#include<reg52.h> #define uchar unsigned char #define uint unsigned int uchar code Disp[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f}; unsigned char code Disp_Sel[] = {0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F}; uchar aa=0; unsigned int tmp; long f; void init(); sbit P21=P2^1; sbit P22=P2^2; sbit P23=P2^3; unsigned char num=0; uint ff; uchar count; uchar first; void display(); void diffence(); void main() { init(); first=0; while(1) { switch(count)// { case 0:P21=0;P22=0;P23=0;tmp=f*1;break; case 1:P21=0;P22=0;P23=1;tmp=f*10;break; case 2:P21=0;P22=1;P23=0;tmp=f*100;break; case 3:P21=0;P22=1;P23=1;tmp=f*1000;break; case 4:P21=1;P22=0;P23=0;tmp=f*10000;break; case 5:P21=1;P22=0;P23=1;tmp=f*100000;break; case 6:P21=1;P22=1;P23=0;tmp=f*1000000;break; case 7:P21=1;P22=1;P23=1;tmp=f*10000000;break; default:break; } } } void init() { TMOD=0x51;//T1计数。T0定时 TH1=0; TL1=0; TH0=(65536-50000)/256;//T0初值为50ms TL0=(65536-50000)%256; TR0=1; TR1=1; EA=1; ET0=1; } void TT0() interrupt 1 { TH0=(65536-50000)/256;//重赋T0初值为50ms TL0=(65536-50000)%256; aa++; if(first == 0)//开始测频时,单片机进行粗略的计算 { if(aa==20) { first =1; aa=0; f = (TH1*256 + TL1)+ff*65536; ff=0; TL1 = 0; TH1 = 0; diffence();//分挡位 } } else//分频后,精确测频 { if(aa==20) { first =0; aa=0; f = (TH1*256 + TL1)+ff*65536; ff=0; TL1 = 0; TH1 = 0; display();//加入显示函数 } } } void diffence()//分挡位 { if(f < 5000) count=0; else if(((f == 5000)||(f > 5000)) && ((f == 10000)||(f < 10000))) count=1; else if((f > 10000) && (f < 50000)) count=2; else if((f>50000)&&(f<100000)) count=3; else if((f>100000)&&(f<500000)) count=4; else if((f>500000)&&(f<1000000)) count=5; else if((f>1000000)&&(f<10000000)) count=6; else if((f>100000000)&&(f<200000000)) count=7; } void TT1() interrupt 3 { ff++; } void display() { num++; num=(num%8); P1=0xff; P0=0xff; P0=Disp_Sel[num]; switch(num) { case 0: P1=Disp[f%10]; break; case 1: P1=Disp[f%100/10]; break; case 2: P1=Disp[f%1000/100]; break; case 3: P1=Disp[f%10000/1000]; break; case 4: P1=Disp[f%100000/10000]; break; case 5: P1=Disp[f%1000000/10000]; break; case 6: P1=Disp[f%1000000/100000]; break; case 7: P1=Disp[f/1000000]; break; default: break; } }
