2310|1
447
大家帮我看看这段程序哪有错误,运行后灯没有闪烁
用的是MSP430F5438
#include <msp430x54x.h>
void Init_Ta0(void);
void main(void)
WDTCTL = WDTPW + WDTHOLD; //关看门狗
P1DIR |= BIT0;                                // P1.0 作为输出
Init_Ta0();                                      //TA0 初始化
_BIS_SR(LPM0_bits + GIE);         // 进入低功耗LPM0
void Init_Ta0(void)
TA0CTL = TASSEL_2 + TACLR; // SMCLK, 计数器清除
TA0CCTL1 = CCIE;                    // CCR1 中断使能
TA0CCR1 = 50000;                   //配置定时值
TA0CTL |= MC_1;                     //增计数模式
#pragma vector=TIMER0_A1_VECTOR
__interrupt void Timer0_A1 (void)
  switch(TA1IV)
  {case 2:P1OUT ^= BIT0;        // LED1 闪烁
          break;
急~~
#include "msp430x54x.h"void main(void){  WDTCTL = WDTPW + WDTHOLD;                 // Stop WDT  P1DIR |= 0x01;                            // P1.0 output  TA1CTL = TASSEL_2 + MC_2 + TACLR + TAIE;  // SMCLK, contmode, clear TAR                                            // enable interrupt  __bis_SR_register(LPM0_bits + GIE);       // Enter LPM0, enable interrupts  __no_operation();                         // For debugger}// Timer_A3 Interrupt Vector (TAIV) handler#pragma vector=TIMER1_A1_VECTOR__interrupt void TIMER1_A1_ISR(void){  switch(__even_in_range(TA1IV,14))  {    case  0: break;                          // No interrupt    case  2: break;                          // CCR1 not used    case  4: break;                          // CCR2 not used    case  6: break;                          // reserved    case  8: break;                          // reserved    case 10: break;                          // reserved    case 12: break;                          // reserved    case 14: P1OUT ^= 0x01;                  // overflow             break;    default: break;   }}CCIE是对CCR0  详情 回复 发表于 2011-12-16 18:20
188
void main(void)
                                            // enable interrupt
             break;
    default: break;
CCIE是对CCR0
