4517|2
STM32 用FSMC驱动ILI9320 问题 [复制链接]
液晶驱起来了 但是在送单色的测试数据时候 有明显的亮纹  怎么办
此帖出自stm32/stm8论坛
条纹通常为频率或VCOM电压没设好,把程序贴上来看看  详情 回复 发表于 2011-12-16 09:46
条纹通常为频率没设好
此帖出自stm32/stm8论坛
void STM3210E_LCD_Init(void)
#if ISRST == 0
    GPIOB->ODR |= 0x02;
    _delay_ms(1);
    GPIOB->ODR &= ~(0x02);
    _delay_ms(1);
    GPIOB->ODR |= 0x02;
#endif
    _delay_ms(50); /* delay 50 ms */
#ifdef ILI9325
LCD_WriteReg(0x00e3,0x3008);
LCD_WriteReg(0x00e7,0x0012);
LCD_WriteReg(0x00ef,0x1231);//Set the internal vcore voltage
LCD_WriteReg(0x0001,0x0100);//S
#endif
#ifdef ILI9320
LCD_WriteReg(0x00e5,0x8000);
LCD_WriteReg(0x0000,0x0001);
#endif
LCD_WriteReg(0x0002,0x0700);//Line inversion
#if   ID_AM==000
LCD_WriteReg(0x0003,0x0000);//屏幕旋转控制 TFM=0,TRI=0,SWAP=1,16 bits system interface  swap RGB to BRG,此处ORG和HWM 为0
#elif ID_AM==001
LCD_WriteReg(0x0003,0x0008);
#elif ID_AM==010
LCD_WriteReg(0x0003,0x0010);
#elif ID_AM==011
LCD_WriteReg(0x0003,0x0018);
#elif ID_AM==100
LCD_WriteReg(0x0003,0x0020);
#elif ID_AM==101
LCD_WriteReg(0x0003,0x0028);
#elif ID_AM==110
LCD_WriteReg(0x0003,0x0030);
#elif ID_AM==111
LCD_WriteReg(0x0003,0x0038);
#endif
LCD_WriteReg(0x0004,0x0000);
LCD_WriteReg(0x0008,0x0207);
LCD_WriteReg(0x0009,0x0000);
LCD_WriteReg(0x000a,0x0000);
LCD_WriteReg(0x000c,0x0001);//此处配置接口类型 16位 system接口
LCD_WriteReg(0x000d,0x0000);
LCD_WriteReg(0x000f,0x0000);
//电源配置
LCD_WriteReg(0x0010,0x0000);
LCD_WriteReg(0x0011,0x0000);
LCD_WriteReg(0x0012,0x0000);
LCD_WriteReg(0x0013,0x0000);
LCD_WriteReg(0x0010,0x17b0);
LCD_WriteReg(0x0011,0x0137);
LCD_WriteReg(0x0012,0x0139);
LCD_WriteReg(0x0013,0x1700);
LCD_WriteReg(0x0029,0x000c);
//LCD_WriteReg(0x002b,0x000d);
#if   ID_AM==000
LCD_WriteReg(0x0020,0x00ef);//GRAM水平起始位置
LCD_WriteReg(0x0021,0x013f);
#elif ID_AM==001
#elif ID_AM==010
LCD_WriteReg(0x0020,0x0000);
#elif ID_AM==011
#elif ID_AM==100
LCD_WriteReg(0x0021,0x0000);
#elif ID_AM==101
#elif ID_AM==110
#elif ID_AM==111
#endif
LCD_WriteReg(0x0030,0x0000);
LCD_WriteReg(0x0031,0x0507);
LCD_WriteReg(0x0032,0x0104);
LCD_WriteReg(0x0035,0x0105);
LCD_WriteReg(0x0036,0x0404);
LCD_WriteReg(0x0037,0x0603);
LCD_WriteReg(0x0038,0x0004);
LCD_WriteReg(0x0039,0x0007);
LCD_WriteReg(0x003c,0x0501);
LCD_WriteReg(0x003d,0x0404);
LCD_WriteReg(0x0050,0x0000);//水平 GRAM起始位置
LCD_WriteReg(0x0051,0x00ef);//水平GRAM终止位置
LCD_WriteReg(0x0052,0x0000);//垂直GRAM起始位置
LCD_WriteReg(0x0053,0x013f);//垂直GRAM终止位置
#ifdef ILI9325
LCD_WriteReg(0x0060,0xa700);//G
#endif
#ifdef ILI9320
LCD_WriteReg(0x0060,0x2700);//G
#endif
LCD_WriteReg(0x0061,0x0001);//Enables the grayscale inversion of the image by setting REV=1.??????????????????????????????
LCD_WriteReg(0x006a,0x0000);//不使用卷曲功能
LCD_WriteReg(0x0080,0x0000);
LCD_WriteReg(0x0081,0x0000);
LCD_WriteReg(0x0082,0x0000);
LCD_WriteReg(0x0083,0x0000);
LCD_WriteReg(0x0084,0x0000);
LCD_WriteReg(0x0085,0x0000);
LCD_WriteReg(0x0090,0x0010);
LCD_WriteReg(0x0092,0x0000);
LCD_WriteReg(0x0093,0x0003);
LCD_WriteReg(0x0095,0x0110);
LCD_WriteReg(0x0097,0x0000);
LCD_WriteReg(0x0098,0x0000);
//显示画面写入 0x0130是不显示当前画面
//0x0173是显示当前画面
LCD_WriteReg(0x0007,0x0130);
#ifdef Immediately
LCD_WriteReg(0x0007,0x0173);
#endif
此帖出自stm32/stm8论坛
电源解决方案和技术 | DigiKey 应用探索站
