2232|0
294
如何利用专门设计的测量室和分子束沉积(MBD)系统测量高电阻概述 [复制链接]
晶体[1]材料是现代电子和光电子技术的基础。因此,这些材料的电子特性,如(各向异性) 电导率和光电导率以及与这些特性有关的温度依存性,都是研究人员关注的问题。采用大量结晶技术的晶体生长尺寸可能不大,但往往表现出极高的电阻。这个应用笔记说明如何利用专门设计的测量室[2]分子束沉积(MBD)系统(在晶体或薄膜生长过程中对其进行现场测量)来测量高达1017W的电阻
Crystalline materials are fundamental to modern electronics andoptoelectronics. Therefore, the electrical properties of thesematerials, such as their  and photocon-ductivity, as well as the temperature dependencies associatedwith these properties, are of great interest to researchers. Thecrystals grown using a number of crystallization techniques maybe small in size and often exhibit very high resistances. Thisapplication note describes how to measure resistances as high as1017in a specially designed measurement chamber, as well asin a Molecular Beam Deposition (MBD) system that allowsmaking in-situ measurements during crystal or film growth.
   了解更多信息
要想了解有关6517A型静电计/高阻表[3]或者吉时利其他系列数字源表的更多信息,请点击http://www.keithley.com.cn/products/localizedproducts/highresistance/6517a,或者联系吉时利公司:全国免费电话800-810-1334手机用户请拨打440-650-1334
登录吉时利官方微博(http://weibo.com/keithley)与专家进行互动。
吉时利仪器公司(中国)市场部
(T) 8008101334,  8610 82255010,  82255011
[1] 晶体http://www.keithley.com.cn/llm/a/11.html
[2] 测量室http://www.keithley.com.cn/llm/a/searchresults?q=%E6%B5%8B%E9%87%8F%E5%AE%A4
[3] 6517A型静电计/高阻表http://www.keithley.com.cn/products/localizedproducts/highresistance/6517a
