3942|5
9B96下载不进去 [复制链接]
芯片版本 LM3S9B96  IQC80C3XD  开发环境IAR版本5.4
警告信息
Thu Dec 15 17:09:18 2011: Warning:
Verify error at address 0x00001000, target byte: 0x70, byte in file: 0x00
Verify error at address 0x000010CB, target byte: 0x60, byte in file: 0x00
Verify error at address 0x000010CC, target byte: 0xC2, byte in file: 0xFF
Thu Dec 15 17:09:18 2011: Warning: Too many verify errors, only the first 200 are displayed
Thu Dec 15 17:09:18 2011: Warning: Verify error, failed to read memory at address 0x0000111C - 0x0000C39C
Thu Dec 15 17:09:21 2011: Warning: There were warnings during download, see Log Window
Thu Dec 15 17:09:21 2011: Loaded debugee: E:\9B96开发板资料\DK-LM3S9B96-CD-562\StellarisWare for C1\boards\dk-lm3s9b96\grlib_demo\ewarm\Exe\
grlib_demo.out
Thu Dec 15 17:09:22 2011: Software reset was performed
Thu Dec 15 17:09:22 2011: Target reset
Thu Dec 15 17:09:38 2011: Failed to read one or more register values (busy).
一开始还能下载程序,但是也有警告,后来就下不进去了!屏幕也白屏了!郁闷啊,板子刚到!
楼主这种情况后来好了吗?  详情 回复 发表于 2013-1-14 14:29
299
老版本的IAR开发环境需要打补丁,建议升级成最新版本试试。
87
下载最新版本的iar,老版本不能运行这个开发板
回复 板凳 wllyj 的帖子
能给个链接吗??????用KEIL行吗
299
keil 4.22也可以。
314
回复 楼主 wzp2007 的帖子
楼主这种情况后来好了吗?
