5606|11
我的直流电机驱动程序不能世道电机匀速转动 [复制链接]
 如题,   我们实训选了直流电机可调转速的项目,但是我想领导程序完美一点,电机达到那个要求的转速后,只能在要求速度上下徘徊,不能达到那个指定速度后匀速转动。
程序如下:
//文件名:main.c
//文件功能:包含液晶显示子文件
#include<reg52.h>//包含52单片机头文件
#include<lcd1602.h>
sbit S1=P1^5;
sbit S2=P1^6;
sbit S3=P1^7;
sbit PWM=P2^7;
bit flag=0;
unsigned int sec;
unsigned char fun_num=0;
unsigned int  T0_num=0;
unsigned int  num1=0;    //本秒圈数
unsigned int  num2=0;    //上一秒圈数
unsigned int  fre0=20; //设定
unsigned int  fre =0;    //差:fre=num1-num2;
unsigned int  PWM_H=25; //高电平  所谓的“PWM”就是脉冲宽度调制
 //0123456789012345
  [T:00001 Fre:9999]
  [N:12345 fre:9999]
void display()
     unsigned int i,j;
     j=0;
  i=0;LCD_dis(j,i,'t');
  i++;LCD_dis(j,i,':');
  i++;LCD_dis(j,i,0x30+sec/10000);
  i++;LCD_dis(j,i,0x30+sec%10000/1000);
  i++;LCD_dis(j,i,0x30+sec%1000/100);
  i++;LCD_dis(j,i,0x30+sec%100/10);
  i++;LCD_dis(j,i,0x30+sec%10);
  i++;LCD_dis(j,i,' ');
  i++;LCD_dis(j,i,'F');
  i++;LCD_dis(j,i,'R');
  i++;LCD_dis(j,i,'E');
  i++;LCD_dis(j,i,0x30+fre0%10000/1000);
  i++;LCD_dis(j,i,0x30+fre0%1000/100);
  i++;LCD_dis(j,i,0x30+fre0%100/10);
  i++;LCD_dis(j,i,0x30+fre0%10);
     j=1;
  i=0;LCD_dis(j,i,'N');
  i++;LCD_dis(j,i,0x30+num1/10000);
  i++;LCD_dis(j,i,0x30+num1%10000/1000);
  i++;LCD_dis(j,i,0x30+num1%1000/100);
  i++;LCD_dis(j,i,0x30+num1%100/10);
  i++;LCD_dis(j,i,0x30+num1%10);
  i++;LCD_dis(j,i,0x30+fre%10000/1000);
  i++;LCD_dis(j,i,0x30+fre%1000/100);
  i++;LCD_dis(j,i,0x30+fre%100/10);
  i++;LCD_dis(j,i,0x30+fre%10);
//-----------------延时函数------------------------
void delay_20ms()
     unsigned int i=200;
  while(i--);
//----------------按键扫描函数----------------------
void scan_key()//按键扫描
  if(S1==0)
      delay_20ms();
   if(S1==0)
         fun_num++;
   if(fun_num>=5) fun_num=0;
   while(S1==0);
   delay_20ms();
  if(S2==0)
      delay_20ms();
   if(S2==0)
         if(fun_num==1)      {fre0+=1000;}
   else if(fun_num==2) {fre0+=100; }
   else if(fun_num==3) {fre0+=10;  }
   else if(fun_num==4) {fre0+=1;   }
   while(S2==0);
   delay_20ms();
  if(S3==0)
      delay_20ms();
   if(S3==0)
         if(fun_num==1)      {fre0-=1000;}
   else if(fun_num==2) {fre0-=100; }
   else if(fun_num==3) {fre0-=10;  }
   else if(fun_num==4) {fre0-=1;   }
   while(S3==0);
   delay_20ms();
void ex0_server() interrupt 0    //外部中断0
  num1++;
void t0_server()  interrupt 1    //定时器0中断
     TH0=(65536-5000)/256;
     TL0=(65536-5000)%256;
  T0_num++;
  if(T0_num<PWM_H)    //10ms*25=250ms
   PWM=1;
  else if(T0_num<100)  //10ms*100=1000ms=1s
      PWM=0;
  if (T0_num>=200)  //200*5ms=1s
