5793|3
“char code reserve [3] _at_ 0x23;”是什么语法规则? [复制链接]
安装了uVision4之后,打开有个示例程序:
  1. /*------------------------------------------------------------------------------
    HELLO.C
  2. Copyright 1995-2005 Keil Software, Inc.
  3. #include <REG52.H>                /* special function register declarations   */
                                      /* for the intended 8051 derivative         */
  4. #include <stdio.h>                /* prototype declarations for I/O functions */
  5. #ifdef MONITOR51                         /* Debugging with Monitor-51 needs   */
    char code reserve [3] _at_ 0x23;         /* space for serial interrupt if     */
    #endif                                   /* Stop Exection with Serial Intr.   */
                                             /* is enabled                        */
  6. /*------------------------------------------------
    The main C function.  Program execution starts
    here after stack initialization.
    void main (void) {
  7. /*------------------------------------------------
    Setup the serial port for 1200 baud at 16MHz.
    #ifndef MONITOR51
        SCON  = 0x50;          /* SCON: mode 1, 8-bit UART, enable rcvr      */
        TMOD |= 0x20;               /* TMOD: timer 1, mode 2, 8-bit reload        */
        TH1   = 221;                /* TH1:  reload value for 1200 baud @ 16MHz   */
        TR1   = 1;                  /* TR1:  timer 1 run                          */
        TI    = 1;                  /* TI:   set TI to send first char of UART    */
    #endif
  8. /*------------------------------------------------
    Note that an embedded program never exits (because
    there is no operating system to return to).  It
    must loop and execute forever.
      while (1) {
        P1 ^= 0x01;           /* Toggle P1.0 each time we print */
        printf ("Hello World\n");   /* Print "Hello World" */
复制代码
请问:
(1)语句“char code reserve [3] _at_ 0x23;   ”初看不符合C语言的语法规则,难道这是51单片机C语言特有的?
(2)没搞明白“P1 ^= 0x01;”起什么作用,我把它注释掉之后,照样运行正常。
谢谢!
此帖出自51单片机论坛
受教了:carnation:  详情 回复 发表于 2012-8-2 18:09
4008
定义一个char数组位于代码段的0x23地址
P1 ^= 0x01;
^是异或操作,相当于最低位取反
此帖出自51单片机论坛
P1 ^= 0x01;
就是P1=P1^0x01;
此帖出自51单片机论坛
65
受教了:carnation:
此帖出自51单片机论坛
