3100|1
37
【低功耗】FPGA Low Power Technology Mapping for Reuse Module Design [复制链接]
In this paper, FPGA low power technology mapping for reuse module design under the time constraint is proposed. Traditional high-level synthesis does not allow reuse of complex, realistic datapath component during the task of scheduling. On the other hand, the proposed algorithm is able to approach a productivity of the design the low power to reuse which given a library of user-defined datapath component and to share of resource sharing on the switching activity in a shared resource. Also, we are obtainable the optimal the scheduling result in experimental results of our using chaining and multi-cycling in the scheduling techniques. Low power circuit make using FPGA technology mapping algorithm for selection reuse module by scheduling
12.pdf (251.15 KB, 下载次数: 7)
此帖出自FPGA/CPLD论坛
顶,不错!  详情 回复 发表于 2011-11-23 08:19
6892
顶,不错!
此帖出自FPGA/CPLD论坛
个人签名一个为理想不懈前进的人,一个永不言败人!
欢迎光临网上店铺!