   T0_num=0;
   PWM=1;
   flag=1;
   fre=num1-num2;
   num2=num1;
   sec++;
   if(fre>fre0) { if(PWM_H>0)   PWM_H--;}
   if(fre<fre0) { if(PWM_H<100) PWM_H++;}
   SBUF=0x30+fre%1000/100;while(TI==0);TI=0;
   SBUF=0x30+fre%100/10;  while(TI==0);TI=0;
   SBUF=0x30+fre%10;    while(TI==0);TI=0;
   SBUF=0x0d;            while(TI==0);TI=0;
   SBUF=0x0a;            while(TI==0);TI=0;
//***************串口中断函数**********************//
void serial_sever() interrupt 4
       if(RI==1) { RI  = 0; }
//--------------外部中断0的初始化函数----------------------------
void EX0_Init()
    IT0=1; EX0=1; EA=1; PX0=1;
//---------------定时中断0的初始化函数----------------------------
void ET0_Init()
    TMOD=0X01;
 ET0=1;
 EA =1;
 PT0=1;
 TR0=1;
//************串口中断的初始化函数*****************//
void s_Init()
 SCON  = 0x50;  // 串口工作在方式1, 允许接收
 PCON |= 0x80;  // SMOD=1;波特率倍增
 TMOD |= 0x20;  // 定时器1工作在方式2,重载
 TH1   = 0xf3;  // 波特率4800,fosc=12MHz
 TL1   = 0xf3;  // 波特率4800,fosc=12MHz
 EA = 1;
 ES = 1;        // 允许串行中断,interrupt enable
 TR1 = 1;       // 启动定时器1,timer1 run
 TI = 0;  //发送中断溢出标志
 RI = 0; //接收中断溢出标志
//-------------------主函数----------------------------------
void main()//
   Init_LCD();//液晶初始化
      EX0_Init();//调用外部中断0的初始化函数
   ET0_Init();//调用定时中断0的初始化函数
   s_Init();//调用串口中断的初始化函数
 while(1)
     if(flag==1)
     flag=0;
           display();
  scan_key();//按键扫描
  希望有高手帮忙改改!!  拜托了。
此帖出自51单片机论坛
不用去纠结这个问题   控制中不可能做到恒定不变   一般在5%范围内波动就已经很好了  详情 回复 发表于 2011-12-22 21:33
2751
裸片初长成(初级)
原帖由 UC_gundam 于 2011-12-21 15:10 发表  如题,   我们实训选了直流电机可调转速的项目,但是我想领导程序完美一点,电机达到那个要求的转速后,只能在要求速度上下徘徊,不能达到那个指定速度后匀速转动。程序如下:   / ...
有点波动是正常的吧,就算加入了闭环控制,使用pid等控制算法,也是会有点波动的,能满足精度需求就可以了吧。
此帖出自51单片机论坛
回复 沙发 David_Lee 的帖子
谢谢   现在在禀明的百度当中   但是要弄个回馈电路的话的话貌似比较麻烦  可不可以搞个函数   取转速的平均转速来调速呢
此帖出自51单片机论坛
4008
转速和电流平均和输出力矩有关.没有反馈负载变了你就不能恒速了.
此帖出自51单片机论坛
535
速度和负载有关吧!他的本质感觉是输出功率恒定吧!加入反馈控制会好一点,不知道你用的是什么电机,电机响应需要时间这个你要注意
此帖出自51单片机论坛
3404
裸片初长成(初级)
要想匀速肯定得有反馈,而引入反馈之后肯定会有波动,这个就要看你反馈信号的处理及响应的速度了,响应快了波动就显不出来了,
此帖出自51单片机论坛
1012
PI控制
此帖出自51单片机论坛
个人签名http://item.taobao.com/item.htm?id=12366456386
Arduino 兼容的  maple
不用去纠结这个问题
此帖出自51单片机论坛
其实要求的就是波动范围在5%之内   程序已经有闭环的了  但是PID的话我不太懂    昨天改了一下程序    转速要不就一直跟要求的一直,而且波动出现的比较小  但是问题就是凡是有波动  一般波动都比较大 晕死
此帖出自51单片机论坛
回复 7楼 ssawee 的帖子
我还没学额   而且上网看过了   还是不太懂  但是谢谢啦
此帖出自51单片机论坛
怎么说呢    都是小功率直流电机  毫瓦功率的   但是最大的话可以去到6500转/分
       输出的电流有闭环电路而且由IO口控制输出高低电平控制的了  但是效果不太理想就是了
此帖出自51单片机论坛
原帖由 小小白 于 2011-12-21 17:43 发表 速度和负载有关吧!他的本质感觉是输出功率恒定吧!加入反馈控制会好一点,不知道你用的是什么电机,电机响应需要时间这个你要注意
       厄``  其实这个我有注意的   但是想要恒定那个输出的那个功率的话我们还没能做到   呵呵   但是谢谢你的意见
此帖出自51单片机论坛
