SD卡复位成功,可是初始化收不到00,希望版主帮忙
大致代码如下,用的是Znfat的代码,复位成功了,初始化不行。请大家帮忙看看。
#include "STC12C5A32S2.H" #define DELAY_TIME 10 #define TRY_TIME 200 void SD_spi_write(unsigned char x) { _dat=x; SD_SI=_dat7; SD_SCL=0; if(is_init) delay(DELAY_TIME); SD_SCL=1; if(is_init) delay(DELAY_TIME);
SD_SI=_dat6; SD_SCL=0; if(is_init) delay(DELAY_TIME); SD_SCL=1; if(is_init) delay(DELAY_TIME);
SD_SI=_dat5; SD_SCL=0; if(is_init) delay(DELAY_TIME); SD_SCL=1; if(is_init) delay(DELAY_TIME);
SD_SI=_dat4; SD_SCL=0; if(is_init) delay(DELAY_TIME); SD_SCL=1; if(is_init) delay(DELAY_TIME);
SD_SI=_dat3; SD_SCL=0; if(is_init) delay(DELAY_TIME); SD_SCL=1; if(is_init) delay(DELAY_TIME);
SD_SI=_dat2; SD_SCL=0; if(is_init) delay(DELAY_TIME); SD_SCL=1; if(is_init) delay(DELAY_TIME);
SD_SI=_dat1; SD_SCL=0; if(is_init) delay(DELAY_TIME); SD_SCL=1; if(is_init) delay(DELAY_TIME);
SD_SI=_dat0; SD_SCL=0; if(is_init) delay(DELAY_TIME); SD_SCL=1; if(is_init) delay(DELAY_TIME); } 读字节和这个函数刚好相反,字数有限就不贴了。 unsigned char SD_Write_Cmd(unsigned char *pcmd) //向SD卡写命令,pcmd是命令字节序列的首地址 { unsigned char temp,time=0;
SD_CS=1; SD_spi_write(0xff); //提高兼容性,如果没有这里,有些SD卡可能不支持 SD_CS=0; SD_spi_write(pcmd[0]); SD_spi_write(pcmd[1]); SD_spi_write(pcmd[2]); SD_spi_write(pcmd[3]); SD_spi_write(pcmd[4]); SD_spi_write(pcmd[5]);
do { temp = SD_spi_read();//一直读,直到读到的不是0xff或超时 //senddata(temp); time++; }while((temp==0xff)&&(time<TRY_TIME));
return(temp); } unsigned char SD_Init() //初始化,使用CMD1(命令1) { unsigned char time,temp; unsigned char pcmd[] = {0x41,0x00,0x00,0x00,0x00,0xff}; //命令1的字节序列
SD_CS=0; //打开片选
time=0; do { temp=SD_Write_Cmd(pcmd); time++; if(time==TRY_TIME) { SD_CS=1; //关闭片选 return(INIT_CMD1_ERROR);//CMD1写入失败 } }while(temp!=0); is_init=0; //初始化完毕,将is_init设置为0,为了提高以后的数据传输速度 SD_CS=1; //关闭片选
SD_spi_write(0xff); //按照SD卡的操作时序在这里补8个时钟 return(0); //返回0,说明初始化操作成功 } unsigned char SD_Reset() { unsigned char time,temp,i; unsigned char pcmd[] = {0x40,0x00,0x00,0x00,0x00,0x95};
is_init=1; //is_init置为1,让SPI速度慢下来
SD_CS=1; for(i=0;i<0x0f;i++) //初始时,首先要发送最少74个时钟信号,这是必须的!!! { SD_spi_write(0xff); //120个时钟 }
SD_CS=0; time=0; do { temp=SD_Write_Cmd(pcmd);//写入CMD0 time++; if(time==TRY_TIME) { return(INIT_CMD0_ERROR);//CMD0写入失败 } }while(temp!=0x01);
SD_CS=1; SD_spi_write(0xff); //按照SD卡的操作时序在这里补8个时钟 return 0;//返回0,说明复位操作成功 } void main() { int i,j; i=1; serialinit(); j=SD_Reset();//SD卡复位 i=SD_Init(); //SD卡初始化 senddata(j); //senddata(i); while(1) {} }
下面附件是原理图,现在搞不清楚是硬件问题还是软件问题了。
