(){} // Marks end of FlashWrite
